#61 |
I did it with the model from post 54:
Code:
Run SWR Gain F/B F/R R-a X-a Eff. Segs 1-0 1.4754 13.13 6.12 6.12 429.21 55.034 99.87 328 1-1 1.458 13.1 6.11 6.11 432.63 32.872 99.87 426 1-2 1.4458 13.05 6.09 6.09 433.7 2.9925 99.87 570 1-3 1.4452 13.02 6.09 6.09 432.2 -17.46 99.87 754 1-4 1.4526 12.99 6.09 6.09 428.61 -39.94 99.87 1004 1-5 1.4662 12.98 6.1 6.1 424.21 -58.6 99.87 1310 1-6 1.8526 13.16 6.1 6.1 510.02 -126.2 99.87 1752 1-7 1.7968 12.89 6.13 6.13 454.7 -155.8 99.88 2318 1-8 1.8304 12.62 6.2 6.2 406.3 -186.1 99.88 3066 1-9 2.0167 12.15 6.35 6.35 333.99 -224.1 99.89 4074 1-10 2.6439 10.07 7.72 7.72 115.99 -41.32 99.9 5418 1-11 3.8206 5.9 10.98 10.98 121.58 -210.1 99.92 7198 1-12 1981.3 8.27 10.45 10.45 0.1527 -27.33 98.71 9570 |
#62 |
Nikiml,
Re your conv-test results in post #61, I sent you an email with some tips and suggested investigations you could do to obtain a better understanding of these results. I don't have the time to dig into now. I would simply point out that runs 1-0 to 1-3 are for segmentation at 10 segs per 1/2 wave to ~23 segs per 1/2 wave and the gain varies from 13.13 to 13.02. The next run 1-4 has a total seg count of 1004, which is ~31 segs per 1/2 wave. I suspect that for run1-4 (and 1-5 to 1-12), the normal 4nec2 segment check would report errors. If this turns out to be the case, conv-test results for these runs are not valid. If you have the time, it would be very interesting to investigate a manual nec file based on run 1-4 at ~ 30 segs per 1/2 wave. Does it pass the normal 4nec2 segment check with no errors at 585mHz? What about runs 1-5 to 1-12 ? Last edited by Autofils; 2010-06-10 at 09:35 PM. Reason: corrected spelling |
#63 |
You were exactly right.
1-0...1-4 are warning free, but the rest dont pass the segment checks |
#64 |
I was going to run that nec model (post 54) in EZNEC and run the auto seg on it but I couldn't import it in because EZNEC likes to import actual x,y,z cooridinates and those are not. EZNEC gives 2 options for segmentation conservative or minimum recommended for the frequency you select. I was curious what it would do with that model but it didn't happen. I know with other models I've adjusted the segments to 1 and then let EZNEC auto segment and it did a great job.
Many times after auto segmentating certain models I had to adjust the source wire diameter very close to the size of the wires it was attached to to get the AGT back in line. I would think that is a good thing because I'm still on the fence about adjusting the source wire much to get a good AGT. I've also found that some things that EZNEC doesn't protest about 4NEC2 does like certain dia/seg ratios and dia/length ratios. I'm not very good with 4NEC2 I really only use it to get some of the nice graphs it generates. |
#65 | |||
You can easily convert the 4nec2 nec file into compatible (x,y.z) co-ordinates for EZNEC, by resaving the nec file in 4nec2's geometry editor, under the settings tab in 4nec2's main window. That save will strip out all the SY cards. re your other comment: Quote:
Reference post by j3d 5 May 2009 --> http://www.digitalhome.ca/forum/show...4&postcount=45 From my reading in this thread, I don't see that much discussion took place on this subject. For those that have a desire to better understand the limitations of the nec2 core and how best to deal with nec2 limitations in their models, I see the question to be answered as this: If the adjustment to the wire diameter of the Vsource is only a very small percentage, does this "procedure" have merit or should it be abandoned? In post 49 of this thread, 300Ohm mentioned the following: Quote:
I'm sure that all, would like to get the views from Arie and Dr Cohen. Cheers |
#66 | ||
Although, really really fat dipoles start to behave like bowties.
#67 | |
Re your comment "the Vsource wire isnt a real wire in the build anyway": Are you stating an opinion that you believe the "AGT wire adjustment procedure" is valid or it is not valid, since the Vsource wire element is not a part of the antenna design? I'm also not exactly clear on what you mean by "those warnings may be built in cost overrun". By cost overrun, are you implying that 4nec2 warnings are not really all that important and thus can be ignored? Only errors are really important? I'm not being critical, I just feel that clear understandings are needed to have a good discussion. Cheers |
#68 | ||
Warnings on the otherhand, The warning for the wire diameter size for reflectors, doesnt seem to make a difference in real life builds, from what Ive observed, other than fatter/wider the better. And the angle too sharp warnings, for example on bowties, dont seem to amount to anything either. I havent hit upon every warning yet, so there may be some that should cause serious concern. But for the most part it seems the warnings are something that should be acknowledged, ie yes its a fat reflector or yes thats a sharp angle, but then move on, heh.
#69 |
Since the reflector-less SBGH with NARODs is a pretty popular antenna to build, (not ANY bi-directional vhf-hi/uhf antennas are commercially available AFAIK) nikimls top hat NAROD is a good overall compromise over the vhf-hi band and it minimizes the channel 33 -38 gain dip. For channel ranges 7 - 9 or 11 - 13, and if channel 33 - 38 arent a concern, the specific vhf-hi channel range vhf-hi straight NAROD would be the ticket.
NEC file with gen1 reflector-less SBGH with nikimls optimized top hat NAROD. Code:
CM model segmentation is derived from autosegmentation 21 at 698Mhz CM AGT = 1.0 (0db) at 585 mhz CM Based on Nikiml top hat gen1 SBGH with 89mm feed point CM and using 6 gauge wire for driven elements and NARODs. CE GW 1 21 0 -1.7519685 0 0 -6.7629921 5.01101575 0.08101138 GW 2 21 0 -6.7629921 5.01101575 0 -1.7519685 10.0220315 0.08101138 GW 3 21 0 -1.7519685 10.0220315 0 -6.7629921 15.0330472 0.08101138 GW 4 17 0 -6.7629921 15.0330472 0 -12.353543 15.0330472 0.08101138 GW 11 7 0 -8.5472441 17.4304724 0 -8.5472441 15.4934646 0.08101138 GW 14 15 0 -8.5472441 15.4934646 0 -13.429134 15.4934646 0.08101138 GW 21 21 0 1.7519685 0 0 6.76299213 5.01101575 0.08101138 GW 22 21 0 6.76299213 5.01101575 0 1.7519685 10.0220315 0.08101138 GW 23 21 0 1.7519685 10.0220315 0 6.76299213 15.0330472 0.08101138 GW 24 17 0 6.76299213 15.0330472 0 12.3535433 15.0330472 0.08101138 GW 31 7 0 8.54724409 17.4304724 0 8.54724409 15.4934646 0.08101138 GW 34 15 0 8.54724409 15.4934646 0 13.4291339 15.4934646 0.08101138 GW 10 51 0 8.54724409 17.4304724 0 -8.5472441 17.4304724 0.08101138 GW 41 21 0 -1.7519685 0 0 -6.7629921 -5.0110157 0.08101138 GW 42 21 0 -6.7629921 -5.0110157 0 -1.7519685 -10.022031 0.08101138 GW 43 21 0 -1.7519685 -10.022031 0 -6.7629921 -15.033047 0.08101138 GW 44 17 0 -6.7629921 -15.033047 0 -12.353543 -15.033047 0.08101138 GW 51 7 0 -8.5472441 -17.430472 0 -8.5472441 -15.493465 0.08101138 GW 54 15 0 -8.5472441 -15.493465 0 -13.429134 -15.493465 0.08101138 GW 61 21 0 1.7519685 0 0 6.76299213 -5.0110157 0.08101138 GW 62 21 0 6.76299213 -5.0110157 0 1.7519685 -10.022031 0.08101138 GW 63 21 0 1.7519685 -10.022031 0 6.76299213 -15.033047 0.08101138 GW 64 17 0 6.76299213 -15.033047 0 12.3535433 -15.033047 0.08101138 GW 71 7 0 8.54724409 -17.430472 0 8.54724409 -15.493465 0.08101138 GW 74 15 0 8.54724409 -15.493465 0 13.4291339 -15.493465 0.08101138 GW 50 51 0 8.54724409 -17.430472 0 -8.5472441 -17.430472 0.08101138 GW 100 11 0 -1.7519685 0 0 1.7519685 0 0.06424494 GS 0 0 0.0254 ' All in in. GE 0 EK LD 5 0 0 0 2.49e7 0 EX 0 100 6 0 1 0 GN -1 FR 0 1 0 0 698 0 RP 0 60 73 1001 0 0 3 5
#70 |
Adjusting the source wire can also be accomplished by changing it's length and get the same result.
In many of my models I use wires running away from the feed point like balun wires would be and then attach the source to that. By doing that it allows me to change the source wire length and it has the same effect as changing the diameter. I don't think it's any better than changing the source wire diameter except maybe it doesn't fall into some of NEC limitations but I don't think that a very small increase or decrease in wire diameter does either. I've tried it both ways and got the same results. If your segmentation is way off and you have to adjust your source wire a lot to get a good AGT then probably your convergence is bad due to the poor segmentation. In that case I would say adjusting the source wire diameter is just fooling yourself. |
#71 |
My thanks to 300Ohm and mclapp for their comments:
Reference links: 300Ohm (post 68) --> http://www.digitalhome.ca/forum/show...1&postcount=68 mclapp (post 70) --> http://www.digitalhome.ca/forum/show...2&postcount=70 Like 300Ohm, I have used the AGT adjust "procedure" in all my past posted 4nec2 nec files. I never really questioned the effect of different wire diameter, on this AGT adjustment, because the results never indicated any significant wrong results. After recently reading j3d's post on the subject, and with a re-read Cebik's modeling guide, part 4 ( the last 2 pages under the heading "Testing Models"), I thought it would provide a better understanding of 4nec2 limitations, if jed's question could be answered with some detail and if possible some reference links. Reference link to j3d's post --> http://www.digitalhome.ca/forum/show...4&postcount=45 For me, the questions that need answers is simply this: ... in the case of the AGT adjust procedure, do two wrongs actually may a right" and along with that, do other modelers, besides DigitalHome.ca forum members, use this AGT adjust procedure? The recent posting (post 61) by Nikiml re Convergence Tests on his model, provides some "food -for-thought" and I invite comments. If the majority of readers on this subject feel, that this is somewhat of a waste of time, I will stop posting on this subject, as I have plenty of other activities to keep me busy. The only way I can "measure" the interest in this subject is from the posts that are made. Food - for - Thought Comments ========================= Nikiml's post 61, Convergence-Tests showed, that up until segment-check errors occurred, the raw gain varied from 13.13 dBi (total_segs=328) to 12.99 (total segs=1004). Reference link (post 61): --> http://www.digitalhome.ca/forum/show...9&postcount=61 By extrapolation of Nikiml's data, 21 segments per 1/2 wave raw gain would be 13.03 dBi. For this specific model, the Convergence Test reveals the "most accurate" raw gain convergence is 12.99dBi. So does the recommended model at 21 segments per 1/2 wave using the AGT adjust procedure, give a more accurate result, not only for this model, but for any model, regardless of the complexity? The beauty of the Non-adjusted AGT Test and the Convergence Test is: you can depend on the results, regardless of antenna model differences (GH vs Yagi or BowTie etc)and the antenna's complexity. In an effort to continue this discussion, here are some more "food-for-thought" links. 1. Arie's 4nec2 Forum The AGT is off - Why? A bug? http://fornectoo.freeforums.org/the-...-bug-t175.html Auto Segment http://fornectoo.freeforums.org/auto-segment-t189.html 2. Practical Antenna Modeling - WX7S http://www.wx7s.com/wordpress/?m=200812 3. Antenna Modeling for Radio Amateurs Here is an excellent overview about some of the history of antenna modeling with references to mathematical models. There is a brief discussion about limitations of the various modeling approaches and a summary of EZNEC and 4nec2 is included. This pdf doc was written by Steve Stearns, K6OIK. http://www.fars.k6ya.org/docs/Antenn...o-Amateurs.pdf ...Cheers |
#72 |
I decided to cleanup the models I posted earlier, to remove the segmentation warnings, to fix the spacing between the NARODs and the driven elements to 12mm and remove few inaccuracies.
Bellow are the dimensions for the "cleaned-up" jeds GH mods with Top hat NARODs and 3 narod reflectors. I propose to call them GH10n3,..., GH4n3 - n for NARODS and 3 for the narod reflectors. For all models use the dimensions from the JED's website plus the additional dimensions from below. The X dimension is the distance between the driven elements plane and the NAROD reflectors plane. s is the distance (center to center) between the horizontal legs of the NARODS and the driven elements. The b dimension from the JED's models is also the length of the horizontal legs of the narods. Code:
GH10n3 GH8n3 GH6n3 GH4n3 --------+-----------------+--------------+---------------+---------------+ Dim | mm inch | mm inch | mm inch | mm inch | -------------------------------------------------------------------------- s | 12 1/2 | 12 1/2 | 12 1/2 | 12 1/2 | a | 427 16 13/16 | 428 16 7/8 | 399 15 13/16 | 405 16 | h | 49 1 15/16 | 48 1 7/8 | 60 2 3/8 | 57 2 1/4 | L1 | 907 35 11/16 | 960 37 13/16 | 995 39 3/16 | 961 37 13/16 | L2 | 804 31 11/16 | 813 32 | 813 32 | 810 31 15/16 | Z | 360 14 3/16 | 433 17 | 448 17 5/8 | 470 18 1/2 | X | 240 9 7/16 | 300 11 13/16 | 314 12 3/8 | 316 12 7/16 | Code:
GH10n3 ======================= Ch. Freq R-Gain R-in X-in SWR NetGain -------------------------------------------------------- 171 8.08 256.81 -499.31 5.06 5.49 174 9.11 231.29 -171.44 1.99 8.61 7 177 9.46 266.23 12.45 1.14 9.44 180 9.58 336.79 130.76 1.53 9.39 8 183 9.6 438.92 194.54 1.91 9.15 186 9.57 557.45 189.96 2.15 8.95 9 189 9.52 649.62 108.94 2.24 8.83 192 9.45 666.92 -12.84 2.22 8.77 10 195 9.36 609.35 -111.47 2.12 8.76 198 9.27 520.17 -155.26 1.95 8.79 11 201 9.15 435.78 -152.02 1.74 8.82 204 9.01 370.32 -119.47 1.51 8.83 12 207 8.83 325.97 -69.96 1.27 8.77 210 8.59 302.42 -9.27 1.03 8.59 13 213 8.24 302.07 60.93 1.22 8.2 216 7.74 334.63 139.65 1.57 7.52 219 7.01 424.63 216.01 1.98 6.51 ....................................................... 467 13.37 289.63 -32.3 1.12 13.36 14 473 13.75 295.63 -57.54 1.21 13.71 15 479 14.08 282.73 -67.07 1.27 14.02 16 485 14.34 266.78 -62.95 1.29 14.27 17 491 14.5 249.68 -49.03 1.29 14.43 18 497 14.58 234.07 -20 1.3 14.51 19 503 14.65 237.36 24.94 1.29 14.58 20 509 14.76 267.13 59.15 1.27 14.7 21 515 14.82 298.55 74.65 1.28 14.75 22 521 14.82 327.56 85.09 1.33 14.73 23 527 14.8 359.82 90.91 1.39 14.68 24 533 14.77 394.49 87.42 1.45 14.62 25 539 14.73 426.14 73.11 1.5 14.55 26 545 14.7 450.03 51.13 1.53 14.5 27 551 14.68 464.88 26.17 1.56 14.47 28 557 14.67 471.88 1.89 1.57 14.45 29 563 14.67 473.1 -19.67 1.58 14.44 30 569 14.67 470.65 -37.62 1.59 14.44 31 575 14.66 466.41 -51.81 1.59 14.43 32 581 14.64 462.05 -62.58 1.59 14.41 33 587 14.59 459.22 -70.79 1.59 14.36 34 593 14.49 459.48 -78.39 1.61 14.25 35 599 14.37 462.97 -89.1 1.64 14.11 36 605 14.31 465.57 -106.52 1.68 14.02 37 611 14.37 461.02 -128.46 1.73 14.05 38 617 14.52 448.43 -148.78 1.76 14.18 39 623 14.69 431.09 -164.65 1.78 14.33 40 629 14.85 411.32 -176.26 1.8 14.48 41 635 14.99 389.92 -184.18 1.81 14.62 42 641 15.12 367.14 -188.48 1.81 14.74 43 647 15.24 343.31 -188.89 1.81 14.86 44 653 15.35 318.95 -185.04 1.81 14.97 45 659 15.46 294.81 -176.7 1.8 15.09 46 665 15.56 271.74 -163.79 1.78 15.21 47 671 15.65 250.62 -146.55 1.74 15.32 48 677 15.71 232.22 -125.47 1.71 15.4 49 683 15.72 216.93 -101.27 1.66 15.44 50 689 15.64 204.7 -74.53 1.62 15.39 51 695 15.44 195.21 -45.27 1.6 15.2 52 701 15.11 188.52 -12.94 1.6 14.87 707 14.61 185.4 23.11 1.63 14.35 GH8n3 ======================= Ch. Freq R-Gain R-in X-in SWR NetGain -------------------------------------------------------- 171 9.23 430.41 -412.05 3.13 7.89 174 9.71 388.99 -155.22 1.68 9.42 7 177 9.81 413.22 -18.91 1.38 9.7 180 9.77 458.11 48.68 1.56 9.56 8 183 9.67 502.68 70.44 1.73 9.35 186 9.56 534.54 63.59 1.82 9.18 9 189 9.44 549.3 43.61 1.85 9.04 192 9.33 549.25 22.2 1.84 8.94 10 195 9.23 539.92 5.78 1.8 8.86 198 9.13 526.84 -3.56 1.76 8.79 11 201 9.05 514.16 -6.27 1.71 8.74 204 8.97 504.58 -3.8 1.68 8.68 12 207 8.91 499.79 2.14 1.67 8.63 210 8.85 500.93 9.81 1.67 8.57 13 213 8.79 508.92 17.33 1.7 8.49 216 8.74 524.63 22.46 1.75 8.4 219 8.69 548.74 22.09 1.83 8.3 ....................................................... 467 13.74 185.86 -80.76 1.79 13.38 14 473 13.87 202.7 -47.29 1.55 13.67 15 479 13.97 223.22 -19.89 1.36 13.87 16 485 14.05 246.06 1 1.22 14.01 17 491 14.12 269.6 15.44 1.13 14.1 18 497 14.19 292.22 24.11 1.09 14.18 19 503 14.25 312.7 28.26 1.11 14.24 20 509 14.3 330.57 29.46 1.14 14.28 21 515 14.36 346.14 29.1 1.18 14.33 22 521 14.39 360.26 27.91 1.22 14.35 23 527 14.39 373.69 25.78 1.26 14.33 24 533 14.35 386.45 22.25 1.3 14.28 25 539 14.29 398.06 17.33 1.33 14.2 26 545 14.24 408.34 11.54 1.36 14.14 27 551 14.19 417.56 5.27 1.39 14.07 28 557 14.17 426.01 -1.42 1.42 14.04 29 563 14.15 433.86 -8.62 1.45 14 30 569 14.15 441.13 -16.42 1.47 13.99 31 575 14.15 447.81 -24.86 1.5 13.97 32 581 14.16 453.9 -33.93 1.53 13.97 33 587 14.17 459.47 -43.7 1.56 13.96 34 593 14.18 464.62 -54.32 1.58 13.95 35 599 14.18 469.4 -66.18 1.62 13.93 36 605 14.19 473.57 -79.92 1.65 13.92 37 611 14.2 476.3 -96.25 1.69 13.9 38 617 14.23 476.03 -115.37 1.73 13.91 39 623 14.29 470.97 -136.41 1.78 13.94 40 629 14.37 460.04 -157.4 1.81 13.99 41 635 14.47 443.35 -176.16 1.85 14.07 42 641 14.58 421.89 -190.98 1.87 14.16 43 647 14.7 396.98 -200.86 1.89 14.27 44 653 14.82 369.92 -205.26 1.9 14.38 45 659 14.93 341.86 -204.01 1.9 14.49 46 665 15.03 313.84 -197.08 1.88 14.6 47 671 15.11 286.81 -184.58 1.86 14.7 48 677 15.18 261.6 -166.68 1.82 14.79 49 683 15.21 239.03 -143.61 1.78 14.86 50 689 15.19 219.81 -115.68 1.72 14.88 51 695 15.1 204.61 -83.13 1.66 14.83 52 701 14.92 194.16 -46.16 1.61 14.68 707 14.6 189.32 -4.93 1.59 14.37 GH6n3 ======================= Ch. Freq R-Gain R-in X-in SWR NetGain -------------------------------------------------------- 171 9.38 582.83 -616.95 4.41 7.18 174 9.74 461.54 -292.53 2.39 8.94 7 177 9.79 445.98 -133.7 1.71 9.48 180 9.72 456.82 -54.85 1.56 9.51 8 183 9.6 468.65 -19.24 1.57 9.38 186 9.47 472.55 -5.13 1.58 9.25 9 189 9.34 467.95 1.26 1.56 9.13 192 9.22 457.92 7.52 1.53 9.03 10 195 9.11 446.1 16.9 1.49 8.94 198 9.02 435.39 30.2 1.46 8.86 11 201 8.93 427.76 47.18 1.46 8.78 204 8.85 424.54 67.31 1.48 8.68 12 207 8.78 426.77 90.04 1.54 8.58 210 8.72 435.61 114.9 1.63 8.47 13 213 8.66 452.55 141.38 1.75 8.33 216 8.6 479.81 168.67 1.89 8.16 219 8.55 520.71 195.14 2.07 7.99 ....................................................... 467 13.52 200.78 -56.34 1.59 13.29 14 473 13.61 229.49 -24.95 1.33 13.52 15 479 13.67 260.24 -3.96 1.15 13.65 16 485 13.71 290.04 7.25 1.04 13.71 17 491 13.74 316.27 10.59 1.07 13.74 18 497 13.76 337.53 8.85 1.13 13.74 19 503 13.78 353.89 4.73 1.18 13.75 20 509 13.8 366.43 0.14 1.22 13.76 21 515 13.8 376.55 -4.08 1.26 13.74 22 521 13.78 385.39 -7.91 1.29 13.71 23 527 13.74 393.45 -11.73 1.31 13.66 24 533 13.68 400.76 -15.69 1.34 13.59 25 539 13.61 407.43 -19.61 1.36 13.51 26 545 13.57 413.87 -23.38 1.39 13.45 27 551 13.56 420.47 -27.28 1.41 13.43 28 557 13.56 427.32 -31.71 1.44 13.42 29 563 13.58 434.31 -37.02 1.47 13.42 30 569 13.6 441.21 -43.44 1.5 13.42 31 575 13.62 447.73 -51.08 1.53 13.43 32 581 13.65 453.6 -59.98 1.56 13.44 33 587 13.68 458.55 -70.1 1.59 13.45 34 593 13.71 462.32 -81.38 1.62 13.46 35 599 13.74 464.63 -93.75 1.65 13.47 36 605 13.78 465.15 -107.07 1.68 13.49 37 611 13.84 463.5 -121.09 1.71 13.53 38 617 13.91 459.35 -135.38 1.74 13.58 39 623 13.98 452.49 -149.37 1.77 13.63 40 629 14.07 442.92 -162.43 1.8 13.7 41 635 14.16 430.81 -174 1.82 13.78 42 641 14.25 416.4 -183.6 1.83 13.86 43 647 14.35 399.98 -190.8 1.84 13.95 44 653 14.43 381.89 -195.2 1.85 14.02 45 659 14.52 362.53 -196.45 1.85 14.12 46 665 14.6 342.31 -194.2 1.84 14.2 47 671 14.67 321.76 -188.12 1.82 14.28 48 677 14.73 301.45 -177.91 1.79 14.37 49 683 14.76 282.07 -163.35 1.75 14.43 50 689 14.76 264.43 -144.25 1.68 14.47 51 695 14.72 249.42 -120.57 1.61 14.48 52 701 14.6 238.08 -92.39 1.51 14.42 707 14.39 231.5 -59.99 1.41 14.26 GH4n3 ======================= Ch. Freq R-Gain R-in X-in SWR NetGain -------------------------------------------------------- 171 9.25 480.26 -600.55 4.51 6.99 174 9.73 400.55 -300.01 2.42 8.91 7 177 9.83 398.74 -144.31 1.65 9.56 180 9.77 417.54 -61.69 1.45 9.62 8 183 9.66 436.98 -20.34 1.46 9.5 186 9.53 449.47 -1.17 1.5 9.35 9 189 9.41 454.02 8.26 1.51 9.22 192 9.29 452.94 15.31 1.51 9.11 10 195 9.18 449.35 23.56 1.51 9 198 9.08 445.98 34.25 1.5 8.9 11 201 8.99 444.89 47.45 1.51 8.8 204 8.91 447.57 62.71 1.54 8.71 12 207 8.84 455.24 79.38 1.6 8.6 210 8.77 469.1 96.66 1.67 8.49 13 213 8.71 490.56 113.45 1.77 8.36 216 8.66 521.36 128.06 1.89 8.23 219 8.61 563.66 137.63 2.03 8.08 ....................................................... 467 13.21 203.37 -73 1.63 12.96 14 473 13.3 240.41 -44.8 1.32 13.22 15 479 13.33 277.38 -34.12 1.15 13.31 16 485 13.32 306.54 -37.95 1.14 13.3 17 491 13.28 323.56 -48.99 1.19 13.25 18 497 13.24 329.51 -59.83 1.24 13.19 19 503 13.21 328.53 -66.33 1.26 13.15 20 509 13.18 324.75 -67.65 1.26 13.12 21 515 13.17 320.96 -64.66 1.24 13.12 22 521 13.16 318.62 -58.71 1.22 13.12 23 527 13.17 318.32 -51.05 1.19 13.14 24 533 13.19 320.23 -42.63 1.16 13.16 25 539 13.22 324.24 -34.16 1.14 13.2 26 545 13.25 330.18 -26.17 1.14 13.23 27 551 13.27 337.86 -19.04 1.14 13.25 28 557 13.29 347.04 -13.08 1.16 13.27 29 563 13.3 357.51 -8.54 1.19 13.27 30 569 13.3 369.04 -5.63 1.23 13.25 31 575 13.31 381.44 -4.52 1.27 13.25 32 581 13.3 394.48 -5.43 1.32 13.22 33 587 13.3 407.94 -8.58 1.36 13.2 34 593 13.3 421.5 -14.24 1.41 13.17 35 599 13.29 434.72 -22.69 1.46 13.14 36 605 13.29 447.01 -34.2 1.51 13.11 37 611 13.3 457.55 -48.9 1.56 13.09 38 617 13.32 465.3 -66.66 1.6 13.08 39 623 13.36 469.19 -86.93 1.65 13.09 40 629 13.4 468.29 -108.72 1.7 13.1 41 635 13.45 462.03 -130.71 1.74 13.12 42 641 13.5 450.28 -151.43 1.77 13.15 43 647 13.56 433.33 -169.43 1.8 13.19 44 653 13.61 411.91 -183.37 1.83 13.22 45 659 13.67 387.01 -192.19 1.84 13.27 46 665 13.72 359.88 -195.12 1.84 13.32 47 671 13.76 331.82 -191.75 1.83 13.37 48 677 13.79 304.15 -181.92 1.81 13.41 49 683 13.8 278.09 -165.74 1.77 13.45 50 689 13.76 254.8 -143.45 1.71 13.45 51 695 13.65 235.32 -115.4 1.64 13.39 52 701 13.46 220.71 -81.98 1.55 13.25 707 13.12 212.03 -43.65 1.47 12.96 Model (again scroll for each model): Code:
CM GH10n3 CE SY radius=0.003175 SY l1=0.381 SY g1=0.019 SY z1=0.037 SY l2=0.280 SY g2=0.009 SY z2=0.137 SY l3=0.556 SY g3=0.0055 SY z3=0.262 SY l4=0.511 SY g4=4e-3 SY z4=0.414 SY l5=0.270 SY g5=4e-3 SY z5=0.592 SY x=-0.081 SY a1=0.196 SY a2=0.192 SY a3=0.190 SY b=0.120 SY feed=0.0685 SY a1ma2=a1-a2 SY a1pa2=a1+a2 SY a1ma2pa3=a1ma2+a3 SY a1pa2pa3=a1pa2+a3 SY n_top_l=0.213588 SY n_b_l=b SY n_h=0.049287 SY n_b_z=a1pa2pa3*.7071+0.012 SY n_top_z=n_b_z+n_h SY n_back=-0.24027 SY n_refl_size=0.402098 SY n_refl_z=0.359698 SY n_refl_size1=0.453799 GW 1 23 0 -feed 0 0 -feed-0.70711*a1 0.70711*a1 radius GW 2 23 0 -feed-0.70711*a1 0.70711*a1 0 -feed-0.70711*a1ma2 0.70711*a1pa2 radius GW 3 23 0 -feed-0.70711*a1ma2 0.70711*a1pa2 0 -feed-0.70711*a1ma2pa3 0.70711*a1pa2pa3 radius GW 4 15 0 -feed-0.70711*a1ma2pa3 0.70711*a1pa2pa3 0 -feed-0.70711*a1ma2pa3-b 0.70711*a1pa2pa3 radius GW 5 45 x g1 z1 x l1+g1 z1 radius GW 6 33 x g2 z2 x l2+g2 z2 radius GW 7 65 x g3 z3 x l3+g3 z3 radius GW 8 61 x g4 z4 x l4+g4 z4 radius GW 8 33 x g5 z5 x l5+g5 z5 radius GW 13 7 0 -n_top_l n_top_z 0 -n_top_l n_b_z radius GW 14 15 0 -n_top_l n_b_z 0 -n_top_l-n_b_l n_b_z radius GX 20 010 GW 10 51 0 n_top_l n_top_z 0 -n_top_l n_top_z radius GW 15 95 n_back -n_refl_size n_refl_z n_back n_refl_size n_refl_z radius GX 40 001 GW 100 17 0 -feed 0 0 feed 0 radius*.8675 GW 16 107 n_back -n_refl_size1 0 n_back n_refl_size1 0 radius GE 0 LD 5 0 0 0 24900000 GN -1 EK EX 0 100 9 0 1 FR 0 0 0 0 800 0 RP 0 60 73 1001 0 0 3 5 EN ****************** CM GH8n3 CM CE SY radius=0.003175 SY l1=0.314 SY g1=0.018 SY z1=0.083 SY l2=0.340 SY g2=0.0305 SY z2=0.258 SY l3=0.417 SY g3=0.0425 SY z3=0.439 SY l4=0.302 SY g4=.054 SY z4=0.620 SY x=-0.081 SY a1=0.193 SY a2=0.193 SY a3=0.183 SY b=0.121 SY feed=0.0725 SY a1ma2=a1-a2 SY a1pa2=a1+a2 SY a1ma2pa3=a1ma2+a3 SY a1pa2pa3=a1pa2+a3 SY n_top_l=0.214173 SY n_b_l=b SY n_h=0.048478 SY n_b_z=a1pa2pa3*.7071+0.012 SY n_top_z=n_b_z+n_h SY n_b_ystart=-n_top_l '-feed-0.70711*a1ma2pa3-n_b_ysp SY n_b_yend=n_b_ystart-n_b_l SY n_back=-0.29961 SY n_refl_size=0.406309 SY n_refl_z=0.43301 SY n_refl_size1=0.479869 GW 1 23 0 -feed 0 0 -feed-0.70711*a1 0.70711*a1 radius GW 2 23 0 -feed-0.70711*a1 0.70711*a1 0 -feed-0.70711*a1ma2 0.70711*a1pa2 radius GW 3 21 0 -feed-0.70711*a1ma2 0.70711*a1pa2 0 -feed-0.70711*a1ma2pa3 0.70711*a1pa2pa3 radius GW 4 15 0 -feed-0.70711*a1ma2pa3 0.70711*a1pa2pa3 0 -feed-0.70711*a1ma2pa3-b 0.70711*a1pa2pa3 radius GW 5 37 x g1 z1 x l1+g1 z1 radius GW 6 41 x g2 z2 x l2+g2 z2 radius GW 7 49 x g3 z3 x l3+g3 z3 radius GW 8 35 x g4 z4 x l4+g4 z4 radius GW 11 7 0 -n_top_l n_top_z 0 n_b_ystart n_b_z radius GW 14 15 0 n_b_ystart n_b_z 0 n_b_yend n_b_z radius GX 20 010 GW 10 51 0 n_top_l n_top_z 0 -n_top_l n_top_z radius GW 15 95 n_back -n_refl_size n_refl_z n_back n_refl_size n_refl_z radius GX 40 001 GW 100 17 0 -feed 0 0 feed 0 radius*.8675 GW 16 113 n_back -n_refl_size1 0 n_back n_refl_size1 0 radius GE 0 LD 5 0 0 0 24900000 GN -1 EK EX 0 100 9 0 1 FR 0 0 0 0 800 0 RP 0 60 73 1001 0 0 3 5 EN ****************** CM GH6n3 CE SY radius=0.003175 SY l1=0.322 SY g1=0.022 SY z1=0.085 SY l2=0.328 SY g2=0.036 SY z2=0.299 SY l3=0.312 SY g3=0.0495 SY z3=0.590 SY x=-0.075 SY a1=0.184 SY a2=0.205 SY a3=0.171 SY b=0.124 SY feed=0.0755 SY a1ma2=a1-a2 SY a1pa2=a1+a2 SY a1ma2pa3=a1ma2+a3 SY a1pa2pa3=a1pa2+a3 SY n_top_l=0.19945 SY n_b_l=b SY n_h=0.059786 SY n_b_z=a1pa2pa3*.7071+.012 SY n_top_z=n_b_z+n_h SY n_b_ystart=-n_top_l '-feed-0.70711*a1ma2pa3-n_b_ysp SY n_b_yend=n_b_ystart-n_b_l SY n_back=-0.31458 SY n_refl_size=0.406713 SY n_refl_z=0.447715 SY n_refl_size1=0.497582 GW 1 23 0 -feed 0 0 -feed-0.70711*a1 0.70711*a1 radius GW 2 25 0 -feed-0.70711*a1 0.70711*a1 0 -feed-0.70711*a1ma2 0.70711*a1pa2 radius GW 3 21 0 -feed-0.70711*a1ma2 0.70711*a1pa2 0 -feed-0.70711*a1ma2pa3 0.70711*a1pa2pa3 radius GW 4 15 0 -feed-0.70711*a1ma2pa3 0.70711*a1pa2pa3 0 -feed-0.70711*a1ma2pa3-b 0.70711*a1pa2pa3 radius GW 5 39 x g1 z1 x l1+g1 z1 radius GW 6 39 x g2 z2 x l2+g2 z2 radius GW 7 37 x g3 z3 x l3+g3 z3 radius GW 11 7 0 -n_top_l n_top_z 0 n_b_ystart n_b_z radius GW 14 15 0 n_b_ystart n_b_z 0 n_b_yend n_b_z radius GX 20 010 GW 10 47 0 n_top_l n_top_z 0 -n_top_l n_top_z radius GW 15 97 n_back -n_refl_size n_refl_z n_back n_refl_size n_refl_z radius GX 40 001 GW 100 17 0 -feed 0 0 feed 0 radius*.8675 GW 16 117 n_back -n_refl_size1 0 n_back n_refl_size1 0 radius GE 0 LD 5 0 0 0 24900000 GN -1 EK EX 0 100 9 0 1 FR 0 0 0 0 800 0 RP 0 60 73 1001 0 0 3 5 EN ****************** CM GH4n3 CE SY radius=0.003175 SY l1=0.300 SY g1=0.018 SY z1=0.128 SY l2=0.312 SY g2=0.045 SY z2=0.444 SY x=-0.084 SY a1=0.196 SY a2=0.202 SY a3=0.171 SY b=0.122 SY feed=0.075 SY a1ma2=a1-a2 SY a1pa2=a1+a2 SY a1ma2pa3=a1ma2+a3 SY a1pa2pa3=a1pa2+a3 SY n_top_l=0.202458 SY n_b_l=b SY n_h=0.056971 SY n_b_z=a1pa2pa3*.7071+.012 SY n_top_z=n_b_z+n_h SY n_b_ystart=-n_top_l '-feed-0.70711*a1ma2pa3-n_b_ysp SY n_b_yend=n_b_ystart-n_b_l SY n_back=-0.31613 SY n_refl_size=0.405376 SY n_refl_z=0.470002 SY n_refl_size1=0.480585 GW 1 23 0 -feed 0 0 -feed-0.70711*a1 0.70711*a1 radius GW 2 25 0 -feed-0.70711*a1 0.70711*a1 0 -feed-0.70711*a1ma2 0.70711*a1pa2 radius GW 3 21 0 -feed-0.70711*a1ma2 0.70711*a1pa2 0 -feed-0.70711*a1ma2pa3 0.70711*a1pa2pa3 radius GW 4 15 0 -feed-0.70711*a1ma2pa3 0.70711*a1pa2pa3 0 -feed-0.70711*a1ma2pa3-b 0.70711*a1pa2pa3 radius GW 5 35 x g1 z1 x l1+g1 z1 radius GW 6 37 x g2 z2 x l2+g2 z2 radius GW 11 7 0 -n_top_l n_top_z 0 n_b_ystart n_b_z radius GW 14 15 0 n_b_ystart n_b_z 0 n_b_yend n_b_z radius GX 20 010 GW 10 49 0 n_top_l n_top_z 0 -n_top_l n_top_z radius GW 15 95 n_back -n_refl_size n_refl_z n_back n_refl_size n_refl_z radius GX 40 001 GW 100 17 0 -feed 0 0 feed 0 radius*.8675 GW 16 113 n_back -n_refl_size1 0 n_back n_refl_size1 0 radius GE 0 LD 5 0 0 0 24900000 GN -1 EK EX 0 100 9 0 1 FR 0 0 0 0 800 0 RP 0 60 73 1001 0 0 3 5 EN |
#73 |
nikiml,
nice work, looks promising! |
#74 |
nikiml, you missed the other NAROD dimension in the above drawings, previously you called C.
#75 |
No, this dimension is fixed to be equal to the jeds b dimension.
see the equal segment symbols on the "drawing". |
