Toshiba regza no blue - Canadian TV, Computing and Home Theatre Forums
Old 2009-12-05, 04:07 PM   #1
fridgeguy
Default Toshiba regza no blue
I have no blue color anymore. Eg; cable menu is green and is usually blue. TV colors are shades of red and green This just happened while I was watching a show. I didn't touch anything or change settings.
fridgeguy is offline
Old 2009-12-05, 04:26 PM   #2
cooper83
What connection are you using? Component cables? HDMI?
If it's component cables, it might be the blue connector is faulty, or maybe not connected properly...?
Panasonic TH-42PE7U plasma, Toshiba HD-D3, PS3, Shaw DCX3400, Yamaha HTR-6160, Polk 6.1, Belkin PF30, Harmony 700
cooper83 is offline
Old 2009-12-05, 04:40 PM   #3
Please provide the model number of your TV. As mentioned above, if you've got things connected to the TV, please advise their makes/models and check/redo your connections from those devices. Advise the types of connections used if you've got problems on more than one device. Does the TV menu work properly, or if you connect cable directly to the TV, or another device like a DVD player directly to the TV?
Here's a list of things to check:
http://www.digitalhome.ca/forum/showthread.php?t=19694
57 is offline
