Personal Opinions:50" 3d plasma or 54" non-3d - Canadian TV, Computing and Home Theatre Forums
Old 2010-07-19, 11:27 PM   #1
Renegade
Default Personal Opinions:50" 3d plasma or 54" non-3d
Given budget constraints if you were to buy a tv today would you take a smaller 3d plasma or a larger non-3d.
More specifically, 54" S2 or 50" samsung c7000.
Renegade is offline
Old 2010-07-20, 12:48 AM   #2
cooper83
Larger non-3D TV.
Panasonic TH-42PE7U plasma, Toshiba HD-D3, PS3, Shaw DCX3400, Yamaha HTR-6160, Polk 6.1, Belkin PF30, Harmony 700
cooper83 is offline
Old 2010-07-20, 03:58 AM   #3
eimaj
+1 to coopers comment.
tech junkie, but recently it's been junkie tech
eimaj is offline
Old 2010-07-20, 08:32 AM   #4
idrive
+2 with Cooper
We got a non-3D 54" Pany just after x-mas and we just loooooooove it !
Sharp LC-70LE640U /Yamaha RX-V373 / Explorer 8642HD / PS3 Fat upgraded to 320 Gb
idrive is offline
Old 2010-07-20, 08:33 AM   #5
nursedude
^^^ Ditto. Until there is more programming and better viewing options that don't include getting special glasses that cost $$ 3D tv will probably not take off to the extent it's worth the premium. I, personally, am waiting for holographic TV to be developed.
nursedude is offline
Old 2010-07-20, 03:13 PM   #6
Airsculpture
Location: Fredericton NB, Panasonic TC-P50G25 & TC-P42G25, Pioneer 9140TXH, Sony BDPS580, PS3
Always wondered why they don't put whatever is in the glasses on the screen so no-one has to wear the goggles ?
Airsculpture is offline
Old 2010-07-20, 03:20 PM   #7
MarcP
I'm skipping 3D until there's an actual standard where 3D glasses can be used with 3D TVs from any manufacturers. Right now, the glasses you get only work for the TV you purchased and you have only one source to buy additional/replacement glasses.
MarcP is offline
Old 2010-07-20, 03:30 PM   #8
eljay
Premium Supporter
Add one more vote for "larger non-3D TV".
MY HT SET-UP (PICS & GEAR LIST)
eljay is offline
Old 2010-07-20, 03:39 PM   #9
753951
No competition. Go with larger 2D set.
753951 is online now
Old 2010-07-20, 04:50 PM   #10
reidw
Default Stick With 2D
Yep. Get the larger 2D HD set. 3D is still too new/buggy to be taken seriously. If it is still around in three/four years you can get a much better 3D set then. There's no rush.
reidw is offline
Old 2010-07-20, 10:03 PM   #11
Renegade
thanks for all the responses, it's pretty clear what the consensus is. I was leaning toward the larger non-3d initially then started getting temped to go 3d...thanks for confirming my original thoughts and helping set me straight....sometimes a little confirmation from others helps
Renegade is offline
Old 2010-07-23, 12:52 PM   #12
arminia
On AVS forum the consensus seems to be that the 3D VT series is also the best 2D tv out there.
arminia is offline
Old 2010-07-24, 12:05 PM   #13
stationg
Mine makes a buzz/hummm sound. Apparently plasma's do this. The PQ on this set is outstanding. I hope I can get the buzz/humm thing sorted out. I sit 6ft from the TV.
Good luck
Gateway, Yamaha Receiver, 58" Panasonic 3D TV, Xbox360, PS3, Panasonic 3D Bluray Player, Definitive Speakers, SVS Sub
stationg is offline
Old 2010-07-29, 04:27 PM   #14
TooSmooth
These exist, but you would need to sit straight infront of the TV (similar tech is in the new 3ds)
TooSmooth is offline
