In Wall Receiver - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Home Theatre Corner > A/V Receivers and Amplifiers
Old 2010-03-28, 10:13 AM   #1
Tom Foolery
Default In Wall Receiver
I'm looking to put some in wall speakers in my study. I haven't chosen what speakers I'm going to use but that won't be a problem. My problem is I'm somewhat limited in space and a big receiver wouldn't look very good in the room. I did a google search for in wall receivers and I didn't really find anything that looked like it was decent quality.
Does anybody know of any in wall receivers. Preferably from a well know manufacturer i.e. Yamaha, Denon, Onkyo
Tom Foolery is offline
Old 2010-03-28, 12:14 PM   #2
cambo
Good luck on that. These things need to breathe. Having it cooped in-wall won't allow enough air-flow- especially if cooling is required at the back.
Have you considered mounting a shelf to save some floor space?
cambo is offline
Old 2010-03-28, 12:38 PM   #3
JamesK
I haven't seen an "in wall" set, but I have seen one built into a corner cabinet. I expect you could mount almost any recent flat screen set into a frame built into a wall. However, as has been mentioned, you'll have to allow for cooling.
JamesK is online now
Old 2010-03-28, 06:28 PM   #4
Tom Foolery
I forgot to mention that I'm trying to connect the speakers to my computer. might there be any other solution to bypass a receiver, such as an amplifier
Old 2010-03-28, 07:31 PM   #5
nobsplease
Try the Yamaha DRX-730. Half width, good amp, doesn't require a lot of cooling space (digital amplifier).
Artificial intelligence is no match for natural stupidity.
nobsplease is offline
