Wireless Gigabit spec published, gains Cisco supportWireless Gigabit spec publis - Canadian TV, Computing and Home Theatre Forums
Old 2010-05-16, 05:05 PM   #1
JamesK
Default Wireless Gigabit spec published, gains Cisco supportWireless Gigabit spec publis
IT World Canada
JamesK is offline
Old 2010-05-16, 10:34 PM   #2
recneps77
60GHz?! Will that even penetrate walls?
recneps77 is offline
Old 2010-05-20, 09:02 AM   #3
bdoyledimou
it isn't designed to penetrate walls.. it is not a competitor to WiFI, it is to be used for wireless HD Signal transfers between devices (a PC and a Projector for example)
bdoyledimou is offline
Old 2010-05-20, 12:04 PM   #4
recneps77
I got that part, but if you are in the same room as the device you're connecting to, I hardly think a (most likely very expensive) wireless solution is really worth it over the cost/hassle of plugging in a cable.
Sounds like one of those technologies that sounds good in theory, but will have a very small niche market.. doesn't seem that great to me.
