ICP a Carrier company? - Canadian TV, Computing and Home Theatre Forums
Old 2009-12-07, 12:30 PM   #1
my0gr81
Default ICP a Carrier company?
I have seen referrences made on this forum regarding quality and reliability of ICP furnaces. These are then followed by statements such as to stick to the major companies such as Carrier,etc. Looking throught the ICP site, it seems that they are in fact a Carrier company.
http://en.wikipedia.org/wiki/Interna...ts_Corporation
Is this a case where the cheaper/ more budget conscious product are relegated to a sub brand or is there a bias that anything not branded carrier, lennox etc, has to be bad? Consumer reports of reliability aside (biased and negative feedback derived instead of feedback per unit sold). I can understand that most installers will have experience with those units, is that experience based on volume?
I ask, because I found out that my builder has used an ICP furnace, and wondering if I should spring for the maintenance plan or just chance it.
my0gr81 is offline   Quick reply to this message
Old 2009-12-07, 04:16 PM   #2
txv
ICP is owned by united technologies, which also owns carrier.
ICP has had heat exchanger problems in the past but the current product line might be okay.
The maintenance plans don't even cover heat exchanger replacement; change the filter as required and get the unit checked every few years. (annual maintenance is not warranted a new unit)
I wouldn't worry about brand name, provided that the equipment was sized/installed correctly.
WARNING: The HVAC information I provide is not based on field experience and DOES NOT constitute professional advice.
txv is offline   Quick reply to this message
Old 2009-12-07, 07:36 PM   #3
TKG26
its important to understand that just because carrier owns icp it does not make icp furnaces equal to carrier. They are not carrier furnaces with icp branding....
ICP is the dodge neon(or cavalier) of heating. Everyone has one, but they also know they are a POS!
Licenced HVAC TECH: "Without seeing your problem i can only offer suggestions, no warranty is included with my advice"
TKG26 is online now   Quick reply to this message
Old 2009-12-07, 10:16 PM   #4
my0gr81
two different point of views, got to love how the internet brings these opinions together. To continue the Dodge Neon metaphor, that car had a high number of problems, but all in all, when taken in context with total percentage of vehicle sold, it was pretty much equal to most cars in its size. If a builder builds a whole subdivision and installs hundreds of those units, all the failures the techs will see will be related to those furnaces, hence, associating that brand with those problems. Is this a reasonable assumptions?
Regardless, nothing I can do now, but what TXV recommended, hope for the best and plan for a heat exchanger replacement in a few years. basically, what I would have probably put towards an upgraded furnace without a guarantee that the higher cost furnace wouldn't have had its heat exchanger fail as well.
Old 2009-12-07, 10:54 PM   #5
txv
Carrier doesn't own ICP, the parent company of carrier does.
ICP may have solved their heat exchanger problems - the industry will find out in 5-10 years if they don't start droppling like flies.
I'm pretty sure that carrier (secondary heat exchanger lawsuit)/lennox /york/trane have all manufactured their share of junk.
Old 2009-12-08, 12:38 AM   #6
HDTV101
I installed a Keepright ICP furnace myself, model N9MP2, did most all of the work except the gas hook-up. I bought the furnace for $1100 and paid another $500 for the gas and venting hook-ups. The furnace comes with a 20 year warranty on the heat exchanger.
http://www.weinstall.ca/keeprite%20f...comparison.pdf
So far it's been working very well... and I'm happy I didn't pay some dealer $5000.00. It may not have all the bells & whistles, like a 2 stage, but it's still gets the job done for the price I paid. It may be a Dodge Neon of furnaces... but there must be tons of them out there working just fine.
This model is very popular with builders... and it replaced my 20 year old furnace that came with the house that was also a builder installed furnace.
http://icpindexing.mqgroup.com/docum...4001102002.pdf
HDTV101 is offline   Quick reply to this message
Old 2009-12-08, 12:55 AM   #7
99semaj
Semantics. ICP falls under Carrier management. None of our business units stand alone, and all HVAC is Carrier.
99semaj is offline   Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
