| View Poll Results: What do you think of Rogers Quick Start Guide? | |||
| Excellent |
4 | 1.32% |
| Somewhat Positive |
15 | 4.95% |
| Somewhat Negative |
44 | 14.52% |
| Terrible |
236 | 77.89% |
| No Opinion |
4 | 1.32% |
| Voters: 303. You may not vote on this poll | |||
#1 | |
My 3 cable boxes have the new guide today.
Edit by 57 - see the following great news from Hugh: http://www.digitalhome.ca/forum/show...66#post1057866
H550, H890, H1, SA8300, SA8300HD, SA940, PS3 SLIM 250GB, Panny TH42PX60U, Prima PS3227, Sammy BDP1500, Toshiba HDA3 Last edited by hugh; 2010-01-14 at 11:08 AM. Reason: Add Note |
Title says it. It's utterly useless, and causes an extra click to get to the guide itself (which is nothing to brag about in the first place).
Hi-tech. Way to go, Rogers! |
I kind of like the Feature. Apparently, Toronto doesn't have it yet, but areas around it do to the north and east.
Yeah Toronto's higher concentration of people makes it hard to handle in case of bugs... Always wise to roll out anything slowly.. But it will come soon enough. It just took about 6 months for Toronto to get the extra French HD channels after everyone outside the GTA got them... Seriously though, I'm sure they'll flip the switch on us by the weekend, unless something unexpected happens.
Well, this is damn annoying. My Harmony remote no longer works.
If you press GUIDE twice, it just takes you back to the show. If you press GUIDE twice on the original remote, you get the guide. Plus this quick start feature is stupid to begin with. I'll attempt reprogramming my Harmony to see if that helps. |
Three Harmonys and three different types of Rogers STB's. All work correctly when I press the guide button.
H550, H890, H1, SA8300, SA8300HD, SA940, PS3 SLIM 250GB, Panny TH42PX60U, Prima PS3227, Sammy BDP1500, Toshiba HDA3 |
My other Harmony worked fine.
It turns out this Harmony's GUIDE button was programmed as MENU. If you press the MENU button, it takes you to the Quick Start. If you press it again, then it just goes back to the show. So, I changed the GUIDE button to GUIDE as it's supposed to be and now it works fine. Too bad pressing the MENU button doesn't take you directly to the real guide. As far as I'm concerned, the Quick Start guide is just an annoying waste of time. |
I think the quick guide is clean and simple , well done Rogers! I like the grouping features and I think the graphical interface looks nice.
It's not the tru2way that I have seen, but not a bad start! |
#9 | |
Most likely it hasn't launched in your area yet that's all. |
#10 |
Location: Stouffville, Ont, Rogers Cable, SA8300HD, Samsung PN59D6500, Denon AVR-791
I have the new guide in Stouffville and it is annoying. I do not want another step to get to the IPG.
I called and complained yesterday that there is no option to turn this off and the first person stated as this is an upgrade they do not want an option to turn it off. My response is it seems more of a downgrade to me. Anyways I have now programmed my harmony remote guide to press guide twice. The only change I need to make is to leave the guide I have to press exit now if I am not going to a channel. |
#11 |
If I was in charge I would have gone with
click guide once -> IPG click guide twice -> new quick start menu or even better choice would be to tie it to a separate channel all together something along the lines of the how we have On Demand but ofcourse that wouldnt work for Rogers because they want to force blast us with ad's on this new menu |
#12 |
Sorry if these questions have been asked before....
-will I keep the recordings that are on my 8300HD when it gets updated? -if I am recording something when the update comes, will the box immediately reboot (as I'm assuming it will need too) and I lose that recording or will it wait until the recording ends? |
#13 |
BJC, the firmware update should be seamless. the reason they stagger the role out is to deal with problems more effectively. Frankly, it's best to be later in the roll-out after any implementation issues are resolved.
#14 | |
The more I use this the more I am annoyed. |
#15 |
And to add to that Harmony question, is there any image flicker present when pressing Guide twice? In other words, if you press it send Guide twice, is there any sign of this Quick Start abomination showing up on screen *before* the proper guide loads?
