Cell Antenna Booster? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Smartphone and Tablet Computing including Android, Blackberry and iOS devices
Old 2010-08-03, 10:28 PM   #1
KingBuzzo
Default Cell Antenna Booster?
Hi Fellas:
The outlaws built a new house in the sticks with a steel roof and now their 'dumb' phones don't work!
Do you have any recommendations on a booster they could mount outside that would work on both MTS and Telus networks (CDMA)?
Also, is it possible to be on both GSM and CDMA?
Thanks!
KingBuzzo is offline
Old 2010-08-03, 11:12 PM   #2
BGY11
Just to clarify, do their phones manage to get some signal right in front of their home (or near a window)? A signal booster won't do anything if it can't get a signal to begin with.
I'm not sure of any reliable signal boosters myself, but hopefully some other DHC members have an idea where to look.
BGY11 is online now
Old 2010-08-05, 01:56 AM   #3
TorontoColin
Check out JDTeck for cellular signal repeaters. I've ordered one for AWS, but I can't tell you how effective it is because it hasn't arrived yet.
TorontoColin is online now
Old 2010-08-09, 02:09 PM   #4
KingBuzzo
yesh, they get a signal outside of the house but not inside...
Old 2010-08-09, 02:11 PM   #5
KingBuzzo
ok, let me know how that goes...one of their carriers wants $500 for their booster - that seems ridiculous to me...
I found a used on kiij but it only works on the 1900MHz band - I'm not sure if that would work for thier carriers to be sure...
Old 2010-08-15, 05:23 PM   #6
BlueMan1
Suggest checking Dual Band Cellphone Boosters manufactured by Wilson Electronics. Several models available.
We get 1 bar of signal strength (outside of cottage))and with the desktop version we get as much as 6 bars (when located near inside antenna).
Easy installation.
BlueMan1 is offline
Old 2010-08-15, 08:56 PM   #7
peth
Can also recommend a Wilson dual band, use on every day.
peth is offline
