#571 |
Location: Bolton, Rogers Cable, Samsung LN-S4092D, SA8300HD, Samsung Ht-TQ72
Thanks for the helpful info!
#572 |
After the latest software update on my Sony EX620, it appears that the Rovi Guide software was updated. It now presents a "Reset" feature and a lot more user-control options.
The guide however still presents the same bug as before: the OTA channel guide setup simply does NOT work. Same problem as before: the data is downloaded then the message "The guide cannot complete setup" appears when using a Canadian postal code. It works for a US postal code however (but does not display data for CDN stations). Anyways, one of the new options added allows the guide data to be downloaded over the air instead. This is completely new and was not present in the earlier version. I am trying to see whether this option will work. If it does, I will be very happy. Let's see. |
#573 |
The closest TVGOS over-the-air host station is CFCF-DT. You must be able to receive this station in order to capture EPG data from TVGOS for your locale.
DMX 68' tower, HyGain HAM 5 rotator, Antennas Direct 91-XG & C5, Channel Master 7777 preamp, Siemens surge protection |
#574 |
Speaking of TV Guides.. A few weeks ago I sent an email request to ZAP2IT,
asking if they could update the Channel Lineups in some Buffalo area ZIP Codes to reflect all of the Toronto Stations. Since the Canadian DTV Transistion was completed in August, it was in need of updating. Most of the channels that were available were still following the old Analog naming conventions and weren't listing HD Content when available, etc. I just checked up on it and see that it looks much better now. All the Toronto stations are there now, with the -DT Callsigns, etc.
uhf/vhf combo rotor chimney mount homebrew vhf hi hpf ap-8700 preamp 4way split lg lcd dtt901 pctuner mythtv |
#575 |
Yes I have a perfect reception of CFCF (100% signal strength & quality). Anyways, it's still a no-go. After days of playing with the new settings, it still won't load any data, over the air or over the internet for my postal code. Sigh. I really wonder what the bug is.
Rovi support is mostly useless, they keep saying that I have to reset the guide and retry, although I have reset it just about 500 times already. So back to using a US zipcode and receiving data for US stations only. |
#576 |
CBC was fixed a few months ago but Global in Toronto doesn't show EPG nor PSIP data on my SONY TV, but shows on my DTVpal DVR. Both units are set at a Buffalo ZIP code so pick up the TV Guide broadcast from Buffalo PBS station.
Should I set my SONY TV to a Toronto postal code for Global TV Guide info to come from CTV Toronto? I hesitate only because I don't want other info or settings to change. |
#577 |
My Sony Bravia is not TVGOS-capable, and displays the current PSIP EPG data for Global Toronto and Paris perfectly.
I would try changing your Sony's settings to your Canadian postal code. You can always change it back if results are not satisfactory.
#578 |
So, now that I have ditched cable and got my OTA going well, how could I get a decent program guide ? I guess I miss my guide on my Bell/Rogers PVR...
Is there a web site, with Canadian stations, that I could register with to receive a Daily Program Guide, for only the station I receiver OTA ? Ideally a daily email, sent to my smartphone or computer, so I could know what will be on tonight... Right I read the Toronto Star, but that is so 20th century... |
#579 |
zap2it.com enter 14174 as the zipcode and you will see Canadian and US listings.
#580 |
I use area code L4A 5E7 with zap2it which lists stations from Toronto, Hamilton, Buffalo, Rochester, CKCO, CKVR, CHEX.
#581 |
Hello dshel,
Although I believe you already have obtained your answer, for completeness you should note there are many options available for obtaining OTA program guide info. The main ways of getting program guide info are:
I would suggest searching for these terms on this forum as you may find more info that can help you decide on the best option for your particular setup. Depending on your model, your TV may already have a guide built-in for PSIP or TVGOS. Or, you may decide to invest in a receiver (for example, the old CM-7000PAL has essentially the same guide as the Bell Satellite TV PVR) or a certain HTPC software. |
#582 |
I have my personalized page on zap2it bookmarked on my playbook tablet - I use it ALL THE TIME. I've even customized it to have my top channels listed at the top and I've removed all the channels that I can't receive reliably.
Just use you own postal code - it does Canada just fine...and choose "Broadcast (Antenna)" when you are asked who your provider is. Use this everyday.. |
#583 |
Some great tips here, thanks everyone I've setup zap2it, it's great !
brill |
#584 |
In addition to the advice above, you may wish to investigate a tuner with TVGOS and/or PSIP guide abilities. Both guide-data methods supply data over-the-air and populate information on-screen.
TVGOS (TV Guide On Screen) and PSIP (Program and System Information Protocol) are also available on DVR's from Channel Master, discussed in this thread. Subscription-based DVR program listings are available on TiVo for OTA.
#585 |
http://zap2xml.awardspace.info/
and http://mc2xml.hosterbox.net/ are easy ways to create an xmltv.xml file for import in to various PVR applications, like mythtv, NextPVR, so on...
| Tags |
| epg, ota, vancouver |
