#76 |
I've run many "optimization" runs on a lot of antenna models....half-an-inch
one way or another is barely perceptible.... |
#77 |
With the help of envirogeek for the pictures and dimensions of the U8000 phasing lines, heres a closer to real life model of the U8000.
Raw Gain: ![]() Note: At the 470 mhz end of the scale, add about .3 dBi. At the 806 mhz end of the scale, subtract about .12 dBi. The middle of the scale doesnt need to be adjusted. SWR: ![]() NEC file: Code:
CM AntennaCraft U8000 NEC model, Closer to Real Life CM Modeled by 300 ohm, measured by octopod, phasing line help from envirogeek CM BowLen=8.0", BowSep=8.0", Reflector to Element Sep=4.00" (AWG9 Elements/Phase Lines) CM 9 Refl. Rods, 20-in long. Autoseg(21), AGT=1.0 at 585 mhz. CM AGT= .93 (-0.3 db) at 470 mhz, AGT= 1.03 (.12 db) at 806 mhz CM FeedSep=2.0" on individual U4000's CE GW 1 3 0 -9.125 4 0 -8.4178932 4.70710678 0.05721178 GW 2 13 0 -8.4178932 4.70710678 0 -1.7620476 6.875 0.05721178 GW 3 3 0 -9.125 4 0 -8.4178933 3.29289331 0.05721178 GW 4 13 0 -8.4178933 3.29289331 0 -1.7620476 1.125 0.05721178 GW 5 3 0 -11.125 4 0 -11.832107 4.70710709 0.05721178 GW 6 13 0 -11.832107 4.70710709 0 -18.487952 6.875 0.05721178 GW 7 3 0 -11.125 4 0 -11.832107 3.29289331 0.05721178 GW 8 13 0 -11.832107 3.29289331 0 -18.487952 1.125 0.05721178 GW 9 3 0 -9.125 12 0 -8.4178932 12.7071068 0.05721178 GW 10 13 0 -8.4178932 12.7071068 0 -1.7620476 14.875 0.05721178 GW 11 3 0 -9.125 12 0 -8.4178933 11.2928933 0.05721178 GW 12 13 0 -8.4178933 11.2928933 0 -1.7620476 9.125 0.05721178 GW 13 3 0 -11.125 12 0 -11.832107 12.7071071 0.05721178 GW 14 13 0 -11.832107 12.7071071 0 -18.487952 14.875 0.05721178 GW 15 3 0 -11.125 12 0 -11.832107 11.2928933 0.05721178 GW 16 13 0 -11.832107 11.2928933 0 -18.487952 9.125 0.05721178 GW 17 3 0 -9.125 -12 0 -8.4178932 -11.292893 0.05721178 GW 18 13 0 -8.4178932 -11.292893 0 -1.7620476 -9.125 0.05721178 GW 19 3 0 -9.125 -12 0 -8.4178933 -12.707107 0.05721178 GW 20 13 0 -8.4178933 -12.707107 0 -1.7620476 -14.875 0.05721178 GW 21 3 0 -11.125 -12 0 -11.832107 -11.292893 0.05721178 GW 22 13 0 -11.832107 -11.292893 0 -18.487952 -9.125 0.05721178 GW 23 3 0 -11.125 -12 0 -11.832107 -12.707107 0.05721178 GW 24 13 0 -11.832107 -12.707107 0 -18.487952 -14.875 0.05721178 GW 25 3 0 -9.125 -4 0 -8.4178932 -3.2928932 0.05721178 GW 26 13 0 -8.4178932 -3.2928932 0 -1.7620476 -1.125 0.05721178 GW 27 3 0 -9.125 -4 0 -8.4178933 -4.7071067 0.05721178 GW 28 13 0 -8.4178933 -4.7071067 0 -1.7620476 -6.875 0.05721178 GW 29 3 0 -11.125 -4 0 -11.832107 -3.2928929 0.05721178 GW 30 13 0 -11.832107 -3.2928929 0 -18.487952 -1.125 0.05721178 GW 31 3 0 -11.125 -4 0 -11.832107 -4.7071067 0.05721178 GW 32 13 0 -11.832107 -4.7071067 0 -18.487952 -6.875 0.05721178 GW 33 7 0 -11.125 4 0 -11.125 0 0.05721178 GW 34 7 0 -11.125 0 0 -11.125 -4 0.05721178 GW 35 7 0 -9.125 4 0 -9.125 0 0.05721178 GW 36 7 0 -9.125 0 0 -9.125 -4 0.05721178 GW 38 33 -4 -20.125 15.5 -4 -0.125 15.5 0.1875 GW 39 33 -4 -20.125 11.5 -4 -0.125 11.5 0.1875 GW 40 33 -4 -20.125 7.75 -4 -0.125 7.75 0.1875 GW 41 33 -4 -20.125 3.875 -4 -0.125 3.875 0.1875 GW 42 33 -4 -20.125 -3.875 -4 -0.125 -3.875 0.1875 GW 43 33 -4 -20.125 -7.75 -4 -0.125 -7.75 0.1875 GW 44 33 -4 -20.125 -11.5 -4 -0.125 -11.5 0.1875 GW 45 33 -4 -20.125 -15.5 -4 -0.125 -15.5 0.1875 GW 46 33 -4 -20.125 0 -4 -0.125 0 0.1875 GW 47 5 0 -11.125 12 0.3072 -10.625 9.33333333 0.05721178 GW 48 5 0.3072 -10.625 9.33333333 0.3072 -9.625 6.66666667 0.05721178 GW 49 5 0.3072 -9.625 6.66666667 0 -9.125 4 0.05721178 GW 50 5 0 -9.125 12 -0.3072 -9.625 9.33333333 0.05721178 GW 51 5 -0.3072 -9.625 9.33333333 -0.3072 -10.625 6.66666667 0.05721178 GW 52 5 -0.3072 -10.625 6.66666667 0 -11.125 4 0.05721178 GW 53 5 0 -9.125 -4 -0.3072 -9.625 -6.6666667 0.05721178 GW 54 5 -0.3072 -9.625 -6.6666667 -0.3072 -10.625 -9.3333333 0.05721178 GW 55 5 -0.3072 -10.625 -9.3333333 0 -11.125 -12 0.05721178 GW 56 5 0 -11.125 -4 0.3072 -10.625 -6.6666667 0.05721178 GW 57 5 0.3072 -10.625 -6.6666667 0.3072 -9.625 -9.3333333 0.05721178 GW 58 5 0.3072 -9.625 -9.3333333 0 -9.125 -12 0.05721178 GW 59 3 0 11.125 4 0 11.8321068 4.70710678 0.05721178 GW 60 13 0 11.8321068 4.70710678 0 18.4879524 6.875 0.05721178 GW 61 3 0 11.125 4 0 11.8321067 3.29289331 0.05721178 GW 62 13 0 11.8321067 3.29289331 0 18.4879524 1.125 0.05721178 GW 63 3 0 9.125 4 0 8.4178933 4.70710709 0.05721178 GW 64 13 0 8.4178933 4.70710709 0 1.7620476 6.875 0.05721178 GW 65 3 0 9.125 4 0 8.4178933 3.29289331 0.05721178 GW 66 13 0 8.4178933 3.29289331 0 1.7620476 1.125 0.05721178 GW 67 3 0 11.125 12 0 11.8321068 12.7071068 0.05721178 GW 68 13 0 11.8321068 12.7071068 0 18.4879524 14.875 0.05721178 GW 69 3 0 11.125 12 0 11.8321067 11.2928933 0.05721178 GW 70 13 0 11.8321067 11.2928933 0 18.4879524 9.125 0.05721178 GW 71 3 0 9.125 12 0 8.4178933 12.7071071 0.05721178 GW 72 13 0 8.4178933 12.7071071 0 1.7620476 14.875 0.05721178 GW 73 3 0 9.125 12 0 8.4178933 11.2928933 0.05721178 GW 74 13 0 8.4178933 11.2928933 0 1.7620476 9.125 0.05721178 GW 75 3 0 11.125 -12 0 11.8321068 -11.292893 0.05721178 GW 76 13 0 11.8321068 -11.292893 0 18.4879524 -9.125 0.05721178 GW 77 3 0 11.125 -12 0 11.8321067 -12.707107 0.05721178 GW 78 13 0 11.8321067 -12.707107 0 18.4879524 -14.875 0.05721178 GW 79 3 0 9.125 -12 0 8.4178933 -11.292893 0.05721178 GW 80 13 0 8.4178933 -11.292893 0 1.7620476 -9.125 0.05721178 GW 81 3 0 9.125 -12 0 8.4178933 -12.707107 0.05721178 GW 82 13 0 8.4178933 -12.707107 0 1.7620476 -14.875 0.05721178 GW 83 3 0 11.125 -4 0 11.8321068 -3.2928932 0.05721178 GW 84 13 0 11.8321068 -3.2928932 0 18.4879524 -1.125 0.05721178 GW 85 3 0 11.125 -4 0 11.8321067 -4.7071067 0.05721178 GW 86 13 0 11.8321067 -4.7071067 0 18.4879524 -6.875 0.05721178 GW 87 3 0 9.125 -4 0 8.4178933 -3.2928929 0.05721178 GW 88 13 0 8.4178933 -3.2928929 0 1.7620476 -1.125 0.05721178 GW 89 3 0 9.125 -4 0 8.4178933 -4.7071067 0.05721178 GW 90 13 0 8.4178933 -4.7071067 0 1.7620476 -6.875 0.05721178 GW 91 7 0 9.125 4 0 9.125 0 0.05721178 GW 92 7 0 9.125 0 0 9.125 -4 0.05721178 GW 93 7 0 11.125 4 0 11.125 0 0.05721178 GW 94 7 0 11.125 0 0 11.125 -4 0.05721178 GW 96 33 -4 0.125 15.5 -4 20.125 15.5 0.1875 GW 97 33 -4 0.125 11.5 -4 20.125 11.5 0.1875 GW 98 33 -4 0.125 7.75 -4 20.125 7.75 0.1875 GW 99 33 -4 0.125 3.875 -4 20.125 3.875 0.1875 GW 100 33 -4 0.125 -3.875 -4 20.125 -3.875 0.1875 GW 101 33 -4 0.125 -7.75 -4 20.125 -7.75 0.1875 GW 102 33 -4 0.125 -11.5 -4 20.125 -11.5 0.1875 GW 103 33 -4 0.125 -15.5 -4 20.125 -15.5 0.1875 GW 104 33 -4 0.125 0 -4 20.125 0 0.1875 GW 105 5 0 9.125 12 0.3072 9.625 9.33333333 0.05721178 GW 106 5 0.3072 9.625 9.33333333 0.3072 10.625 6.66666667 0.05721178 GW 107 5 0.3072 10.625 6.66666667 0 11.125 4 0.05721178 GW 108 5 0 11.125 12 -0.3072 10.625 9.33333333 0.05721178 GW 109 5 -0.3072 10.625 9.33333333 -0.3072 9.625 6.66666667 0.05721178 GW 110 5 -0.3072 9.625 6.66666667 0 9.125 4 0.05721178 GW 111 5 0 11.125 -4 -0.3072 10.625 -6.6666667 0.05721178 GW 112 5 -0.3072 10.625 -6.6666667 -0.3072 9.625 -9.3333333 0.05721178 GW 113 5 -0.3072 9.625 -9.3333333 0 9.125 -12 0.05721178 GW 114 5 0 9.125 -4 0.3072 9.625 -6.6666667 0.05721178 GW 115 5 0.3072 9.625 -6.6666667 0.3072 10.625 -9.3333333 0.05721178 GW 116 5 0.3072 10.625 -9.3333333 0 11.125 -12 0.05721178 GW 1000 5 -1.5 -1.25 -14.75 -1.4999995 1.25 -14.75 0.045371 GW 1003 1 -1.4999995 1.25 -14.75 -1.25 1.25 -14.75 0.05721178 GW 1004 1 -1.5 -1.25 -14.75 -1.25 -1.25 -14.75 0.05721178 GW 1005 3 0 11.125 0 -0.9999998 11.1250086 0 0.05721178 GW 1006 3 0 9.12499824 0 -0.9999 9.10978141 0 0.05721178 GW 1007 3 0 -9.125 0 -1 -9.125 0 0.05721178 GW 1008 3 0 -11.125 0 -1 -11.125 0 0.05721178 GW 1009 9 -1 -11.125 0 -1.1369963 -8.4139905 -4.049356 0.05721178 GW 1011 9 -1.3627339 -3.9610055 -10.70065 -1.5 -1.2500002 -14.75 0.05721178 GW 1012 13 -1.511996 -8.413995 -4.04935 -1.737734 -3.961005 -10.70065 0.0572118 GW 1014 1 -1.511996 -8.413995 -4.04935 -1.136996 -8.41399 -4.049356 0.0572118 GW 1015 1 -1.737734 -3.961005 -10.70065 -1.362734 -3.961005 -10.70065 0.0572118 GW 1016 9 -1 -9.125 0 -1.1369963 -6.4139905 -4.049356 0.05721178 GW 1017 9 -1.5 -1.5215514 -10.739498 -1.4999995 1.25 -14.75 0.05721178 GW 1018 13 -1.481954 -6.266946 -4.047133 -1.738806 -1.806844 -10.69254 0.0572118 GW 1019 1 -1.481954 -6.266946 -4.047133 -1.136996 -6.41399 -4.049356 0.0572118 GW 1020 1 -1.738806 -1.806844 -10.69254 -1.5 -1.521551 -10.7395 0.0572118 GW 1038 9 -0.9999 9.10978141 0 -1.1699612 6.31694603 -3.9920945 0.05721178 GW 1040 9 -1.1823972 1.55442342 -10.762988 -1.25 -1.25 -14.75 0.05721178 GW 1041 13 -1.437782 6.16597 -4.206811 -1.557289 1.5596016 -10.75563 0.0572118 GW 1042 1 -1.169961 6.316946 -3.992095 -1.437782 6.16597 -4.206811 0.0572118 GW 1043 1 -1.182397 1.5544234 -10.76299 -1.557289 1.5596016 -10.75563 0.0572118 GW 1044 9 -1 11.125009 0 -1.067962 8.413188 -4.050555 0.0572118 GW 1046 9 -1.1819999 3.96181678 -10.699438 -1.25 1.25 -14.75 0.05721178 GW 1047 13 -1.442925 8.4161204 -4.046175 -1.557 3.9618117 -10.69945 0.0572118 GW 1048 1 -1.067962 8.413188 -4.050555 -1.442925 8.4161204 -4.046175 0.0572118 GW 1049 1 -1.182 3.9618168 -10.69944 -1.557 3.9618117 -10.69945 0.0572118 GS 0 0 0.0254 ' All in in. GE 0 EK LD 5 0 0 0 3.77e7 0 EX 0 1000 3 0 1 0 GN -1 FR 0 1 0 0 470 0 RP 0 1 73 1510 90 0 1 5 0 0 The U4000, however is an excellent deal for the money at $27.50.
#78 |
Location: SW Michigan, http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d1dda0093f11cf4
300ohms, re: Posting 65:
> Ill post the charts of what is theoretically possible by ganging up two U4000s in their present positions of the U8000 (which actually looks good because no serious lobes are produced). Ill do this by eliminating the phasing lines and putting 2 excitation sources into the NEC file. < Is there some reason that the F/B graphs are all flatlined at 0? That would imply that it was done w/o reflectors, but the NEC file shows the rods are defined there. > From the above results, you have to subtract estimated losses from the 2 baluns and the 2 way splitter. < It seems like splitter/combiner losses would negate most of the gains. Would it not be possible to redesign the phasing harness for better performance instead? The existing harness actually looked rather clever to me, though apparently it did seriously degrade the end result. |
#79 | ||
A simpler lower loss solution for horizontally stacked antennas is to use the Winegard SD3700 300ohm to 75ohm outdoor coupler. Its downside is its about $20 - $25.
#80 |
In an earlier post, 300ohm, you modeled very good gain on VHF-HI by connecting the reflector rods,
Could the same increased VHF-HI gain hold true for a similarly modified Winegard HD8800 ? (This would be important for people try) |
#81 | |
If youre willing to sacrifice some uhf gain for vhf-hi gain, moving the reflector to bowtie distance out to about 13" to 15" helps. Exact distances will have to be modeled per antenna design. On my tweaked Baltimore closed end bowtie antenna, I got a good 7 dbi vhf-hi gain for ch 11 and 13, and almost 16 dbi channels 38 to 46, reflector to element distance of 14", 40" by 40" curved reflector, 2" X 4" mesh, center mesh 1/2". The wide reflector concept does NOT work for the GH, hence the need for NARODs.
#82 |
That's cool, good to know also. Doesn't the CM4228HD have continuous reflector, this mod on the U8000, or HD8800 would put it well ahead of the CM4228, on VHF-HI, correct ? or am I missing something...
How much worse is the split reflector VHF-HI gain as is, none ? |
#83 | |||
#84 |
OK, so the reflector on the CM4228 interacts differently with the bow-ties, compared to the U8000 design, talking in terms of VHF-HI
Would it be a relatively easy, and reversible mod to backup the reflector on the CM4228, or any of the double bays |
#85 | |
But Ive tried to put smaller uhf reflectors in front of larger vhf-hi refectors, spaced at the correct distances, like in the case of loops, with pretty poor results, if thats what you mean.
#86 |
Location: Calgary - Shaw phone & internet, 4 bay OTA in attic / Pigeon Lake - CCI Wireless, 8 bay OTA on roof
I never did connect the reflector rods on my U8000.
Is there a recommended quick and dirty reversible method? I was thinking of just reusing some 14 gauge aluminum wire to bridge the gap and wrapping it onto the reflector ends with aluminum foil tape. If the weather holds next week I might make a last trip up on the roof of the cabin. |
#87 |
I adjusted the model on the HD8800 (different antenna) to see if the result would be similar to U8000 for connected reflector rods, and it did NOT help on VHF-HI in this case
