I thought its 200 Gb a month? Ethier way I am having it set up this weekend. I can provide results as well. (currently i have primus DSL)
You're right - 200 Gig. And cheaper then Rogers...
Let's hope it works well. Curiously, I just repeated that ping test & got an "A" this time. |
I switched about a month ago and the connection speed is about the same. I did have a delay of about 4 days getting it activated after my Rogers internet was disconnected. I had to keep calling everyday to get a status from TekSavvy, and all they could do was keep emailing Rogers to ask them to switch me. No Rogers tech had to come out as I was an existing cable internet customer who owned my own modem.
Here are my results from those servers: ![]()
out of curiousity, does teksavvy then use the same modem as rogers? i purchased the rogers modem a couple years ago and just curious in case i ever decide to switch. look forward to your reviews.
#6 | |
List of Approved Modems: * Joohong - SL-2810 - 29.2 * Toshiba - PCX2600 - 19.0.0 * Toshiba - PCX2600 - 19.0.1 * Motorola - SB5100 - 3 * Motorola - SB5101 - 1 * Motorola - SB5101N - 1 * Motorola - SB5120 - 4 * SA - DPC2100 - 1.1 * SA - DPC2100r2 - 2.1 * SA - DPC2325 - 1 * SA - DPX2100 - 1.1 * SMC - SMC8004-BCM - 1.A * SMC - SMC8013WG-RCR - 1C * SMC - SMC8013WG-RMR - 1C * SMC - SMC8014WG-RMR - 1.B * SMC - SMC8014WG-SI - 1.A * SMC - SMCD3GN - 1.A * Terayon - ECM715 - 3 * Terayon - ECM715 - 7/3.2 * Terayon - ECM715 - 7/3.3 * Terayon - TJ715x - 10 * Terayon - TJ715xHP - 14 * Thomson - DCM325 - 1.7 * Thomson - DCM425 - 4 |
#7 | |
Last edited by Cyclism; 2010-08-06 at 10:11 AM. Reason: Removed unnecessary quote. |
Speedboost. It skews speed tests. Some parts of Rogers' territory has it, Toronto and the surrounding areas being one of them.
#9 |
Skews meaning it's not REALLY faster? If you don't mind explaining I'd be curious to know how it works. I don't see how it could get around the "absolute" bottleneck imposed by the provider - but if it does I'd love to know
Edit: I'd thought this was something people install on their pc - but your note implies it's at the provider end - if so how would I know what speed I'm really getting? |
#10 |
Speedboost is a 10 seconds or so boost to the start of your transfers. It essentially makes loading web pages faster.
The best way to check your speed is to download a large file (you can cancel the download after a minute if you're tight with your cap space) from a large company like Microsoft (so that you know the server can transfer at high speeds) and see at what speed the download settles after a bit. |
#11 |
Right. Every since Rogers enabled speedboost a few months back it has skewed speedtest.net results. I do see close to 10Mb/s sustained on large downloads after the speedboost ends.
#12 |
so the rogers tech came and set up my line. too bad they didn't provision my modem yet...
called techsavvy and they said this is a common issue. so i will need to wait 1-2 days for the service ticket to run its course. |
#13 |
#14 |
Thanks for the explanation. I'll download SP3 or something from Microsoft & post those results too for the right before/after picture. My Rogers > TekSavvy switch isn't for another week or so - Rogers insisted on a month's notice.
I hope speedtest.net & others adjust their tests to account for speedboost...otherwise it's not obvious if you're really getting the sustained speeds you're paying for. |
#15 |
So I'm getting max 509 KB/Sec downloading SP3 from Microsoft.
I'm quite unsure of this math - but; - 509 KB/Sec (think this is Bytes not Bits) - multiple by 8 to get Bits/Sec gives 4,072 K Bits/Sec - which can be expressed as 4 MegaBits/Sec So am I only getting 4 Meg down or what? |
