I was wondering if anyone knows what generation the chipset is for this board as I understand that 5 or 6 is the the best and most current?
TIA |
ATSC DTV performance is bottom 5th class, or high 4th class.
Analog performance is great, but buggy on MythTV. |
I use this card for ATSC viewing with Win MCE and get dropouts now and then, albeit from fringe US stations using an indoor antenna. Is their a better 6th generation Hauppauge card, or one from a different vendor that is more reliable for ATSC?
TIA |
http://www.digitalhome.ca/forum/showthread.php?t=42094
or http://www.digitalhome.ca/forum/showthread.php?t=49381 While reading hundreds of posts would give you lots of info, here's the general opinion: HVR-1250 is a great desktop card (single) ATSC tuner. HVR-950Q is a great USB (single) ATSC tuner. There are other more-or-less equivalent cards discussed in there, but these are the two most commonly used by members here |
Another way to put it, based on your rough location: at my in-laws home near Yonge and Lawrence, their Samsung 24" TV tunes just slightly less-good than my 950Q USB stick, using the exact same antenna.
The only differences I've noted thus far, is the 950Q could pull in Rochester stations on a morning when the Samsung TV could not, and Ion is slightly better with the 950Q as well (when it comes in at all). And Samsung TV's have excellent tuners. |
Thx both of you for the info, I may look into the USB version to use with a laptop.
I have/had 4 HVR-1600 and the ATSC tuners in them are all crap. I mean the worst ATSC tuner cards among my half dozen other ones.
HVR-1250 is king. It is actually better than my 950Qs (at my location anyways) 1600 is just ridiculously bad at my place for some reasons. I don't think 4/4 bad is a fluke.
LG55LW5000/Denon3313/MirageOMD5+Nanosat+MM8/ClearStream2/CM7778+3414 SSGPN50A550/OptomaHD33/Onkyo717/KEF3005/Velo15" |
#8 | |
#9 |
I use the 1250 which replaced the 1600 in my system I would not return to a 1600 after the great success I have had with the 1250. If I were starting out again I would spend the extra and go for the 2250.
#10 |
Ditto: When starting out with ota my first atsc try was with a 1600 and it was awful.
