#166 |
I received a 8462 on Friday and can say that I am not experiencing any of the issues some are reporting here.
The picture is excellent (no worse than the 8300). I have no audio sync issues (I am using HDMI into a Denon receiver). Nor is there an audio lag when you stop fast forwarding through commercials. I am not experiencing any pixelation issues when fast forwarding or reversing. In fact, it may be my imagination but I might argue the picture is clearer than before when doing this. Also when padding a weekly recording of Medium on Friday the next scheduled recording next Friday has retained the padding. Now it has been a while since I have attempted this so I am not sure if this is the same behaviour as before and the padding doesn't get dropped until the actual recording occurs. I am very interested to see if the padding sticks, or if someone can confirm the padding will get dropped upon recording. |
#167 |
Had my 8462 for a few weeks now. Don't like the fact that I cannot record the same show twice in one day without setting to record any time this channel. Missing Hell's Kitchen!!
#168 |
I am pretty sure the guide and menu buttons have always done the same thing . . . and don't you mean hopefully they never add the quickstart guide to the 8642?
#169 |
Location: Whitby, Ontario (Rogers Cable), LG 42PC3D, 8642HD
I recently had issues with my 8300HD rental so I went to exchange it and they gave me the 8642 model. So far it is working well.
One thing I noticed last night was the Copy To VCR option is no longer available in the playback menu. I see that someone posted this at the very beginning of the thread. I used to output some shows for my daughter to DVD so she could watch stuff on long car rides. It now seems there is no way of doing this. Am I wrong? Is my DVD recorder now going to be just a DVD player? I guess I will have to finally invest in an external drive since there would be no way to archive anything either. |
#170 |
Cornflake - I can verify that the IR sensor on the 8642 is terrible. It sees signals from only a narrow angle range, therefore you need to be right in front of the unit (trying to hit from a 90 degree angle as I did with the 8300HD does not work well).
Terry - With the Copy to VCR option gone you could hook up a device to capture the analog output in realtime and copy to DVD if you wanted. Obviously, this still does not capture in HD format but you can do what you're asking for.
Pioneer Elite PRO-730HD | Elite DV-59AVi | Marantz SR8200 | Mirage OM series | Rogers/Cisco 8642HD, SA4250HD |
#171 |
Slyboy - can you capture playback from the PVR that way? I always assumed you could not since you had to use the "copy to vcr" function.
#172 |
Terry, you can still copy to the VCR simply by hitting "play" on the PVR and "record" on the DVD recorder at a time that you're not watching anything else. You must also do this at a time that does not include the "auto-standby" time of 1:10AM.
Here's the thread comparing the features of the two PVRs as linked in post 1 of this thread. http://www.digitalhome.ca/forum/show...80#post1121780
#173 |
I will give that a try. Thanks!
What was the purpose of the "Copy to VCR" option then if you never needed it? |
#174 |
It allows you to copy in the background, however, some people did encounter problems with it in the background.
#175 |
Is the 8642 Hard drive suppose to be or almost constantly reving up?(doesn't really stop keeps on riving up) Because since last night the hard drive(you can hear it) starts up, you hear it running, then stops. Then the procces starts all over again about 3 seconds later.
Its a new unit only had it maybe less then a month(rental)? You also hear a thump sound coming from the TV when you fast forward / reverse the PVR after >>> or <<< bars? Is this common? I never had this with my 8300? Last edited by MCIBUS; 2010-10-07 at 03:51 PM. Reason: grammar |
#176 | |
#177 |
Here is the problem I am having with my 8642. Recordings are often missing the begining and the end of the show. The PVR records 60 mins (or 30 mins) as per the timer, but the show is slightly offset from the hour. On my old Bell 9241 it automatically added a few minutes to the beginning and end of the timer to compensate for this.
I tried to manually change the timers, however, only 2 of the entries reflect adding 2 mins to the end, the others still show the timer ending on the hour. Curious that it takes effect for some but not for others. Any ideas? |
#178 |
This has been discussed often and is a problem with the IPG - it's not accurate. Also, there is an issue with programming padding (firmware) as outlined below.
The "padding" (adding extra minutes) will only work if the programme is on more than once a week. If it's only on weekly or less often, then the padding goes away and the scheduled recording goes back to what the IPG shows, which is inaccurate in some cases. You'll need to set a new recording (or padding) each week, or record the next programme in line, or perhaps attempt a manual recording, which often doesn't work properly either. Each provider has his share of issues and this is one with our PVRs (8642 and 8300). Here's the thread on the topic - as you can see from the date of the first post, it's been going on for some time: http://www.digitalhome.ca/forum/showthread.php?t=18207 Suggest you read the stickies, FAQs and the following useful post: http://www.digitalhome.ca/forum/showthread.php?t=57741 Edit by 57. Others in this thread have indicated that padding does work on the 8642 for programmes that air say once a week. The 8300 doesn't appear to work that way on the current firmware.
57's Home Theatre (Latest equipment & photos) 57's Optimization Services (Home Theatre Optimization) Last edited by 57; 2010-10-26 at 09:51 AM. Reason: Added Edit |
#179 |
Deleted
#180 | |
| Tags |
| 8642, audio drpouts, cisco, cisco 8642, closed captioning, download, firmware, freezing, hd-pvr, live, pause, pvr, recording, rogers |
