SA8300 doesn't buffer live TV - Canadian TV, Computing and Home Theatre Forums
Old 2010-02-25, 05:14 PM   #1
thedukey
Default SA8300 doesn't buffer live TV
Hi all,
I'm having a weird problem with my SA8300 where randomly, it will not keep a buffer of my current channel i.e. I can't pause or rewind. However, if I change channel and come back, the buffer starts filling again, and I can pause and instant replay. The other thing I can do is start recording, but it won't record from the moment I started watching, but only from the moment I started recording.
I've change the internal hard drive, but to no avail... has this happened to anyone else before?
thedukey is offline
Old 2010-02-25, 05:49 PM   #2
Haven't heard of this complaint before that I recall. A cold reboot usually solves these sorts of odd glitches.
Some of us have found the "record from record press" instead of "record from channel change" issue and the way I get around it is to rewind to the start of the recording, then press record. Then it always records the entire segment, instead of just from "record press" onwards.
Useful post for those new to the forum:
57 is offline
Old 2010-02-28, 06:48 PM   #3
thedukey
Seems to be a known issue on Videotron. Guess I'll have to live with it for now.
thedukey is offline
