Location: Dunnville, Ontario on the Grand River, North shore Lake Erie
I don't mean to de-rail the 91XG testing, but is there anything different about the 91XG and the MXU59 from antennacraft ?
____________________________________________ MXU59 For Extreme Deep Fringe Areas 100" Boom Length, 59 Electronic Elements *Range up to 60+ Mi. UHF (Ch. 14-69) Featuring quadriture drive that develops extended resonance and optimum impedance match across the entire UHF band ! ![]() http://www.antennacraft.net/pdfs/MXU59.pdf ____________________________________________ 91XG •Range: 50-70+ Miles •Wideband coverage of UHF channels 14-69 •High protection, anti-corrosion, anodized silver aluminum construction •Reflector grids manufactured from welded, hot dipped, zinc-plated steel with plastic coating •Low wind load •Snap-lock quick assembly •Inclinable mast clamp for horizontal or vertical installation •High performance, integral PCB balun for true signal matching •Front to back ratio: 28 dBi •High gain across entire UHF band (UHF channels 14-69) •Max Gain 16.7 dB •Dimensions 22" H x 20" W x 93" Deep Last edited by stampeder; 2009-11-11 at 11:55 AM. Reason: split from 91XG Hacks thread |
OTA Canuck,
based on the gain figures, the 91XG is 200% stronger. |
No worries, sometimes I get confused and forget things from one minute to the next.
I also noticed the gain figures on the MXU59 is less than the 91XG. Many people here are much more knowledgeable about antennas too, so you might try some of the other forum subjects. |
#4 | |
yep, thats weird, heh?
Oops so actually maybe the 91Xg is not that much stronger have you modeled that MX... |
#6 | |
This is my first post, I have been hanging around for a little while. I am coming out of lurkdom. I have made a Hoverman and gave it as a wedding gift. Hey, she asked for it, so she got it.
I was thinking about getting the 91XG, but I could purchase two MXU59s for the price of one 91XG, so I thought that maybe two would be better than one. I hope I am right. Of course I bought the two antennas FIRST and then started searching/reading about the MXU59. I am worried that I didn't make the best decision now. After reading around, I have heard of corrosion problems. Is there something that I can do to help the antennas last longer? Is the 91XG really that much better? I mean can just one 91XG really do better than two MXU59s? I ordered two MXU59s and plan on stacking them to pick up some stations 100 to 140 miles away. (Not sure if I am going to do it vertically or horizontally yet) I have a winegard AP-8780 preamplifier. I will not get my antennas up for a while since winter is starting to set in, and I will have to get them set up before I mount them. But when I get them up, I will let ya know what happens. |
Resurrecting this thread, I am going to buy the MXU59 and compare it to my 91XG. Just found photos of it on another site and the number of directors is intriguing.
I recall 300ohm modelling the 91XG with round directors and the gain was increased. I'll try the MXU59 stock and with an added screen reflector once the weather warms up. |
#9 |
What is your winter time (non-tropo) results with the 91XG?
Is it stock/modified, any amplification, etc.? Looking forward to your comparison test...
91XG, C5, CPA-19; Denon AVR-1312 |
#10 |
The high gain figures for the 91XG are most likely taken from the highest point (peak) on it's gain curve and not representative of it over it's entire UHF range plot. The lower figure for the MXU59 is understandably the mean or average gain figure across its gain curve.
#11 |
According to the data sheet AD sent me, the 91XG's modeling shows about 11.8 dBi at 470 MHz to a peak of 18.3 dBi at around 765 MHz. This type of curve is typical of any and all wide-band Yagi antennas over this large of frequency span.
Antennacraft only publishes a single gain number ambiguously labeled as "UHF gain". Give that the boom length and element count of each antenna are very close, I would expect the basic performance of the two antennas to be very similar. |
#12 |
Antennacraft MXU59 on order. I will post my results in April or May.
#13 |
It is very odd that Antennacraft doesn't try to elaborate on their gain figure. I do believe that some manufacturers exaggerate 'gain' figures. What's just as important is how the antenna will stand up to the elements and even birds, unless it's tucked away in an attic. The higher gain X Beams, as they call them in the UK, are described by one antenna installer/tester there as being less durable than a conventional 18 element Yagi and is clearly evident in some of the pictures lower down in the link below.
http://www.aerialsandtv.com/aerials.html I have read reviews from people who are quite pleased with the Antennacraft MXU59 and having had a combination VHF/UHF/FM Antennacraft for over 19 years, I can say that it was pretty well built and still delivers excellent signal quality. |
#14 |
I'd be willing to try one out. I'd likely hold onto it if it's more durable than an XG91, and performs similarly.
Come September, a gain of 18.3dBi in the 700MHz band is of no use to me. So the search is on for something with an extreme gain for channel 51 and below--preferably something with high gain at the low end of UHF.
DMX 68' tower, HyGain HAM 5 rotator, Antennas Direct 91-XG & C5, Channel Master 7777 preamp, Siemens surge protection |
#15 | |
They are fine for loft installation, but the majority of ones I have seen outdoors are generally quite deteriorated by birds or snow. Unless very recently installed. In fact, just down the road from me, there's a house with an aerial where the top halves of the elements are bent down, but the bottom halves are fine. When I get my new camera, I will take a shot! (Actually the rigid X directors are fine outside, such as the ones by Antiference: http://www.antiference.co.uk/products/aerials , in other words elements that can't be distorted with light pressure. But the Philex ones are like aluminium foil and are rubbish http://www.philex.com/catalogue/category/?id=1058) |
