#46 |
Karyudo:
One set of dimensions is found in the .pdf file in post #92 (at page 7) of the following thread: http://www.digitalhome.ca/forum/showthread.php?t=99907 This design appears to be among the best in excellent gain at reasonable size. The rest of that thread has many helpful designs and tips for a DBGH with NARODs. The newer "top-hat" version of NAROD design appears to be helping out as well, although I'm not sure if the top-hat design and measurements have been optimized for this particular version of DBGH (others can chime in on that; I think it's being optimized for other GH versions right now). |
#47 |
Karyudo,
Those models are mods of the JED's antennas. You can just use his dimensions and I have posted dimensions for the additional elements for two of the three models in the thread. Check out the 3d view to get an idea of how the dimensions are to be applied. |
#48 | ||
Note to Stampeder: This discussion should really be moved to the Software 4nec2 modeler's thread, but I leave that to your discretion ================= 300Ohm, In reference to your post #39 http://www.digitalhome.ca/forum/show...2&postcount=39 Quote:
1. The plots of Gain vs auto-seg per 1/2 wave for SBGH, show a significant drop in gain over a narrow range from 10 to 13 segments per1/2 wave. Above 13, the gain results are reasonably constant (ie good convergence). In the case of DBGH plots, I wonder if those models were collinear or mesh screen or both? There was no discussion in the thread that I could find, that discussed how auto-segmentation actually calculates the segments for each element and what that implies for larger models. As all modelers who post results on this forum should know, the minimum segmentation recommended by L. B. Cebik in his "Beginner's Guide to NEC Modeling" is 10 segments per 1/2 wave at the design frequency of the antenna. So I ignore the Snowman53's plot results for < 10 segments per 1/2 wave. 2. As I mentioned previously, my experience with convergence tests on manually segmented models at 10 -20 segments per 1/2 wave, have never shown anything close to a 1 1/4dB difference. I suspect that Snowman53's auto-segmentation results might actually be characterizing the auto-segmentation algorithm, rather than antenna model differences at the 10 -13 auto-seg range. It is unfortunate, that a manual segmented model was not compared with an auto-seg model, since that would answer my suspicion. However your GH6.3Narod_with_Screen model presents an opportunity for any modeler to investigate that difference ! I propose this Modeling Challenge: Take the GH6.3-Narod_with Screen model by 300Ohm in post #31 of this thread and make a manual segment version using the design freq of 584mHz with 10 segments per 1/2 wave. You can use a smaller segmentation density for modeling the mesh screen reflector. If you are really keen, you could show the effect of varying the segmentation of the mesh screen from a very small density up to 10 segments per 1/2 wave. (1) Run a sweep 461 to 707; step 12 and compare the gains. What is the max difference between this manual segmented model vs the auto-segmentation 22 at 800Mhz model? A final thought: In his post summary, Snowman53 stated: Quote:
"I am not sure one can trust NEC to provide consistent values between different types of antennas which may use different segment sizes." Now if the segmentation is not done correctly due to modeler's in-experience, or other cause, this statement is true, but if the models follow all the the segmentation rules correctly, I don't believe this statement to be true. If it was, it would mean that all the excellent work by Ken Nist comparing commercial antennas would be in doubt as well. I think the trust that Snowman53 is unclear about concerning different types of antennas needs an answer and I totally agree with his statement "I would welcome a discourse on this topic with the resident modeling wizards." Perhaps the "resident modeling wizards" will seriously take a look at my modeling challenge. I am reminded of that old expression .... "You can lead a horse to water, but you can't make him drink" The challenge has been presented .... any takers? Cheers [ Oh,Oh .... I hear Zapperman calling me...so gotta go and get back to work ....Cya later] Last edited by Autofils; 2010-06-07 at 12:43 PM. Reason: Corrected Reference link to post #39 |
#49 | |
Snowman53 did present a good argrument. I also think its best to get more modelers into this discussion , rather than just you and me alone. holl_ands will probably be back, and maybe Snowman53 too. mclapp, since he's very good with EZNEC can provide some insight too. And maybe we can get some more Mana_gal modelers into the discussion. And maybe Arie Voors too. Hes posted on this website in your absence, and likes us too. So has Dr. Natan Cohen, the Fractal Guy, the originator of the fractal antenna. In the meanwhile, its not as important as you finishing your website for example. For now, Ill stick with the convienent and safe auto-segmentation of 21 or 22 except for antennas of very high segmentation, like the 91XG or CM4251, DBGH Mesh or Quad or modeling vhf oddballs like stampeders CM1111 or my CM1221, heh.
#50 | |
With reference to 300Ohm's post #49 -> http://www.digitalhome.ca/forum/show...5&postcount=49.
I would suggest that you enlarge the scope of the discussion to think about collectively generating a more detailed modeler's guideline that Stampeder could make into a "sticky" For me, there are really two important questions that snowman53's auto-segmentation analysis raises. I had mentioned them in my previous posts on this subject, but I guess I wasn't that clear. So let me have another go and provide some points that might start the discussion with a wider viewpoint. Question 1. How to determine an antenna model's "reliability" for posted results of Gain/Swr etc The late L. B. Cebik (W4RNL) pioneered the use of MoM nec programs in the ARRL as a better way to compare commercial antennas for Radio Hams, and to provide a software tool to better design "Home-Brew" Radio Ham antennas covering a wide range from 80m up to "Moon-Bounce" frequencies. His recommendation for determining a model's reliability is to run two tests: not only AGT at at least one frequency (within the designed bandwidth), BUT one should also run Convergence Tests, to determine how increased segmentation affects the results of a specific nec model. The value of these two tests is simply this: It is applied to a specific antenna model, hence comparisons of models of different antennas that have been found to be "reliable" via these two tests, provides the best and only assurance that the comparison is valid. The AGT test should be done at at least one frequency inside the designed bandwidth and Convergence tests should be done from the minimum recommended density of 10 segments per 1/2 wave up to the max limit of segmentation that meets the segmentation rules. In 4nec2, Arie has developed a Convergence test that does exactly that. It is the "Conv-test" function in the Calculate->Start optimizer (F12) tab of the main window of 4nec2. I would recommend that you ensure your Auto-segmentation setting is disabled before running the Convergence and AGT tests. If you have never run the Conv-test function in 4nec2, take a close look at it. It is an extremely powerful tool that Arie has built into 4nec2 ! I really believe that running both tests will provide the answer to Snowman53's query "I am not sure one can trust NEC to provide consistent values between different types of antennas which may use different segment sizes." Question 2. Why is Auto-segmentation used ? Is it ever Disabled ? ...and other questions Auto-segmenation is a useful computer aid for 4nec2 modelers, especially when the model is of an antenna with complex geometry. Snowman53's analysis shows that setting auto-seg to >13 gives good convergence on the specific SBGH and DBGH models that he considered in his analysis. It does not necessarily imply that all models will be reliable if you use auto-seg at a setting >13 (say 21 or 22). Instead, you should test each specific model using AGT and Covergence tests. That will give a measure of the model's reliability; using auto-seg does not give such assurances. My modeling challenge was geared to explore what the auto-seg algorithm in 4nec2 actually does for complex antenna geometries, including a mesh screen. I was not familiar with the details of the snowman53 models, hence my suggestion for the GH6.3-narod with Screen. Feel free to explore with any other model. Personally I don't use auto-seg. From what I understand, it is very useful when first setting up your model segmentation and should be used when running sweep optimizations. I suspect that most other times your should disable auto-segmentation. There might be some other strange effects that others have noticed, using auto-seg. You probably have the most experience of anyone on this forum with mesh-screen models; would you recommend using auto-seg with mesh screens? From Arie's help file, it's interesting to note that you can selectively turn-off auto-segs for specific wire elements in your model via a preceding + <sign>. This would allow the modeler some control over the auto-seg algorithm. I see more and more new comers to 4nec2 modeling on this forum. I know from my journey that there is lots to learn and even more to continue to learn - for all of us. I really believe a more detailed 4nec2 guideline "sticky" that provides some explanation on these subjects would be very useful and would further grow the reputation for DigitalHome.ca as the world's best modeling forum. Anyway...time to go... I hope folks find this helpful in better defining my thoughts. I'm way over my allotted time... you know ...Zapperman is calling ...so it's back to "kompozer" and more html stuff. 4NEC2 Auto-segmentation Help Notes Code:
Auto-segmentation When optimizing and/or sweeping antenna performance, it is likely thatdimensions and/or frequencies are changing, so it is possible that certain NEC requirements, such as the minimum number of segments per half-wave are not met any more. To overcome this problem, Auto-Segmentation is used. If this feature is enabled (See Settingssettings on Main window), each calculation/optimization/sweeping step, the wire length for each wire is checked against the actual wave-length and the specified number of segments per wire, and the position for voltage/current sources, RLC-loading and transmission lines is updated. If a certain number of segments is already specified in the input file, at least this number of segments is set with auto-segmentation. This to avoid auto-segmentation decrease the number of segments specified for critical regions. If you do not want to specify a minimum, set the number of segments to one. If the number of segments is preceded by a “+” sign the number of segments is fixed, meaning, the segments for this wire are not affected by the auto- segmentation process. When enabling the Auto-Segmentation feature, you are asked to specify the number of segments per half-wave. Although, mostly accuracy improves if more segments are specified, also the computation time is increased. For ‘simple’ structures, without sharp angles, a value from 10 to 20 will be sufficient. If precise impedance values are required or if wires joining at sharp angles are used more segments could be required. If you are not sure what amount to specify, please use increasing values and compare the results. (You could do this using the Sweepereval function). Also abrupt current changes on the structure might indicate an insufficient number of segments. One place more segments aren’t better is if wires of different diameters are connected. If computer performance is an issue, you could consider not to the use the auto-segmentation feature. If this feature is disabled, the processing especially for large input files with many wires is speed-up. |
#51 |
A slightly conservative mod. This is because I fixed the horizontal legs length to be the same and I fixed the spacing between the active element and the narods to be 12mm. I believe this model won't produce the unequal segmentation warning.
Nec code: Code:
CE SY radius=0.003175 SY hat_rad=0.003175 '0.0010265 SY l1=0.300 SY g1=0.018 SY z1=0.128 SY l2=0.312 SY g2=0.045 SY z2=0.444 SY x=-0.084 SY a1=0.196 SY a2=0.202 SY a3=0.171 SY b=0.122 SY feed=0.075 SY a1ma2=a1-a2 SY a1pa2=a1+a2 SY a1ma2pa3=a1ma2+a3 SY a1pa2pa3=a1pa2+a3 SY n_top_l=0.20747 SY n_b_l=0.122 SY n_z_sp=0.0105 SY n_h=0.053322 SY n_b_z=a1pa2pa3*.7071+n_z_sp+hat_rad-radius SY n_top_z=n_b_z+n_h SY n_b_ystart=-n_top_l '-feed-0.70711*a1ma2pa3-n_b_ysp SY n_b_yend=n_b_ystart-n_b_l SY n_back=-0.3034 SY n_refl_size=0.424505 SY n_refl_z=0.459371 SY n_refl_size1=0.475897 GW 1 23 0 -feed 0 0 -feed-0.70711*a1 0.70711*a1 radius GW 2 25 0 -feed-0.70711*a1 0.70711*a1 0 -feed-0.70711*a1ma2 0.70711*a1pa2 radius GW 3 21 0 -feed-0.70711*a1ma2 0.70711*a1pa2 0 -feed-0.70711*a1ma2pa3 0.70711*a1pa2pa3 radius GW 4 15 0 -feed-0.70711*a1ma2pa3 0.70711*a1pa2pa3 0 -feed-0.70711*a1ma2pa3-b 0.70711*a1pa2pa3 radius GW 5 35 x g1 z1 x l1+g1 z1 radius GW 6 37 x g2 z2 x l2+g2 z2 radius GW 11 7 0 -n_top_l n_top_z 0 n_b_ystart n_b_z hat_rad GW 14 15 0 n_b_ystart n_b_z 0 n_b_yend n_b_z hat_rad GX 20 010 GW 10 49 0 n_top_l n_top_z 0 -n_top_l n_top_z hat_rad GW 15 101 n_back -n_refl_size n_refl_z n_back n_refl_size n_refl_z radius GX 40 001 GW 100 17 0 -feed 0 0 feed 0 radius*.8675 GW 16 113 n_back -n_refl_size1 0 n_back n_refl_size1 0 radius GE 0 LD 5 0 0 0 24900000 GN -1 EK EX 0 100 9 0 1 FR 0 0 0 0 800 0 RP 0 60 73 1001 0 0 3 5 EN Code:
Ch. Freq RawGain R-in X-in SWR NetGain 171 9.69 428.61 -240.2 2.1 9.1 174 9.61 415.59 -123.24 1.61 9.37 7 177 9.5 417.9 -57.03 1.44 9.35 180 9.38 423.34 -18.55 1.42 9.25 8 183 9.27 427.45 4.69 1.43 9.13 186 9.17 429.21 20.15 1.44 9.03 9 189 9.08 429.2 32.33 1.45 8.93 192 9 428.61 43.71 1.46 8.85 10 195 8.92 428.7 55.54 1.47 8.76 198 8.86 430.59 68.28 1.5 8.68 11 201 8.8 435.29 81.99 1.54 8.6 204 8.75 443.7 96.48 1.6 8.51 12 207 8.7 456.79 111.34 1.67 8.42 210 8.66 475.69 125.91 1.76 8.32 13 213 8.63 501.76 139.13 1.86 8.22 216 8.6 536.72 149.19 1.98 8.1 219 8.57 582.52 152.98 2.12 7.97 467 13.15 204.81 -65.08 1.59 12.92 470 13.24 222.9 -46.48 1.41 13.11 14 473 13.29 241.94 -34.18 1.28 13.22 476 13.31 261.25 -26.23 1.18 13.28 15 479 13.33 279.84 -22.58 1.11 13.32 482 13.33 296.69 -22.82 1.08 13.32 16 485 13.32 310.97 -26.21 1.1 13.31 488 13.31 322.14 -31.78 1.13 13.29 17 491 13.29 330.03 -38.46 1.17 13.26 494 13.26 334.83 -45.28 1.2 13.22 18 497 13.24 337 -51.48 1.22 13.2 500 13.21 337.1 -56.54 1.24 13.16 19 503 13.18 335.75 -60.18 1.25 13.13 506 13.16 333.51 -62.32 1.25 13.11 20 509 13.14 330.85 -63.03 1.25 13.09 512 13.12 328.13 -62.44 1.24 13.07 21 515 13.11 325.63 -60.74 1.23 13.06 518 13.1 323.53 -58.13 1.22 13.06 22 521 13.1 321.96 -54.8 1.21 13.06 524 13.1 320.99 -50.92 1.19 13.07 23 527 13.11 320.66 -46.65 1.18 13.08 530 13.11 320.98 -42.13 1.16 13.09 24 533 13.12 321.95 -37.48 1.15 13.1 536 13.14 323.55 -32.79 1.14 13.12 25 539 13.15 325.76 -28.16 1.13 13.13 542 13.16 328.54 -23.66 1.13 13.14 26 545 13.18 331.88 -19.37 1.13 13.16 548 13.19 335.73 -15.35 1.13 13.17 27 551 13.2 340.04 -11.64 1.14 13.18 554 13.22 344.78 -8.3 1.15 13.2 28 557 13.23 349.91 -5.36 1.17 13.2 560 13.24 355.37 -2.87 1.18 13.21 29 563 13.25 361.11 -0.85 1.2 13.21 566 13.25 367.09 0.68 1.22 13.21 30 569 13.26 373.26 1.71 1.24 13.21 572 13.26 379.58 2.23 1.27 13.2 31 575 13.26 386 2.24 1.29 13.19 578 13.26 392.49 1.74 1.31 13.18 32 581 13.25 399.03 0.73 1.33 13.16 584 13.25 405.59 -0.79 1.35 13.15 33 587 13.24 412.17 -2.83 1.37 13.13 590 13.24 418.75 -5.4 1.4 13.12 34 593 13.23 425.32 -8.55 1.42 13.1 596 13.22 431.86 -12.31 1.44 13.08 35 599 13.22 438.34 -16.74 1.47 13.06 602 13.22 444.69 -21.93 1.49 13.05 36 605 13.22 450.82 -27.93 1.51 13.04 608 13.22 456.61 -34.81 1.54 13.02 37 611 13.24 461.88 -42.6 1.56 13.03 614 13.25 466.48 -51.28 1.59 13.02 38 617 13.27 470.21 -60.81 1.61 13.03 620 13.3 472.91 -71.08 1.63 13.04 39 623 13.33 474.39 -81.96 1.66 13.06 626 13.36 474.56 -93.27 1.68 13.07 40 629 13.4 473.3 -104.83 1.7 13.1 632 13.43 470.56 -116.42 1.72 13.11 41 635 13.47 466.32 -127.85 1.74 13.14 638 13.5 460.58 -138.89 1.76 13.16 42 641 13.54 453.38 -149.33 1.77 13.19 644 13.58 444.8 -158.99 1.79 13.22 43 647 13.61 434.93 -167.66 1.8 13.24 650 13.65 423.9 -175.19 1.81 13.27 44 653 13.69 411.84 -181.43 1.82 13.31 656 13.72 398.93 -186.24 1.82 13.33 45 659 13.76 385.32 -189.53 1.83 13.37 662 13.79 371.21 -191.23 1.83 13.4 46 665 13.82 356.76 -191.27 1.82 13.43 668 13.85 342.17 -189.64 1.82 13.47 47 671 13.87 327.6 -186.33 1.81 13.49 674 13.89 313.23 -181.33 1.79 13.52 48 677 13.9 299.21 -174.67 1.78 13.55 680 13.91 285.71 -166.39 1.76 13.57 49 683 13.91 272.85 -156.52 1.73 13.59 686 13.9 260.79 -145.12 1.7 13.6 50 689 13.87 249.64 -132.23 1.67 13.59 692 13.82 239.54 -117.91 1.63 13.56 51 695 13.75 230.6 -102.21 1.59 13.52 698 13.66 222.95 -85.18 1.55 13.45 52 701 13.54 216.72 -66.88 1.52 13.35 704 13.38 212.04 -47.37 1.48 13.21 707 13.19 209.05 -26.71 1.46 13.04 710 12.95 207.91 -4.96 1.44 12.8 Top hat dimensions: Code:
-----------a-----------
| | a = 0.4149m
b | b = 0.0533m
| | c = 0.122m
-----c----- -----------
And the narod reflectors dimensions: Code:
------------L1------------
L0 = 0.9518m
-------------L0------------- L1 = 0.849m
L1_z = 0.4594m
X = 0.303m
X here is the distance between the active element and the narod reflectors plane
#52 | |
#53 |
A note to the DBGH builders who try to stack two of those.
It seems that the narod reflectors can be moved closer with no much gain loss, as long as the top and bottom narods are also are aslo moved away from the middle ( the optimizer knows exactly by how much). Thus one could may be try to have 5 narod reflectors for the whole DBGH... |
#54 |
With just the middle reflector. It has lower VHF gain and a small dip at ch 17-21. But the SWR is ok.
Code:
CM model segmentation is derived from autosegmentation 22 at 800Mhz CM for VHF AGT of 1 set the radius multiplier of the souce wire to 1 CM Wire 15 95 n_back1 -n_refl_size n_refl_z n_back1 n_refl_size n_refl_z radius CE SY radius=0.003175 SY hat_rad=0.003175 '0.0010265 SY l1=0.300 SY g1=0.018 SY z1=0.128 SY l2=0.312 SY g2=0.045 SY z2=0.444 SY x=-0.084 SY a1=0.196 SY a2=0.202 SY a3=0.171 SY b=0.122 SY feed=0.075 SY a1ma2=a1-a2 SY a1pa2=a1+a2 SY a1ma2pa3=a1ma2+a3 SY a1pa2pa3=a1pa2+a3 SY n_top_l=0.183474 SY n_b_l=0.129366 SY n_z_sp=0.012 SY n_h=0.051536 SY n_b_z=a1pa2pa3*.7071+n_z_sp+hat_rad-radius SY n_top_z=n_b_z+n_h SY n_b_ystart=-n_top_l '-feed-0.70711*a1ma2pa3-n_b_ysp SY n_b_yend=n_b_ystart-n_b_l SY n_back=-0.317 SY n_back1=x SY n_refl_size=0.4146 SY n_refl_z=0.726 SY n_refl_size1=0.442318 GW 1 23 0 -feed 0 0 -feed-0.70711*a1 0.70711*a1 radius GW 2 25 0 -feed-0.70711*a1 0.70711*a1 0 -feed-0.70711*a1ma2 0.70711*a1pa2 radius GW 3 21 0 -feed-0.70711*a1ma2 0.70711*a1pa2 0 -feed-0.70711*a1ma2pa3 0.70711*a1pa2pa3 radius GW 4 15 0 -feed-0.70711*a1ma2pa3 0.70711*a1pa2pa3 0 -feed-0.70711*a1ma2pa3-b 0.70711*a1pa2pa3 radius GW 5 35 x g1 z1 x l1+g1 z1 radius GW 6 37 x g2 z2 x l2+g2 z2 radius GW 11 7 0 -n_top_l n_top_z 0 n_b_ystart n_b_z hat_rad GW 14 15 0 n_b_ystart n_b_z 0 n_b_yend n_b_z hat_rad GX 20 010 GW 10 43 0 n_top_l n_top_z 0 -n_top_l n_top_z hat_rad GX 40 001 GW 100 17 0 -feed 0 0 feed 0 radius*.8675 GW 16 105 n_back1 -n_refl_size1 0 n_back1 n_refl_size1 0 radius GE 0 LD 5 0 0 0 24900000 GN -1 EK EX 0 100 9 0 1 FR 0 0 0 0 800 0 RP 0 60 73 1001 0 0 3 5 EN Code:
Ch. Freq RawGain R-in X-in SWR NetGain 171 5.31 458.77 61.19 1.58 5.09 7 177 5.89 473.08 12.08 1.58 5.67 8 183 6.27 409.56 -33.25 1.38 6.16 9 189 6.51 334.91 -15.11 1.13 6.49 10 195 6.67 290.98 37.68 1.14 6.65 11 201 6.78 277.93 102.23 1.43 6.64 12 207 6.85 292.55 171.94 1.77 6.5 13 213 6.89 339.51 245.61 2.14 6.28 219 6.9 436.62 317.89 2.52 6.01 467 12.38 212.36 -5.77 1.41 12.25 14 473 12.38 257.52 29.49 1.2 12.34 15 479 12.24 307.96 48.56 1.18 12.21 16 485 12 358.84 48.96 1.26 11.94 17 491 11.77 401.6 30.3 1.36 11.67 18 497 11.66 427.16 -0.43 1.42 11.53 19 503 11.69 434.26 -31.35 1.46 11.53 20 509 11.81 429.11 -54.77 1.47 11.65 21 515 11.95 418.52 -69.16 1.47 11.79 22 521 12.09 406.84 -75.91 1.45 11.94 23 527 12.22 396.34 -76.95 1.43 12.08 24 533 12.34 388.09 -73.96 1.4 12.22 25 539 12.45 382.58 -68.27 1.37 12.34 26 545 12.55 380.02 -60.92 1.35 12.45 27 551 12.64 380.49 -52.77 1.33 12.55 28 557 12.72 383.97 -44.59 1.32 12.64 29 563 12.8 390.39 -37.1 1.33 12.71 30 569 12.87 399.6 -31.04 1.35 12.77 31 575 12.93 411.31 -27.17 1.38 12.82 32 581 12.98 425.01 -26.26 1.43 12.84 33 587 13.03 439.96 -29.03 1.48 12.87 34 593 13.06 455.08 -36.02 1.53 12.86 35 599 13.08 469.03 -47.44 1.59 12.85 36 605 13.08 480.28 -62.95 1.65 12.81 37 611 13.07 487.46 -81.49 1.7 12.77 38 617 13.04 489.8 -101.41 1.74 12.71 39 623 12.99 487.55 -120.9 1.78 12.64 40 629 12.93 481.86 -138.85 1.81 12.55 41 635 12.88 473.98 -155.34 1.84 12.48 42 641 12.86 464.16 -171.29 1.87 12.44 43 647 12.88 451.38 -187.14 1.9 12.44 44 653 12.94 434.29 -202.03 1.93 12.48 45 659 13.03 412.39 -214.03 1.96 12.55 46 665 13.13 386.4 -221.13 1.98 12.63 47 671 13.23 357.9 -221.97 1.99 12.73 48 677 13.32 328.69 -215.94 1.97 12.83 49 683 13.38 300.46 -203.1 1.94 12.91 50 689 13.41 274.62 -183.85 1.89 12.98 51 695 13.39 252.25 -158.74 1.81 13.01 52 701 13.29 234.27 -128.34 1.71 12.98 53 707 13.09 221.47 -93.16 1.6 12.85 713 12.75 214.67 -53.65 1.48 12.58 Code:
| | a = 0.3669m
b | b = 0.0515m
| | c = 0.1294m
Last edited by nikiml; 2010-06-10 at 09:32 AM. Reason: removed unnecessary wires |
#55 |
Thank you nikiml for the simple GH4 with simple Top hat. This should work well for me.
#56 |
Having not built it, all I can say is:
I hope so! Post feedback. |
#57 | |
The FCC intial specs were for 6 db vhf-hi and 10 db uhf for the intended area coverage.
#58 |
This one is probably not for build. It is just to give ideas where the narod reflectors could possibly go:
Code:
CM model segmentation is derived from autosegmentation 22 at 800Mhz CM for VHF AGT of 1 set the radius multiplier of the souce wire to 1 CM CE SY radius=0.003175 SY hat_rad=0.003175 '0.0010265 SY l1=0.300 SY g1=0.018 SY z1=0.128 SY l2=0.312 SY g2=0.045 SY z2=0.444 SY x=-0.084 SY a1=0.196 SY a2=0.202 SY a3=0.171 SY b=0.122 SY feed=0.075 SY a1ma2=a1-a2 SY a1pa2=a1+a2 SY a1ma2pa3=a1ma2+a3 SY a1pa2pa3=a1pa2+a3 SY n_top_l=0.181961 SY n_b_l=0.120969 SY n_z_sp=0.012 SY n_h=0.050178 SY n_b_z=a1pa2pa3*.7071+n_z_sp+hat_rad-radius SY n_top_z=n_b_z+n_h SY n_b_ystart=-n_top_l '-feed-0.70711*a1ma2pa3-n_b_ysp SY n_b_yend=n_b_ystart-n_b_l SY n_back1=x SY n_refl_size=0.410447 SY n_refl_z=1.044516 SY n_refl_size1=0.415772 GW 1 23 0 -feed 0 0 -feed-0.70711*a1 0.70711*a1 radius GW 2 25 0 -feed-0.70711*a1 0.70711*a1 0 -feed-0.70711*a1ma2 0.70711*a1pa2 radius GW 3 21 0 -feed-0.70711*a1ma2 0.70711*a1pa2 0 -feed-0.70711*a1ma2pa3 0.70711*a1pa2pa3 radius GW 4 15 0 -feed-0.70711*a1ma2pa3 0.70711*a1pa2pa3 0 -feed-0.70711*a1ma2pa3-b 0.70711*a1pa2pa3 radius GW 5 35 x g1 z1 x l1+g1 z1 radius GW 6 37 x g2 z2 x l2+g2 z2 radius GW 11 7 0 -n_top_l n_top_z 0 n_b_ystart n_b_z hat_rad GW 14 15 0 n_b_ystart n_b_z 0 n_b_yend n_b_z hat_rad GX 20 010 GW 10 43 0 n_top_l n_top_z 0 -n_top_l n_top_z hat_rad GW 15 97 n_back1 -n_refl_size n_refl_z n_back1 n_refl_size n_refl_z radius GX 40 001 GW 100 17 0 -feed 0 0 feed 0 radius*.8675 GW 16 99 n_back1 -n_refl_size1 0 n_back1 n_refl_size1 0 radius GE 0 LD 5 0 0 0 24900000 GN -1 EK EX 0 100 9 0 1 FR 0 0 0 0 800 0 RP 0 60 73 1001 0 0 3 5 EN Code:
Ch. 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 Freq 171 177 183 189 195 201 207 213 219 467 473 479 485 491 497 503 509 515 521 527 533 539 545 551 557 563 569 575 581 587 593 599 605 611 617 623 629 635 641 647 653 659 665 671 677 683 689 695 701 707 713 RawGain 7.9 8.78 8.78 8.62 8.48 8.36 8.27 8.2 8.15 13.14 13.25 13.3 13.31 13.29 13.24 13.13 12.97 12.75 12.54 12.4 12.34 12.36 12.41 12.49 12.57 12.65 12.72 12.79 12.85 12.91 12.95 13 13.04 13.07 13.09 13.11 13.11 13.09 13.06 13.03 13.01 13.01 13.06 13.13 13.23 13.31 13.37 13.39 13.33 13.17 12.88 SWR 2.57 1.32 1.41 1.41 1.24 1.15 1.34 1.63 1.95 1.58 1.29 1.12 1.07 1.12 1.19 1.24 1.3 1.35 1.4 1.43 1.43 1.42 1.4 1.38 1.37 1.37 1.38 1.41 1.45 1.49 1.55 1.6 1.66 1.72 1.77 1.81 1.85 1.87 1.89 1.9 1.91 1.91 1.92 1.92 1.91 1.89 1.84 1.78 1.68 1.58 1.46 |
#59 |
I tried convergency test on the original Jed GH8 at freq of 590Mhz and it did not converge.
I am starting to think that maybe the AGT does not stay at 1 when 4nec2 does the convergence test. |
#60 | |
Re post 59:
j3d's nec files have a high segment count with a segment per 1/2 wave >>10, so that doesn't leave a lot of room for increased segmentation before you exceed the segmentation rules for len/rad parameter. He does this because he believes adjusting the wire radius of the Vsource to fine tune the AGT breaks nec sgmenation guidelines, but .... that's another topic for later discussion. Don't be overly concerned about the AGT test. Since it is calculated at a specific frequency, it will change at other frequencies. The 4nec2 help gives this guideline: Code:
Average-Gain-Test To check the reliability of your model, you can run an ‘average gain test(AGT). To run such a test, use the ‘Generate (F7)’ command, select ‘Far field pattern’ and check ‘Aver-Gain test’. Then click the ‘Generate’ button. When the ‘expert’ button is selected and using the lowest option-box, one should select the ‘1 – average gain’ option to perform this same test. (The other option-boxes could be left to 1:Ver/Hor/Tot field, 0: no norm, 0: power-gain). To get usefull test results 4nec2 automatically (temporary) removes all wire- and other resistive loading and (if specified) changes the gound-conditions to perfect-ground when doing the required calculations. The test-results are presented on the main (F2) form. The following gradation can be made for the Average-Gain-Test results: > 0.95 and < 1.05 Model is likely to be accurate > 0.90 and < 1.10 Model is usable for most purposes. > 0.80 and < 1.20 Model may be useful, but can be improved. < 0.80 or > 1.20 Model is questionable and should be refined. When the resulting value is below 0.8 or above 1.2 the value is displayed in red color. The db value between brackets can be used to correct the far-field pattern gain. The bandwidth of your UHF is Ch14-51 (470 to 698) mHz. The mid-freq is 584mHz. Set your frequency in the freq tab of the NEC Editor (new) to 584mHz. You will see that 4nec2 reports that freq and it's wavelength in the main window. The 1/2 wave for 584mHz is half of that value or 513/2 = 256.5mm or 0.2565m. At 10 segs per 1/2 wave, your seg-len (segment length is 25.65mm) The number of segs for the Vsource (tag 100) is it's (length / seg-len) In meters that's 0.15/0.02565 = 5.84 segs, which you round off to 5, because the Vsource must have an odd number of segments to ensure the Vsource is exactly at the center of Tag 100. Repeat the same process for all other tags, except round up the number of segs. (these can be even or odd rounded up integers) and that is your segmentation for 10segs per 1/2 wave at the mid UHF freq of your design. Now run conv-test and post your results of Gain vs total segments. Then we can discuss the degree of convergence. |
