Unlocked Cell Phone Discussion - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Smartphone and Tablet Computing including Android, Blackberry and iOS devices
Old 2010-07-30, 11:01 AM   #1
BGY11
Default Unlocked Cell Phone Discussion
Recently there have been several threads that have turned into a discussion of carrier-unlocked cell phones, and the benefits & drawbacks of buying an unlocked handset. To help consolidate this information and make searching easier, I've decided to create a single thread where DHC members can discuss this topic.
BGY11 is online now
Old 2010-07-30, 12:20 PM   #2
JamesK
One comment I've heard about locked phones is long delays in getting updates. A friend has the Motorola Milestone and I believe she's still stuck on Android 2.0. A few months back, there was some discussion here about Rogers locked HTC Dream & Magic being stuck at 1.x, even though 2.x was available for the same phone from elsewhere. If the carriers sell locked phones, then they should be required, by law, to remove the lock at the end of the contract period.
JamesK is online now
Old 2010-07-30, 01:05 PM   #3
TorontoColin
Software updates aren't related to carrier locks so much as they're connected to carrier branding. Even if Rogers were to unlock a phone it would still need the Rogers software update.
Personally I feel carriers shouldn't be able to lock phones purchased outright or at the very minimum the packaging should be required by law to state explicitly that it is carrier locked.
TorontoColin is online now
Old 2010-07-30, 01:11 PM   #4
jvincent
Following up to TorontoColin, there is also a subtle difference for Android phones running custom ROMs.
Before the official 2.2 came out for the Nexus One many people, me included, were running pre-release versions. When the OTA update came out the build was not recognized so we had to wait for a custom ROM that had the new source.
Not a big deal, but worth noting.
Android rocks!
jvincent is online now
Old 2010-07-30, 02:01 PM   #5
David Susilo
can't agree with you more. Furthermore, the company should also de-brand the phone after the end of the contract.
THX, ISF, Control4 Certified Professional; CEDIA Trainer
David Susilo is offline
Old 2010-07-30, 02:29 PM   #6
timlocke
For GSM phones I suspect that any Chinese Mall around TO will unlock a phone for $10-20. I have no idea about the problem with carrier BRANDING and s/w updates.
timlocke is online now
Old 2010-07-30, 02:44 PM   #7
David Susilo
You can unlock most GSM phoines for $5 thru e!ay
Old 2010-07-30, 03:22 PM   #8
jshel101
Why should the consumer have to pay a 3rd party company to unlock their phones when their provider should be doing this free of charge. If I buy a phone on contract. When that contract expires, I own the phone outright. They should be sending me the unlock code if I request it.
jshel101 is offline
Old 2010-07-30, 03:50 PM   #9
TKG26
By unlocking my phone(myself with the help of ppcgeeks) i was able to run custom windows roms on my phone. A phone loaded originally with WM6.1 and telus bloatware. Turned into a WM6.5 and then to a heavily tweeked WM6.5.XX with various versions of htc sense .. IT brought new life to my phone after being bored with it a year and a bit later. I also have android running on it.... The lock can prevent you from doing this, and well your warranty would be void im sure as well..
Basically unlocking and rooting your phone gives you options to run the latest software and roms..
Licenced HVAC TECH: "Without seeing your problem i can only offer suggestions, no warranty is included with my advice"
TKG26 is online now
Old 2010-07-30, 04:01 PM   #10
BGY11
Unlocking a phone refers to enabling the phone to work on another carrier's network. De-branding a phone means removing carrier-supplied software (and with smartphones, generally means installing custom roms).
BGY11 is online now
Old 2010-07-30, 04:14 PM   #11
TKG26
pretty sure i can make it work on another carrier. I just have to run the appropriate cab files..
TKG26 is online now
Old 2010-07-30, 09:13 PM   #12
recneps77
Unlocked phones (phones purchased unlocked from the mfr, not from a carrier and then unlocked)
Benefits:
-choose any carrier you wish (provided hardware + frequency matches)
-use the default manufacturer's version of the OS = faster updates (e.g. Nexus One and Android 2.2 has been out for weeks, while many people are still stuck with 2.1)
-All features of the phone are available - phone companies like to disable certain features when providing their own version of the OS (usually to charge for you to use them, or because they take too much out of the company profit)
-Usually cheaper if you can get a lower monthly rate for 3 years vs a "free" phone and a higher monthly rate for 3 years.
Drawbacks:
-Large sum of money up front, vs 3-year financing (though see the last point above)
-Often no monthly-plan discount for buying a phone outright (though if you use a carrier that doesn't do monthly phone subsidies, you get the lowest rate regardless of phone - e.g. Wind or Mobilicity)
-Your warranty is with the manufacturer, whereas a locked, carrier-specific phone may be warranted by the carrier (and may be an instant swap in-store, should you have issues vs. send the phone to manufacturer to be fixed and wait)
-No "free" upgrade after x years.
That's my take on the matter.
For the record (in case there's any bias ), I have an unlocked phone and a service plan with a company that doesn't offer phone subsidies (Wind).
recneps77 is offline
Old 2010-07-31, 08:01 AM   #13
TKG26
by unlocking my diamond i am now able to share internet conection though the usb and setup a wifirouter.
TKG26 is online now
Old 2010-07-31, 10:06 AM   #14
jimmyfogg
@ TKG26: That's 'rooting' or 'jailbreaking' your phone. Unlocking refers to being able to use your phone on any carrier, while the two go hand in hand, they are not the same.
jimmyfogg is offline
Old 2010-07-31, 04:24 PM   #15
TKG26
oops sorry. Unlocking was probably the first step i did... sorry for the bad info.
TKG26 is online now
