#226 |
You still haven't given an economic reason for the owners of CTV to affiliate with a new locally owned CFPL. Why give up free BDU carriage to pay an affiliate?
#227 |
There is no way CTV will allow a CTV affiliate in London. They currently qualify for simsubs and FFC with their Toronto and KW stations. It would be a loss of revenue for them.
#228 | ||
The real issue for local broadcasting is competition for eyeballs with BDU services. Broadcast network viewing has declined steadily over the years because viewers want the programs on BDU specialty channels. Watching a BDU service rather than broadcast is the direct consequence of choice. Quote:
#229 |
If CTV were smart, they'd put their /A\ channels on CTV sub-channels where /A\ doesn't have transmitters (i.e. Kitchener, Toronto, etc). And vice versa for CTV where only /A\ has transmitters.
DMX 68' tower, HyGain HAM 5 rotator, Antennas Direct 91-XG & C5, Channel Master 7777 preamp, Siemens surge protection |
#230 | |
Secondly, this would degrade the picture quality of both stations, especially in scenes with fast motion. |
#231 | |
The PQ issue is debatable.
#232 | ||
Also the CRTC discourages the use of sub-channels. Quote:
#233 |
Corporate Supporter
Roger1818 that is a myth I’ve heard here before. I contacted CRTC about that and was pointed to a couple of official documents that said nothing about discouraging sub channels. What’s the source of your comment? I wonder what someone in the private broadcast industry says? I do think the US will show us how the business model works with sub channels.
60' Delhi tower,91XG,Y13-10,DB8,Tin Lee Traps,CM9521A,CM7777,CM7000,Winegard RC-1010 & HDA200,Samsung 32 LCD,2 WTV950Q Twinntech supports Digital Home Last edited by wilspin; 2011-01-25 at 07:54 PM. Reason: add more |
#234 |
Agreed with Wilspin: I've seen nothing that indicates the CRTC is discouraging sub channels.
With regards to PQ when sub channels are in use: My discussions with the technical staff at both CKVR (/A\ Barrie) and CFPL (/A\ London) indicate there are no immediate plans to go with high definition. They will be broadcasting in digital standard definition. I have viewed stations with two SD sub-channels, and the primary HD feed looks great (WNED PBS Buffalo, for example).
#235 | ||
#236 | ||
#237 |
This document is typical of all those involved in the Canadian digital conversion, ie. more of the same vagueness and lack of direction. The word "predisposition" defines to tendency or inclination, so I suppose one could assume that the CRTC will "favor" sub channels for new or novel applications BUT also not completely rule out existing OTA channels. How typically bureaucratic and wishy washy of them.
The "weak" wording could also keep the door open for some "good ole boy" behind the scenes maneuvering, as nothing is written in stone, and each sub channel application would be handled on a case by case basis. Anywho, that is my own interpretation. |
#238 |
I agree and that is why I said the discourage (not prohibit) the use of sub-channels.
#239 |
Corporate Supporter
This is why US channels are so important to our OTA crusade.
60' Delhi tower,91XG,Y13-10,DB8,Tin Lee Traps,CM9521A,CM7777,CM7000,Winegard RC-1010 & HDA200,Samsung 32 LCD,2 WTV950Q Twinntech supports Digital Home |
