New home set up - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Home Theatre Corner > Home Theatre Construction
Old 2010-07-22, 05:12 PM   #1
ragweed
Default New home set up
Hi Guys , just stumbled accross this site, looks like a ton of info here. looks great !!
I have a couple of questions, first history and what I am doing ;
New home contructed and just moved in , did not really know what I needed at each part of the house so I ran a boat load of cat 5E to all areas of the hous back to a central location (work room), RG 6 to roof (Sat.)
I have just moved in and would like to start getting a little signal (tv, internet ect through out house.) .
I plan on putting a switch in the control room, then disperse internet through out house. My question is HDMI signal accross cat5 e , I have done a little
(very little) research, came up with cat5E hdmi baluns @ around $125/set . is this the best/cheapest way to go ?? also better brands than others ??
any help would be appriciated
thanks
Ragweed
ragweed is offline
Old 2010-07-22, 05:18 PM   #2
MarcP
Yikes... $125 is a lot. Check with Monoprice. I can't provide a link, but it's less than half of that.
MarcP is offline
Old 2010-07-22, 06:20 PM   #3
ragweed
yes I forgot about "Monoprice", $35 each
ragweed is offline
