DIY AM Radio antenna? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Digital Industry Forums > AM/ FM, Internet Radio and Music Industry
Old 2010-05-09, 04:26 PM   #1
grinder
Question DIY AM Radio antenna?
Quick question from a new-commer.
What would be a simple homemade antenna for the AM band? I've tried the loop and gotten OK results. What would be the next step up?
grinder is offline
Old 2010-05-10, 09:03 AM   #2
mr weather
If you've got the real estate, put up a random length longwire. The longer (like hundreds of feet) the better.
mr weather is offline
Old 2010-05-10, 02:35 PM   #3
stampeder
grinder, are you trying to improve reception on a particular station/frequency or across the entire AM radio band?
stampeder is offline
Old 2010-05-10, 08:28 PM   #4
grinder
Ideally, I'd like to span the AM band for general DXing. As for the random wire, will any length do, or does it need to be calculated for some central frequency?
grinder is offline
Old 2010-05-10, 11:24 PM   #5
cfraser
^ Normally you'd make it really long and then tune it with a (believe it or not ) long wire antenna tuner. I believe MFJ still sells a fairly economical one, not hard to make one just for receiving. A long dipole is a nice not-too-difficult project. Also consider a fancy loop antenna. What is great about them is, besides being reasonably small (compared to LW or dipole), you can manually rotate them (indoors) and they can be very directional, good for mostly blocking that same-frequency station that may be coming in on top of the main one you want. There are some plans on the web.
cfraser is offline
Old 2010-05-11, 07:05 AM   #6
majortom
regardless if ur going to build a dipole, a long wire, or a loop I'd consider getting a short wave radio also. Just so ya wouldn't be limited to the AM Broadcast Band. u'd get dual duty from both the s/w radio, and the antenna.
majortom is offline
Old 2010-05-11, 08:45 AM   #7
mr weather
A nice long loop antenna (say, running the perimeter of your backyard) would work well too. And an advantage is they're not as susceptible to noise as other antennas.
Old 2010-05-11, 09:58 AM   #8
cfraser
^ Yes, noise pickup is the problem with many AM antennas, especially bad in an urban environment (like where I am). I quite like the loops for this. Don't compare the crappy (but still directional) loops you get with AVRs etc. with the larger ones, there is a huge difference. I am speaking of indoor loops here, never tried an outdoor one (I don't know why...).
cfraser is offline
Old 2010-05-11, 11:55 AM   #9
spensar
How about a loop inside the attic? Would that work? Nothing there but insulation.
Panasonic TH-42PX60U, Harmony 670, Rogers HD 8300, 3250HD, Denon AVR-591, Chartwell SL3-5A, Venturer SHD-7000, Samsung 1600 BR.
spensar is offline
Old 2010-05-11, 02:57 PM   #10
mr weather
It could. Interior antennas tend to be noisier because they pick up household EMI (motors, dimmer switches, etc.)
Old 2010-06-04, 09:57 PM   #11
El Gran Chico
Location: Toronto/Etobicoke - Bloor/Royal York/Queensway/Islington
Question
I hope this isn't too dumb of a question but what gauge wire would work best?
Orig 4221, A-D C5, CM 7778, Aquos LC37D62U, TiVo Premiere, DTVpal DVR
El Gran Chico is offline
Old 2010-06-05, 01:10 PM   #12
stampeder
A big spool of something very fine (between 20AWG and 24AWG) will do great. Anything bigger is too cumbersome and doesn't help. If you have an old TV around you could carefully remove the yoke from the picture tube and use that great supply of fine copper wire. Old AM Radios have coil antennas with the perfect wire for your use.
Old 2010-06-06, 12:23 AM   #13
HDTV101
Here's how to make a really good indoor AM antenna: http://www.radiointel.com/review-amloop.htm
HDTV101 is offline
