Can't figure it out (neither can BEV Cust Serv) - Page 2 - Canadian TV, Computing and Home Theatre Forums
Old 2010-05-02, 03:03 PM   #16
mrhud
Seems the issue was with the receiver.
I setup my other 3100, reactivated the card and it's working fine.
Thanks for all of your suggestions.
mrhud is offline
Old 2010-05-02, 03:22 PM   #17
dirtroad
Default Check LNB in connection.
In the last month, I have repaired 2 LNB in connectors on 3100's where the center connection inside the receiver has been torn right off the circuit board!
You may be able to determine this by putting a slight pressure up then down on the RG6 LNB in connection, up should make it connect, and down will separate the connection.
It is a very simple repair inside if you have any soldering skills at all. Worth trying before you throw it out!
If Life is a Highway,...then why is there no end to this dirtroad?
dirtroad is offline
Old 2010-05-02, 04:22 PM   #18
Pinza
That used to be a very common problem on 3100's if the centre pin on the coax was too long.
Pinza is offline
Old 2010-05-02, 05:57 PM   #19
Costa
Do a check switch test on the lines orignally connected to the 9200, and make siure those lines are good first before trying one on the 3100.
You cant use splitters, whatsoever!
From the SW44 switch, to the receiver directly. You stated that you split it from the 9200.
Costa is offline
Old 2010-05-02, 07:45 PM   #20
Pinza
Costa, he used another 3100, it worked just fine. It was a receiver problem.
Pinza is offline
