Hitachi 51F510 rear-Projection info - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > HDTV: Front and Rear Projection Screens and Televisions
Old 2010-01-09, 08:02 PM   #1
dinosaur1
Default Hitachi 51F510 rear-Projection info
Should I remove the reflective screen cover?
Does anyone have basic audio and video calibration settings?
Thanks!
dinosaur1 is offline
Old 2010-01-09, 08:53 PM   #2
1. Sure, if you like, but probably not if you have small children or pets that can reach the screen. I assume you know the procedure.
2. There are no basic video settings as all TVs are unique. See the following post on the topic:
http://www.digitalhome.ca/forum/show...73&postcount=2
and the following post, useful for those new to the forum - FAQs, Search Tips, Optimization, etc:
57 is offline
Old 2010-01-09, 09:06 PM   #3
dinosaur1
So basically I remove the screws...slip off the screen....and I'm done?
Old 2010-01-09, 09:07 PM   #4
Screen assembly slides up towards the ceiling, watch out for the magic focus connections on the back of the screen assembly, most people put in a spacer in the channels where the protective screen was. Usually a 2-3 person job to take the screen assembly off due to bulk and the magic focus connections.
57 is offline
Old 2010-01-09, 09:20 PM   #5
dinosaur1
Hmmmmm, that's not worth it then. I have my eyes on a Panasonic
plasma. How much do you think I can Sell
this tv for?
Old 2010-01-09, 09:21 PM   #6
Most people don't get much and many give it away to anyone willing to take it away.
57 is offline
Old 2010-01-09, 09:28 PM   #7
dinosaur1
I had an offer of $450 but they backed out last second.
Do you know where I can find audio settings that make the speakers sound better? I set mine up a few different ways and I still don't like the sound quality.
Old 2010-01-09, 09:36 PM   #8
TV speakers never sound great. I leave mine at the default, but always listen to an AVR anyway. You might wish to consider an inexpensive HTIB or similar to improve the audio if you're keeping the TV.
If you get the Plasma, those speakers are usually pretty bad and you may wish to consider an HTiB or AVR anyway...
57 is offline
Old 2010-01-09, 09:41 PM   #9
dinosaur1
I know. Speakers are horrible on the plasma. I tried using THX on The Incredibles dvd for calibration and it improved it a bit.
Old 2010-01-09, 09:42 PM   #10
dinosaur1
Would you agree that my Hitachi is much better than dlp,lcd or plasma as far as Gaming goes?
