Fraser Johnston Furnace ? - Canadian TV, Computing and Home Theatre Forums
Old 2010-09-22, 03:14 PM   #1
AMQ-YTZ
Default Fraser Johnston Furnace ?
Hi - I'm in the process of getting quotes for a true modulating furnace. Has anyone worked on a Fraser Johnston before ? It seems that they are manufacterd by the folks that bring us York and LuxAire.
I have quotes for Rheem/Ruud - but have not been able to find much info on the Fraser Johnston model TCP060D12MP.
Thanks,
amQ
AMQ-YTZ is offline
Old 2010-09-26, 04:17 AM   #2
txv
http://www.fraser-johnston.ca/Home_AboutUs.aspx
It's basically a york, but the model number doesn't look right.
WARNING: The HVAC information I provide is not based on field experience and DOES NOT constitute professional advice.
txv is offline
