I currently have a receiver in my living room, that I would like to ditch and run my living room setup off Zone 2 on my theater room/bar downstairs,
my problem is controlling it, my receiver downstairs has a plug that says "zone 2 control IR in" or something like that, (onkyo tx-sr602) what do I need to get so I can control volume and source from my living universal remote, I've seen kits with external receivers and emitters for controlling in cabinet setups, but my setup is open and I don't want to mount an emitter on the front of my receiver hope that makes sence, Thanks,
Panasonic 65" GT30, 5.1 Klipsch, Onkyo Receiver,Gateway, HD PVR, Xbox 360, PS3, |
What you want is a remote extender or RF remote that uses emitters that plugin to a base station. Since your receiver has an IR input you don't need to use an emitter but instead connect a cable from the base station to the IR input. The base station will typically have a 2.5mm or 3.5mm mono jack and your receiver most likely has a 3.5 mm jack. It's easy to find a cable to patch them together.
You've got lots of options, especially if you want to go the universal remote route. What budget did you have in mind? |
#3 | |
I would like to use my shaw remote with it, if possible,
