#46 | |
Just following up on my post from last month.
Long story short. It's now routed from the Optik box to my receiver (Pioneer) and then to the Sharp (Input 4 with the ARC). No handshake or audio sync issues and has been up for the last 2 weeks. I think case closed on my end. No a different note. A few days ago, on a different TV, the audio did cut out but video was coming through with no problems. After flipping back and forth with inputs, audio settings, etc - it turns out the HDMI cable was just slightly loose at the back of the Telus box. After jiggling it a bit, audio returned. I guess with an HDMI connection, audio is the most sensitive? (first to go in the HDMI pecking order?). Anyways, thought I would throw that out there as a potential quick (cheap) fix for those experiencing some audio problems. |
#47 |
I had my TELUS TV upgraded this weekend to OPTIK also. I too had to "downgrade" from HDMI to Component cables from the PVR to the receiver in my living room as there was no video but audio was fine during installation (I still have HDMI from the receiver to the TV though).
Interestingly, the other 2 tv sets still work just fine with an HDMI from the set-top boxes to the TVs. The TELUS tech wanted to change all 3 sets from HDMI to Component as "there are problems with OPTIK and HDMI cables" but agreed to leave the 2 as they worked with their current HDMI (with my old TELUS TV set-up, I never had any issues with any of the TVs or the HDMI cables). |
#48 |
I couldn't get HDMI to work between my PVR and TV until I went an bought some new HDMI 1.4 "High Speed" cables. I have no idea what the other cable I was using was rated for, and whether 1.4 is necessary, but since they were only $10 I grabbed a few of them and they all work great.
I think the "problem" Telus is claiming with HDMI is that they don't want to supply "quality" HDMI cables. Much cheaper and easier to supply some component cables instead. |
#49 |
I will give that a try tomorrow. I have 1.4 HDMI cables from the Blu-ray into the receiver and from the receiver into the TV but had an older HDMI cable from the PVR into the receiver. I will do some switching around and see what happens.
#50 |
For what it's worth, I have a Pioneer AVR and have HDMI from the Cisco 430 to the Pioneer. What happens usually is if I switch from HD channel to SD or play an SD recording after watching HD channel, I won't have sound from the AVR. If I switch the AVR to BD or DVD, then back to TV, it restores the sound.
#51 | |
There is a reason and its quite simple. HDMI is a nonstandardised connection format, that means it has no standard in the IEEE, MPEG group set up HDMI and it is a combination of DVI and the digital audio data combined in one cable format,. The problem is there are multiple variations of HDMI manufatured by various providers, not all are 100% compatible with each other. Things like picture degradation, digital distortion, black pixels appearing randonmly (pixelization) and audio issues are not uncommon, especially with older HDMI equipment. There were alot of problems with HDMI that were experienced with the previous IPTV service from TELUS called Minerva, during that time it was determined that TELUS would not support HDMI, and instead chose to provide component for video and optical for audio. This provided a resolution of 720p or 1080i and 5.1 surround without the HDMI issues. I set up all my customers with component and optical and I leave them HDMI cables. if they change the cables to HDMI and have no problems, fine. If they have problems I ask them to go back to the way I left it, and NOT to call TELUS as HDMI is NOT supported. FYI, I use the TELUS HDMI cables on my Bravia passing through a Denon from a 330 and everything is fine. Hope this clarifies things a little - another TELUS tech |
#52 |
So, I get that Telus doesn't officially support HDMI on Optik.
I understand that for 3D television on Optik you are required to use HDMI. Seems like a conflict to me. |
#53 |
I'm thinking about getting a 23 or 24" LED computer monitor that has HDMI input to use as my primary TV and computer display, as an alternative to upgrading my old non-HD TV, and wondering if the HDMI connection will work with my Telus 430 PVR box. Has anyone tried Telus HDMI to a computer monitor?
This could save me a fair bit of cash because then I could avoid the expense of a new TV, TV cabinet, and sound system, and it could save some space as I'm moving to a smaller place. I would use another port on the LED monitor for my computer, and I could use my 2.1 computer speakers for TV. I already use a 22" LCD monitor for occasional movie watching and it's not bad at all, for 1 or 2 people viewing. My understanding from this thread is that Telus does not guarantee that HDMI will work for all customer TVs etc because of slight differences in the HDMI capabilities of each TV, so HDMI may or may not work for a specific TV (or computer monitor). But component video should work for all TVs. The monitor does not have component video input. I'm thinking the only way to know for sure if HDMI works, is to buy the monitor and try it out. |
#54 |
It should work but how are you going to handle audio?
#55 |
@frank4, several people have used Mediaroom with a computer monitor. You will probably have to plug your computer speakers into the PVR using an RCA to PC audio cable. You can set up the remote to control the volume through the PVR. When the PVR is powered off, you will see the Telus screen saver on the monitor, so you will have to turn the monitor off manually.
Your PC monitor should be HDCP compliant, which I don't think will be a problem with a modern monitor |
#56 |
<bump>
Am looking to update my Telus TV setup here, currently running component video from the CIS430 PVR to TV and optical audio to an old 5.1 Rx. Considering upgrading the Rx to a new HK or Pioneer AVR unit. Would like to go all-digital but still seeing mixed reviews and switching issues going HDMI from the PVR. Is there any change TELUS support for HDMI? Anyone running it ok to an AVR? |
#57 |
I'm running Optik on an Xbox 360, with HDMI to a Pioneer AHK-1018 and then HDMI to a Sony LCD. No problems here, your mileage may vary.
99% of setups will work fine with HDMI, but if it doesn't then you'll have to switch to component/optical. |
#58 |
The XBOX 360 manages HDMI switching much more robustly than other devices, including the CIS boxes. It even has a function to "force" EDID info to the receiver so its does not have a choice but decode digital 5.1 audio.
The problem in my opinion is the way the receiver reads the EDID info and manages it. This is HDMI's achilles heel, HDCP has crippled HDMI to a large extent becasue of this problem. It's not Telus's fault per se, but it should have specified to Cisco that it needs a setting in the box to allow the forcing of EDID. |
| Tags |
| hdmi, optik, telus |
