#31 |
I recently upgraded from 8300 to 8642. Can't say that I am seeing anything, other than larger hard drive, that I currently find worth the cost.
Since upgrading I am experiencing one problem, however. For my HD CBC channels (514, 515, 544) most audio streams seem to play only through the L, R surround speakers, and not through the centre channel speaker. This happens for most audio streams, such as the National news. Luckily, hockey commentary plays through the centre channel speaker, although when it switches to a commercial, or even ice-level commentary, the audio switches to L, R speakers. This only happens with CBC channels. Can anyone shed any light on what is going on or what can be done to fix it? Thanks in advance. |
#32 |
neils, please read the following FAQ on DD5.1 and improperly encoded DD5.1. This should also have been evident on your 8300, since it's been that way with CBC for years. (Possibly you didn't have your PVR or AVR properly configured for DD5.1 before and were getting "surround sound" instead of DD5.1)
http://www.digitalhome.ca/forum/showthread.php?t=17870 Then check out the following post, useful for those new to the forum - FAQs, Search Tips, Optimization, etc: http://www.digitalhome.ca/forum/showthread.php?t=57741
#33 |
Didn't see this mentioned yet, but the IPG shows unsubscribed channels in grey. I'd rather have the option to filter them out completely, but this is at least an improvement over the 8300.
#34 |
I just installed my two 8642s today.
There was one glitch that I noticed - in comparison to my 8300. I previously had my 8300HD working with my Pioneer Kuro Elite 151 such that (on the remote), when I pressed CAB, then PWR - it would turn on the TV, then the Rogers box. This worked fine. Now, with the new 8642, this same sequence does not work properly. There seems to be an HDMI (timing) issue that is different than the 8300HD. When the TV comes on, and then the Rogers box, there is seemingly not enough "time" for the TV to (see) the 8642 - leaving me with a black screen - as if the 8642 was not on. Turning the 8642 off, then on again fixes it. My only solution is to set up the remote to only control the power of the devices individually - rather than the multi device macro way - as I need to allow about 1 second more before I turn on the 8642 after my TV comes on. What this boils down to is that the 8642 must start up a bit slower than the 8300 - and it sends its signals via the HDMI cable a bit delayed compared to the 8300. Not a big deal, of course - but a noticeable difference between the two. Maybe an upcoming firmware update would fix it.... In any event, the new features I like are: - Color schemes (the guide themes) use richer colors - look better on screen - FFW, REW, etc display the actual time on the pointer where you are - Channels you don't subscribe to are in grey (finally) - So far, the "quickstart" nonsense has not made its way onto the two units - The hard drive seems to run MUCH quieter than the 8300 |
#35 |
Forgive my ignorance on the matter, but if I buy a PVR from someone other than Rogers, will it work with Rogers ?
#36 | |
Posts deleted. From Post #1
#37 |
Location: Whitby, Ontario (Rogers Cable), LG 42PC3D, 8642HD
If you want it to work with the digital channels, you need to have a Rogers PVR. If all you plan to use are the analog channels, you could use a Tivo with it. Bell PVRs and PVRs from other cable companies will not work.
#38 |
Darn
Okay, thanks for the quick response !!!! |
#39 |
Just to be 100% clear: if I buy an 8642 (not a TiVo, etc.) from a source other than Rogers, will it work with digital channels?
#40 |
Yes, as long as it is an 8642 that is manufactured for Rogers. For example, if you bought one in the US that was set up for another cable company, it won't work here at all. Rogers will not activate it for you.
So you'd want to buy from an authorized Rogers reseller, of which there are many around the GTA. |
#41 |
Three other things I have noticed with the new 8642:
- The Quickstart guide has not loaded onto it (yet) - The Call Display function does not work - Scrolling in the guide is sluggish if a program is recording Anyone else notice this ? |
#42 | |||
Location: Waterloo, Rogers Cable, Panasonic 55" Plasma, Insignia 5101HD, Cisco 8642, Kaleidescape
My HT equipment: Panasonic 55" Plasma, Insignia 5101HD, Cisco 8642 PVR, Kaleidescape 3U Server & M500 Player |
#43 |
I am very pleased with my 8642 especially the bookmarks on part played recordings. My only problem is with severe glitches on playback of the CBO HD hockey recordings, Ch 514.
The video freezes for a half second and the audio is muted for maybe a second. This occurs roughly every 2 minutes. This did not occur with my 8300 so is it my 8642? Anybody. Thanks. |
#44 |
I'm having random glitches too but i had those on my 8300 in the last month or two so I'm not too worried. I can't tell if it's worse but I had chalked this up to Rogers and not to the box. Overall I'm quite pleased with my 8642 500GB unit.
#45 |
A heads-up for anyone getting the 8642 box: unlike the 8300HD, it does not include an analog tuner, so if you live in a condo/apartment tower you will not be able to see the lobby channel (998) using the 8642. Rogers suggested workaround is to split the cable and feed it directly to your TV (assuming your TV has an analog tuner). This is inconvenient... they really should offer the Cisco 8652 box which includes an analog tuner.
| Tags |
| 8642, audio drpouts, cisco, cisco 8642, closed captioning, download, firmware, freezing, hd-pvr, live, pause, pvr, recording, rogers |
