MDU in condo? - Canadian TV, Computing and Home Theatre Forums
Old 2010-05-15, 02:33 AM   #1
despe666
Default MDU in condo?
I am about to move into a new condo tower. I called Bell's MDU line, and they're saying the building is not wired. However there is a big dish on the roof. I asked the constructor and they told me Bell put the dish up.
I saw a gray box in the wiring closet, with an NAS LMX-42 in it with a wire that seems to be coming from the basement in the input. This box is right next to the Videotron box.
Is there a way to know for sure if the building is MDU? What do you suggest if the constructor and Bev keep throwing the ball to one another?
despe666 is offline
Old 2010-05-15, 06:16 AM   #2
Pinza
With what you say, it is wired for the Stacked System and i would be 99% sure it has both 91 & 82. Maybe you can confirm that there are 2 x Dish's on the roof.
It is very comon for Bell not to know a building is built with a "Backbone".
Just call for an installation the installer should be able to figure it out for you.
Pinza is online now
Old 2010-05-15, 10:31 AM   #3
despe666
Thanks for your reply Pinza. You mention to confirm if there are 2 dish's on the roof. There is only 1 dish, but it has 2 LNBs. Does a backbone installation need to have 2 dish's?
despe666 is offline
Old 2010-05-15, 01:40 PM   #4
Pinza
Well I just thought about this and if the Dish is a large oval one with 2 LNBF's that is OK, I think it might be a "Triple Beam" dish that can hold 3 LNBF's.
Your MDU installers might do it different to the norm here in Ontario, where we use 2 x 75 or 90cm Dish's, 1 for each bird.
Just also called a buddy who says, some installations in the GTA have a "Triple Beam" as well.
Pinza is online now
Old 2010-05-24, 02:05 AM   #5
despe666
FYI, here's the dish in question. I hooked my line into that splitter and I picked up 91 odd so it looks like all I'm missing is a downconverter.
Do you have any idea where I could get my hand on those outside of Bell? I've had a bad experience in the past with an installer and I try to avoid them unless absolutely necessary.
http://i45.tinypic.com/2lj4775.jpg
despe666 is offline
Old 2010-05-24, 06:47 AM   #6
Pinza
Yep, that is what the bell guys call a "Triple Beam".
Without the correct down-converter you will not get all the transponders, as the entire range from both birds are stacked onto the 1 cable feeding the suite.
The down-converter is a proprietary device only available from Bell TV, even the manufacturers will not sell them to you, trust me I know lots of people that have tried. They do appear from time to time on an online auction site...
Pinza is online now
Old 2010-05-27, 07:43 PM   #7
despe666
Thank you for your help Pinza. Perhaps you can answer one more question. I got the boxes, and I see there is a VHF port on them. What is that used for? Is there a way to inject a 9242 TV2 VHF output on that wire somehow?
despe666 is offline
Old 2010-05-28, 06:51 AM   #8
Pinza
I am not 100% certain but I believe that if you hook that port to the Coax input of your TV, then tune to Channel 3, you will or should see the Lobby Camera System.
Pinza is online now
