Rogers 8642 HD (Nextbox) PVR Owners Thread: Read post #1 ) - Page 14 - Canadian TV, Computing and Home Theatre Forums
Old 2010-10-26, 07:44 AM   #196
kibosh
Padding is definitely sticking on my 8642 which has been very nice!
kibosh is offline
Old 2010-10-26, 08:07 AM   #197
ajaxmike
Originally Posted by moti View Post
The problem I am having with converter box is that every five or so minutes the signal does berserk and the picture gets mess-up and the sound disappears. This situations lasts about 1 or 2 seconds. This occurs in recorded mode. It is now over a month old. Any suggestions? Moti
I am having a similar problem with my 8642. When playing back recorded programs, the sound cuts out for a second or two but the picture is OK. Watching live is fine. I think Rogers has a problem with this unit.
ajaxmike is offline
Old 2010-10-26, 08:11 AM   #198
ajaxmike
Originally Posted by snorlax View Post
Best guess is a heat related problem. When the temperature exceeds some critical temperature some component misbehaves and causes your trouble. I would move the PVR to a better ventilated place. Remove it from a sealed cabinet or move it off some other heat generating component. See if this makes a difference then you can act accordingly for a more permanent fix.
My unit sits on an open shelf by itself with no significant heat near it. I highly doubt that heat is the issue. I suspect that the processor and the hard disk are having trouble syncing. I have a 500GB drive.
ajaxmike is offline
Old 2010-10-27, 08:30 AM   #199
moti
Default My 8642 screws up in record mode
Thanks for the suggestions. It apparently is working after I isolated the box Thanks snorlax
moti is offline
Old 2010-11-02, 02:19 PM   #200
sheepishSCOT
Default 8642 Auto Stretch in SD channels (how to stop it!)
I just swaped a dead disk HD PVR and got an 8642. With the old box; when in 1080i the picture size could be controlled using the # button from normal to zoom etc. The 8642 can do this too but when on an SD channel using 1080i and in Normal size it auto zooms out the side bars. It distorts the picture and is total annoying!
Can this be controlled?
In more setting the picture format is set to fixed
In settings it is set to 1080i picture size normal
Using the HDMI output
TV is a Sony Bravia 52" LCD
Thanks!
sheepishSCOT is offline
Old 2010-11-02, 02:33 PM   #201
sheepishSCOT: In the advanced setup wizard, make sure that only 1080i is enabled and make sure that 480i/p widescreen is NOT enabled (it's the latter that causes the stretching). It's usually good to do a reboot after running the wizard.
http://www.digitalhome.ca/forum/showthread.php?t=17719 SA FAQ
See also the following post, useful for those new to the forum - FAQs, Search tips, Optimization, etc:
57 is offline
Old 2010-11-02, 05:00 PM   #202
sheepishSCOT
Default tks
tks brother!... ship is sailn true again
Old 2010-11-05, 11:52 AM   #203
slk188
Default 8642 box freezing
I am having the same problems with the 8642 HD box (freezing and muting for a few seconds) as some others have I am very frustrated. I replaced the box and that still that didn't help, I had technicians at my house ect.... and I still have the same problems. Rogers is telling me they will replace the box again but I know I will have the same problems.
Does anyone know if there is a solution to this problem?
slk188 is offline
Old 2010-11-05, 12:57 PM   #204
moti
I have the same problem. I thought by isolating the Box it had impoved. No such luck. It occurs when I am copying two shows. Thanks
moti is offline
Old 2010-11-05, 05:10 PM   #205
slk188, moti Have you checked your signal strength and S/N ratio when you have these issues? SA FAQ, post 196. Do you have the 160 or 500 GB HDD?
57 is offline
Old 2010-11-06, 08:52 AM   #206
moti
I have a 500 Gb. My HDHI does not work correctly. My S/N is 33 and my Video 79 and Audio is 78. I disconnected my telephone connection from my TV to increase my signal strenght. Do people have their HDHI working? Thanks
moti is offline
Old 2010-11-08, 02:39 PM   #207
icemankent
SAME here - mine has been doing this ever since I got it.
I am not sure if it is a firmware issue, or if the processor in these boxes is a cheap, under-powered paperweight - but it does NOT seem capable of doing more than 1 thing at a time.
For example, if I am recording 1 program, (and tuned to an actual channel), while engaging the guide to scroll for things to record - it is VERY sluggish. If I am recording 2 programs and engage the guide it is so sluggish to be almost unuseable.
Under those circumstances, I have also found that it will sometimes FREEZE entirely - where either the picture and audio are frozen, or just the picture.
Please someone tell me that this is will be possible to be fixed via firmware - and not that the box itself is too cheap to handle the load - thus we have all bought lemons.
icemankent is offline
Old 2010-11-08, 03:32 PM   #208
whitbyterry
Location: Whitby, Ontario (Rogers Cable), LG 42PC3D, 8642HD
I have had my 8642 for about a month now. It works perfectly. I often record one program and watch another. I do not notice any issues with speed or quality.
whitbyterry is offline
Old 2010-11-08, 04:03 PM   #209
moti
Default Freezing Box
The issue is copying two programs at once. Thats when you see the effect.
moti is offline
Old 2010-11-08, 07:01 PM   #210
Eluder
I'll check, but I know that when I am recording two programs at once and watching a 3rd (recording), I have no issues whatsoever, which I found to be impressive.
I'll check on the guide part to see if it's slow when two programs are recording.
Eluder is offline
Tags
8642, audio drpouts, cisco, cisco 8642, closed captioning, download, firmware, freezing, hd-pvr, live, pause, pvr, recording, rogers
