Line Down Middle of Screen - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Rogers Communications > Rogers Cable TV
Old 2010-04-13, 04:19 PM   #1
ldidom01
Default Line Down Middle of Screen
Hey all, need some help.
There is a line down the middle of my screen on basic channels. It seldom shows up when I'm watching HD channels. I have concluded it is the cable because I don't have this problem when I throw on a Bluray or when I connect the cable straight to my TV. Could it be the HD box is a dud? or something else? I called Rogers asking about this problem and they said they can see that there is somthing wrong with the hookups on my lines...so they came and fixed everything that they said needed fixing...but I still see that godforsaken line! Can anyone help me out here?
ldidom01 is offline
Old 2010-04-13, 04:24 PM   #2
Larry
Is this a vertical or horizontal line? Does the line move or is it stationary? What does the line look like (solid black or colour, fuzzy, ..etc)
Larry is offline
Old 2010-04-13, 04:25 PM   #3
ldidom01
horizontal. Right down the middle of the screen, sometimes off to the left or the right. It stays stationary and is only really noticeable on Red Orange or Yellowish colours.
ldidom01 is offline
Old 2010-04-13, 06:33 PM   #4
Larry
Some suggestions to narrow the search for a solution:
1. try connecting the cable directly to the TV to view the analog channels
2. try different cables between the HD box and the TV - if you are using HDMI, try component cables
3. try a different input on the TV
Larry is offline
Old 2010-04-14, 02:32 PM   #5
ldidom01
I have unplugged and tried just analog, no line...I have had the same problem with component cables, one thing I haven't tried is a different input...I'll try that then let you know.
ldidom01 is offline
Old 2010-04-14, 07:31 PM   #6
Paolo
does this happen on hdmi?
Paolo is offline
Old 2010-04-15, 10:31 AM   #7
ldidom01
Tried the different input and so far no line. This is a good thing, I guess it's just that input on my television which kinda sucks. And yes, I have my cable connected through HDMI.
ldidom01 is offline
Old 2010-04-15, 12:39 PM   #8
Larry
So you see the line with both HDMI and Component (obviously different inputs). But you don't see it on another HDMI input? When you tried component, were you sure you switched to component and weren't still viewing the HDMI?
I guess I'm confused precisely what you have seen. Can you create a table:
Input Type Result
1 HDMI line
2 Component line
3 HDMI no line
or whatever
Larry is offline
Old 2010-04-15, 12:51 PM   #9
Mythorn
Also, remember to disconnect the HDMI from the HD box when trying to view component. If they are both connected, the HDMI will either override the component or you'll get even stranger issues. Can you also tell us what model of HD Box you have?
Mythorn is offline
Old 2010-04-16, 01:19 AM   #10
romulus
Did you mean to say VERTICAL ?
Sharp LC40E77UN, SONY STR-DE685 AVR
SA8300HD PVR, Pioneer DVR-543HS DVDR
romulus is online now
