When I came home from work tonight I noticed that about half of my HD stations where jumpy/showing static/breaking up.
I followed some of the tips in the FAQ and noticed that the "Current FDC" is -13 and the "Current QAM" reading is -20....both well below the described acceptable limit. My question is this...if I call Rogers will they be able to just adjust the signal strength on their end easily or is it much more complicated than that? Or worse will they tell me that a technician needs to come to my place? *Of note: (a) I have already tried rebooting the STB and (b) nothing has been changed/moved in my HT setup in over a couple months TIA
StarChoice, DSR 505HD, Sony 46WT510, Sony STR DE-695, Samsung DVD-HD841 |
You should Call Rogers. Cause their could be a area wide problem.
Just to be on the safe side,.
Rogers Digtal Cable,PVR8642HD/PVR8000, VIP ULTIMATE+TMN Playboy, Hustler, Super , WWE 24/7, BELL TV 9241PVRHD, |
#5 | |
I am now able to view the HD stations without any breakups and the signal strength is reading a little bit higher, so perhaps it was just an issue with my area last night as SMCKINNON24 stated. Thanks.
Thank- you.
Hope it doens't happen again. If it does just call Rogers and see if their is a problem.
It sounds like your signal is low. I would call them out anyway.
#9 | |
#10 | |
#11 | |
#12 | |
