Thread Tools | Search this Thread | Display Modes |
#1 | ||
Press release:
Don't they know they had me at " Hello"?
"I've sworn off agnosticism, which I now call cowardly atheism" James Cameron |
Location: Scarboro, Sony KDS60A2020, Toshiba 50h81+42HP86,SA8300HD, 3xSA3250HD, 3xSA3200, HTPC,Sage+5 extender
Is this applicable to the International model on sale to Canadians? If so then perhaps I should return the one I bought last week to Amazon and rebuy.
Location: Downtown Toronto • Toshiba 52XL177 (1080p/24fps/120Hz) • HD DVD Toshiba HD-XA2 • Rogers HDPVR SA8300
Both these tricks could be accomplished by a software update -- mine is at 2.2.2 but it does not recognise a .pdf file on the Kindle drive. In fact, the press release above says exactly that: firmware update coming.
The extended battery life could simply be by polling the wireless network less frequently; keeping the wireless "live" is what runs the battery down. It would be very nice if the Kindle could sort files in some kind of folder structure ... but I understand that's coming in the new year. |
I totally agree - it is nice that it can hold 1500 book but how practical is that without some sore of hierarchy. Who wants to scroll through dozens of pages (slowly) to see what you have on your Kindle.
Here are instructions to manually update: http://www.***********/gp/help/custom...deId=200324680
Doing it now ... will report in a few minutes. Easy to update. Showing 2.3 version. Can't see pdf files yet. The screen rotation works fine (text key has a new option). Figured it out. I had the Home setting set to "Books" instead of "All documents" -- so it was filtering out pdfs. The pdf viewer is fine given the nature of the screen. As long as the pdf files are built from text (not images), the search function works well too. You do need to use the horizontal mode unless you have created the pdf yourself to custom specs most suiting the Kindle. But the opens interesting possibilities as well. In short, bravo! A very nice perk update. |
| Bookmarks |
