#901 | |
You're probably right there.
SC: 8-Feb-02>21-Jul-09 (TFO) | EVu: 23-Jan to 03-Feb-07, back 20-Jun-09 Bell, French packages, pls! Long live OTA! |
#902 |
Yes, but you probably couldn't have CITY on 17 from HC and Global on 16 from CF (the towers are likely too far apart to use adjacent channels). Global would have to move to HC (assuming they could use 16 in the first place).
Link to my TVFool results is in my profile Homepage URL. I suggest others do the same. |
#903 |
Hi Guys. Just a note to mention that I am now getting the full 14 channel universe consistently here in Barrhaven with my new roof top CM 4221 antenna and CM 7778 pre-amp install.
Last edited by Jase88; 2012-05-15 at 11:04 PM. Reason: Edited out cross-posted details |
#904 |
Another update from Barrhaven...
I finally got around to installing an antenna in the attic of my 2 storey house and am happy to report that I am receiving 12 digital channels (all the local ones I believe - including Global). My setup includes a folded dipole made out of flexible copper tubing that is designed for channel 6 VHF (about 187 cm long and 15 cm high) aimed at Camp Fortune, with a straight run of coax directly to a TV on the main floor. No preamp, no splitters, etc. Signal strength is around 90% across the board, except for Global on channel 6.1 that is around 60%. I plan on trying some adjustments in aiming to see if I can improve on that. I had previously planned on adding the Mclapp4 9.5x9 4 bay bowtie antenna that I built (according to the specs here:http://m4antenna.eastmasonvilleweath...0Drawings.html ), but will hold off for now as it seems I wouldn't stand to gain anything - apart from a chance at PBS perhaps, but that seems unlikely with an attic installation. |
#905 |
Hello - I'm hoping for some pre-amp advice.
I have a DB4e that will be mounted on my roof, followed by 40ft of cable to a 3 way splitter, then another 10-20 feet of cable to the 3 TVs. Here is my tvfool report: http://www.tvfool.com/?option=com_wr...073ba5cfd8776a I plan to point the antenna at South Colton for WNPI. I should get HC no problem and also hoping to get CF off the back of the antenna. I'm choosing between a CM7777 & CM7778. I'm thinking the CM7777 provides too much gain and may be overloaded by the local stations. Any advice? Thanks! |
#906 |
regarding the cm7777 preamp I have been using one for about a year near Carling and Bronson with 10km to CF and 14 km to HC.
I have never had any issues with too much signal or preamp problems. I use good quality exterior antennas on a 2 storey house. Good luck |
#907 |
nocash you should also put the Antennas Direct CPA19 on your shopping list. With Ottawa going almost alll UHF except 13, this model is becoming attractive, at least in my mind.
#908 |
Appreciate the responses. Thank you.
I like the PA19 as well, it seems to resist signal overload particularly well. I was originally concerned with pulling in Global and wanted combined inputs....that obviously won't be required in the near future when they move (do we know when yet?). Is anyone using this pre-amp in Ottawa? Any success getting WNPI with it? |
#909 |
The PA19 covers both UHF and VHF
40-216MHz &400-700MHz
OTA, HD7697P, CM7778, Rotator, CM3218, TiVo, HDHomeRun Apple TV, Netflix, Teksavvy, Unblock-us, Wind, MagicJack |
#910 |
Yep. In the future I imagine i will be unplugging my VHF antenna in the attic and use the 8-bay on the roof for CTV Ottawa. Lots of people will no longer need to care about a dual input preamp. Now i can even consider a metallic roof.
#911 |
anyone in Munster?
i'm in the SE quadrant - so the highest i have ~50' unused tower to mount an antenna wondering what antenna you would recommend (preamp if required) i would like to get some US stations and not require a rotor if possible no ATSC tuner yet (PJ), so looking at DVR options, TiVo seems to be at the top mark TV Fool link http://www.tvfool.com/?option=com_wr...134932640e778e |
#912 |
Firstly, thanks to everyone for the great information provided here.
I'm new to OTA and would like to cancel Rogers in the coming weeks. I live in a detached house and have the option of an indoor antenna or outdoor. I tried a friend's indoor and received about 12 stations clearly. My TV Fool report is here: http://www.tvfool.com/?option=com_wr...1349e8764bb028 Questions as follows: 1. If sticking to an indoor antenna, what's my best bet? 2. If going to an outdoor antenna, how many more channels will I get? Which is the best antenna for my purposes? Thanks |
#913 |
I want to share my experiences with a home built OTA antenna. I live in a 2 story aluminum clad house in West Barrhaven near SEAS school. I started playing with this about 6 weeks ago. Today I have 15 high quality digital channels from an attic SBGH setup.
My tvfool at 20 feet is http://www.tvfool.com/?option=com_wr...13491120e8c632 First I tried an unamplified uhf/vhf rabbit ear from The Source. Placed in a 2nd floor bedroom, near a window facing Camp Fortune, I was able to pick up about 5 digital channels. I moved this antenna to the attic and the channel count increased to 13 (including CBC, CJOH, CHRO, Global*2, CHCH, CITY, TVO, OMNI1, OMNI2, CTH and 2 French). This is with 10ft of coax and the TV located below the attic hatch. I ran 50 ft of cable to the basement through a cold air return. With the TV now in the basement, I lost all but CJOH. I had a 20 year old 4-port distribution amplifier (Archer brand) that I placed at the end of this 50ft cable, and got all the channels back. Removed a 2nd floor TV cable from the Rogers splitter and attached it to the Archer dist amp and the upstairs bedroom still has the 13 channels (this probably added 40ft of cable). This setup's picture quality was stable for 3 weeks, but I did see heavy pixelation on some channels during heavy rain storms. After 3 weeks, I built this antenna (without the reflector) and put it in place of the rabbit ear in the attic. http://www.diytvantennas.com/sbgh.html It looks just like the photo at the top of this web page http://lowtek.ca/roo/2011/diy-hdtv-antenn/ I got the coax to twin lead transformer at 'The Source" in Barrhaven $4.95. The wire is 12 gauge used for hanging drop ceiling rails; $10 at home depot (came in a bag, about 50 feet, silver in color). With this SBGH antenna and the Archer distribution amp removed, I got 8-9 channels in the basement (compared to 1 above). With the Archer amp added back in, I am getting 15 digital channels in the upstairs bedroom (add 2 more French channels to above list). The conclusion I drew from removing the Archer amp is that this SBGH antenna is better at picking up signal than the rabbit ear. Last weekend, I added a 2nd TV to the Archer and it worked well for about 10 minutes when I either lost most ch or had pixelation on most/all. This occurred on both TV sets. I replaced the Archer amplifier with one that Rogers had left behind ( Antronix MRA1-15) and got all my channels back. Last nigh at midnight (~16C in middle of hot weekend) I re-scanned and found 21 digital ch. The new were all PBS in 2 groups of 3 (16-1,2,3 WPBS and 18-1,2,3 WNPI). The 18 group was perfect whereas the 16 group had heavy pixelation and were not watchable. In the morning, the 6 PBS ch were gone. This success with PBX has encouraged me to see what can be done to reliably pull in these American stations. Currently, my SBGH without reflector is pointed at Camp Fortune. My questions are: 1) About the amplifiers. Clearly, I need some sort of amplifier to overcome the length of the cable run and splitters. What happened to the Archer? What is that Antronix ? Are these appropriate for my setup? What about a preamp? How is that different from what I have? I see lots of postings with Channel Master 7777; would this be too strong for all my local channels? 2) Is anybody in Ottawa reliably getting PBS with an attic antenna? If so, what antenna/amp are they using? 3) Was my midnight reception of PBS a fluke? Thank you for your help. Everything I know came through reading these forums. |
#914 |
I'm in Nepean (Craig Henry) and still getting 20 channels on the system I wrote about some time back including now pretty reliable WPBS (channels 18-1, 2 & 3) and often-times Fox/CBS (28-1 & 2). (see: http://www.digitalhome.ca/forum/show...&postcount=873).
I recently replaced the CM4221 with a CM4228 on the sixteen foot wooden pole (a slight improvement in daytime reception of WPBS) and will be replacing the old RG-59 coax and screw-on connectors with new RG-6 and weather-resistant compression connectors. A proper ground rod and static block will go in as well. But overall, for the last six months it's been pretty good and, with Netflix filling out our "real" entertainment, we don't miss Rogers one bit. Still haven't moved the antenna to a more permanent location but I'm again looking at options, including chimney mount. Last edited by Dr.Dave; 2012-06-18 at 10:16 PM. Reason: Selling not allowed in these threads. |
#915 |
if you look at my TV Fool data, the Fortune Tower (10) & HC (79) are only 70 degrees apart
could i point @45 degrees and pick up both on the edge of the pattern? i was looking at the pattern for a 4228 and it has minor lobes at just about the right angles, altho i am having trouble interpreting the data i take it the antenna is at the centre of the circles (no distance is given for the circles, just dB loss), but the dB's reduce as it approaches the centre - i thought it would be the other way around? mark OK i found how to read the plots Last edited by mkaye; 2012-06-26 at 03:15 PM. |
