I have recently purchased B&W CM9 front, CM5 surround, CC2 center, ASW-12 sub. Looking for A/V receiver in ~USD$2000 range to match the speakers. Any recommendations please. I am very confused with all the options available.
Thanks. |
#2 | |
Premium Supporter
Consider spending ~$1,200-$1,500 on a receiver to act as a processor, and then buying an Emotiva XPA-3 or XPA-5 (or even a UPA-5) to handle the power requirements.
MY HT SET-UP (PICS & GEAR LIST) |
Most receivers in that price range will probably have many features, but have a look at the following FAQ outlining AVR features to ensure you get what you need:
http://www.digitalhome.ca/forum/showthread.php?t=76082 Check out the following post, useful for those new to the forum - FAQs, Search Tips, Optimization, etc. http://www.digitalhome.ca/forum/showthread.php?t=57741 Are you located in the US? Please put your location in your profile, it helps us help you. I recently purchased a Denon AVR4310Ci and am quite happy with it. It's less than US$2k, but there are lots of options in that price range. As stated before, most AVRs in this price range will have the features you need, but will differ in their ergonomics, or sound nuances, or other small differences that can nag at someone spending this much. Some of the "less popular" brands have also had HDMI issues with some equipment... If it's power you want, the suggestion by eljay is a good one - using the AVR as a Pre-Pro and then purchasing a separate power amp, perhaps only for the fronts, or for 5-7 speakers
#4 | |
DHC Supporter
if your willing to pay for these speakers (assumming new @ retail) plus add
$ 2k (US) you can afford another $ 500 - $ 1000 (or whatever) ; unless your maxed out, than that's for another discussion on your end - maybe behind closed doors .. go separates. good multichannel amp with avr, or with dedicated av processor (now or later) Quote:
+1 to pharsyde's comments
Entry level to get the most of what these speakers can produce would be Cambridge Audio 650R or NAD 965. Good quality separates would give even better listening experience |
