Has anybody here had success hooking up a SlingBox with the 530?
I did have it hooked up successfully with a 505, but the 530 will not accept commands for the 505 or 530 internal SlingBox settings. MOD: Feel free to move to HTPC forum if necessary. |
probably check for a sling forum and see watcha get...
I have a Slingbox AV(?) hooked up for 3+ yrs to my 530..... no problems.... Peter PS. Make sure you are set to the default remote on your 530? Maybe that's the answer.... (did you change the IR/radio settings from default so it wouldn't interfere with your 505?)
Panny 47wx52, DMR-e80*C DSR500x2, XBOX 360, Toshiba 26hf84, LG 37LC2D Last edited by Petee_C; 2010-08-19 at 03:12 PM. Reason: added ps |
Slingbox PRO HD works well on my 530
Go HABS Go! Go MAVS Go! JVC RS-40 on a 128" screen. WOW! |
Figured it out, and putting it here for future searches...
Options 6,4,3,2 Make sure you remote control code address is 0000. |
That's the only way I could make my 505 work with a Harmony remote.
Harmonies will work with other SD addresses
You have to do a little work though. |
