as of late I haven't been able to play the latest MKV files people are making,
I've been reading and it has from what I can tell is has something to do with a new program being used, depending on what you use, lots of people have audio issues, watching in on their computer, my PS3 won't play it at all, anybody heard of this, or know of a solution, for streaming, I've been told to download a new player but that doesn't help me get it to my big screen, I want to be able to stream through my PS3 Thanks, Steve
Panasonic 65" GT30, 5.1 Klipsch, Onkyo Receiver,Gateway, HD PVR, Xbox 360, PS3, |
ill try mine out tonight, but i have been using Vuze now for along while now. might be worth looking into
Licenced HVAC TECH: "Without seeing your problem i can only offer suggestions, no warranty is included with my advice" |
if you are downloading, its any files with "immerse" in the torrent,
starting with last weeks episodes
Yes I have found that to be an issue with all immerse releases recently. I used another DL and it worked fine. I read that if you re-mux? the audio you can get it to work.
