ON - Kanata, Barrhaven, Nepean, West of Greenbelt - OTA - Page 51 - Canadian TV, Computing and Home Theatre Forums
Old 2011-11-18, 10:19 PM   #751
luker0
So after mounting my CM4228HD on a mast about 23ft up and connecting it to a CM7778 I am getting all Ottawa channels, including Global, with great signal strength. I've also picked up 18.1, 18.2 and 18.3 PBS channels and am JUST getting the Fox and CBS signals. I may try to replace the CM7778 with a CM7777 and see if that makes it better.
Now to find DVR and I can cut the satellite cord.
Thanks to everyone for posting such great information here.
luker0 is offline
Old 2011-11-20, 02:42 PM   #752
DXer
Default Reminder: Second DHC OTA Ottawa area Members Meet 22nd November
This is a reminder that the second DHC OTA Members Meet for those in the Ottawa area is happening on Tuesday evening (22nd November 2011) in Kanata. Refer to this post for more details (and make replies in that thread):
http://www.digitalhome.ca/forum/show...3&postcount=30
DXer is online now
Old 2011-11-21, 02:52 PM   #753
flavoie
Originally Posted by roger1818 View Post
I have a couple XPPF's (in use) and I took one apart once and it definitely has a low pass filter, so although it is designed to block 120kHz, it will also block anything above it. Although I don't have any, I am confident the ACT-AF120 does the same thing.
I don't know anything about the Tripp Lite, but I am quite sure it won't be as good as it likely only uses caps to do the filtering. I could be wrong though.
Thanks a lot for the feedback. XPPF are in my future then, I just need to be careful about the 5A limit. The AF120 looks like a notch filter so will not work for my use.
flavoie is offline
Old 2011-11-21, 03:19 PM   #754
roger1818
I would be very surprised if the AF120 was a notch filter as it is easier to build a LPF than a notch filter and there is no reason to make it a notch for its intended purpose (preventing noise generated by appliances from interfering with the 120kHz X10 carrier). If anything, a LPF would be better as noise at other frequencies could also cause problems.
roger1818 is offline
Old 2011-11-21, 03:38 PM   #755
flavoie
roger1818, then for your surprise i think it is time to look at the Af120 Spec sheet
flavoie is offline
Old 2011-11-22, 08:28 AM   #756
roger1818
flavoie, you are right. Very strange.
Old 2011-11-22, 09:40 AM   #757
flavoie
^^^ I think the rationale is not to interfere with other services like LAN networking over power lines, just filter for X10.
I picked up 2 x XPPF locally. It did not fix the interference I can hear from my AV receiver when the subwoofer is on, and I get about a 2dB drop in SNR for Global when the sub is turned on. This is by plugging the sub into the XPPF then the XPPF into the filtering power bar. I also plugged my 2nd XPPF the same way for my HTPC's UPS. I have something to play around, it's a start. Next will be ferrite cores which i am trying to source. The Tripp Lite Isobar is on its way, will come in a few weeks.
flavoie is offline
Old 2011-11-22, 12:00 PM   #758
ralphus1
Hello!
I am located in Almonte and I'm looking to make the move to OTA. Now that I think about it my Rogers cable is actually being disconnected today. I recently picked up a OTA PVR unit and with it's little crappy antenna I could pick up CBC in HD. It was nice but I'll need more channels so I'm thinking of mounting an outdoor antenna on the roof of my house. My home is fairly tall.. (I'm terrible at gauging height but I'll say the roof line is probably 40' high).
Here are my tv fool results:
http://www.tvfool.com/?option=com_wr...ec12cb4aae1e82
Can anyone recommend some equipment and give me an idea of what I might expect to be able to watch? I'm considering the channelmaster 3679 but I'm obviously open to other suggestions.
Thanks!
ralphus1 is offline
Old 2011-11-22, 01:16 PM   #759
tvlurker
To be sure, you need to rerun your TVFool fwith a 40 foot height above ground.
As it stands, it looks like you should be able to get all the local Camp Fortune stations, and you may be able to get some or all of the Herberts Corners stations if there are no other local obstructions. herberts Corners is due east of you -- is your line of sight obscured in that direction?
for a better feel for your local environment, use the TVFool online maps feature, and switch to Google's satellite mode, so that you can position your proposed receiving antenna location on precise locations on the roof of your house. You can also click on the "draw lines to transmitters" options, to see if anything nearby blocks your "view" of Herberts Corners.
Even at 40 feet, I suspect that the Watertown and Massena/Norwood stations are out of reach, except for exceptional weather events during the summer.
On analog, you have a chance at the CKWS repeater in Franktown, Global 2 from near Denbigh, and channel 5 CHRO Pembroke.
tvlurker is online now
Old 2011-11-23, 08:23 AM   #760
ralphus1
Thanks for the info. The map was useful.
I found a channelmaster 3679 last night (pretty much the last one in my area) but as luck would have it - it's now snowing! So much for getting up on the roof and attaching it any time soon.
I have a dumb question. I thought that the switch over from analogue to digital had already happened - why is there still analogue channels?
ralphus1 is offline
Old 2011-11-23, 09:14 AM   #761
roger1818
The analog to digital conversion was only in specified large markets (Markets with more than 300,000 people, national and provincial capitals, and markets with more than one station). Transmitters in smaller markets are allowed to remain analog for now.
Old 2011-11-26, 03:39 PM   #762
ralphus1
That makes sense. Thanks.
ralphus1 is offline
Old 2011-12-04, 11:56 AM   #763
Landowner
Default Help Picking up global please...
I had an HD360 Antenna that was receiving all the HD signals in my area according to TVFool except for 43.1 (CTV2).
I set up a CM4221HD Antenna beside the HD360 on my roof (a few feet higher) switched over to see if a better quality antenna would catch 43.1 pointed in the direction supplied by TVFool.
Now I receive 43.1 but I have lost 6.1 Global which came in fine on the HD360.
(Note: 6.1 is very close on the CM4221HD, I receive bands of proper signal mixed with bands of snow. )
I've quickly lost my courage for roof walking so I would prefer to add a component at a lower level if possible to fix this.
Is there something I can do to the CM4221HD to boost the Global VHF signal or should I combine the
HD360 and the CM4221HD with something.
Here's my location details...
http://www.tvfool.com/?option=com_wr...3cf4d56841350d
What do I need to combine signals from 2 Antennas?
(Option: A buddy gave me a Model-ANT-5002 that I could put up if that is a better option)
Suggestions would be appreciated.
Regards
Doug
Landowner is offline
Old 2011-12-05, 09:27 AM   #764
roger1818
Landowner, the CM-4221HD is a UHF antenna and is very poor at receiving VHF broadcasts, especially VHF-LO, which CIII-DT-6 is on. You will want to use a UVSJ or a pre-amp with separate VHF and UHF inputs to combine a VHF antenna with your CM-4221HD. The VHF antenna can be pointed towards CF as all of Ottawa's VHF broadcasts originate there.
Old 2011-12-05, 09:36 AM   #765
flavoie
Landowner, like roger1818 mentions all you need now is a UVSJ, which stands for UHF VHF Splitter Joiner (also Separator, Combiner,... terms can be used). It is a special splitter/combiner which only picks up the UHF from 1 antenna and the VHF from another antenna.
The 4221hd goes into the UHF port, and the other antenna into the VHF port, and the output port goes to your TV.
flavoie is offline
OTA Forum Sponsor
