Does anyone if and how it would be possible to be able to watch Cable TV on your IMAC? And would it be in HD if you subscribe to the cable package in your home.
#2 | |
There are a number of products available, the most popular being EyeTV by Elgato.
Here's a brief description of the EyeTV Hybrid: Quote:
Panasonic TH-42PE7U plasma, Toshiba HD-D3, PS3, Shaw DCX3400, Yamaha HTR-6160, Polk 6.1, Belkin PF30, Harmony 700 |
Wow...that looks really, really neat. Do you have this?
Yup, but I haven't used it to its full potential, mostly due to the # of cable outlets in my suite, and I'm not in a great location for OTA channels with an indoor antenna. The TV guide also doesn't include Canada.
Neat little unit though.
neat unit. however, with the proprietary nature of the cable boxes here in Canada (and the US) using encrypted QAM and analog cable going away there is no way to really get this into your computer.
Toshiba 57HDX82|Denon AVR4310CI|PS3|SA8300HD|Harmony One|Paradigm [Monitor 9|CC290|DSP3100|ADP190|Titans] |
Hmmmmm that's too bad. Any other way? What about the old Happauge (sp?) company? I remember they used to make TV Tuner cards for the PC.
I just wanted the option to watch the same Cable package that I have at home on my office IMAC. (preferably in HD) Recording is not a major need but would be nice.... |
#7 | |
For example: http://www.ehmac.ca/anything-mac/832...-250-plus.html http://www.ehmac.ca/anything-mac/720...tv-my-mac.html
Pan 50GT50; Pio Rec VSX-519V-K; Shaw phone, HS Ext inter, HD cable DCX3400; 2011 iMac, 2.7 GHz i5; Parad Mini-MK3's |
You will need to use your cable box, regardless of what tuner card you have, and most tuner/capture cards will only input SD from your cable box. Only the Hauppauge HD1212 can input HD to your computer. I do not know of Mac compatiblity for it though.
#9 |
For digital cable, you need a cable STB supplied by the service provider or authorized distributor. If you wish to record, then see the following FAQ on recording HD, which discusses the HD PVRs, firewire (mostly problematical) and the Hauppauge HD PVR.
http://www.digitalhome.ca/forum/showthread.php?t=14099 Suggest you also look through the HTPC forum here.
