#31 |
Does this box do doube-rate deinterlace (i.e. 60 field per second) properly for interlaced materials? The one WD HD media box my brother tried (good that it was from Future Shop for its return policy) didn't support 60 fps for .TS file straight from DVR box or OTA and it was quite glitchy for some common file types. I understand this box plays 1080p60 material fine, but although 1080i material needs lower output bandwidth it takes extra processing to deinterlace properly (converts 30 frames per second data to 60 fields per second screen updates). Any words on whether it does that properly?
#32 | |
I suspect the TV plays an important role in this. Or should I say normally performs the rate doubling (since it would expect 1080i60). Sending 1080p60 is going to tax the system.
Could you elaborate on what codec and container you are experiencing trouble with. Quote:
#33 | |
The WD HD media player (not the WDTV Live box) I tried couldn't double-rate deinterlace any interlaced material, HD or not. Besides the deinterlace problem, the videos I got choppy playbacks for sure are the Bluray-ripped ISOs (not ripping for further compression but DIRECT rip), native VC1 or not, same result. I think there were other videos that played choppy as well but I couldn't remember which those were, since 1080i materials and Bluray direct rips are 99% of the intended use. Please note that I'm referring to the WD HD media player for these problems. That's why I wonder if the WDTV Live still have these problems. |
#34 |
Chris,
Do you have the tester video for 1080i ??
LG55LW5000/Denon3313/MirageOMD5+Nanosat+MM8/ClearStream2/CM7778+3414 SSGPN50A550/OptomaHD33/Onkyo717/KEF3005/Velo15" |
#35 |
I've uploaded 3 short clips in a zip file here:
http://rapidshare.com/files/31375518...lace_Tests.zip In there, we have: CanadaAM_OTA1080i_MP2.mpg -- straight from OTA (over-the-air) reception. Standard 1920x1080i. Should be deinterlaced to 60 fields per second. Text on the bottom of the screen should scroll smoothly and the letters shouldn't be fuzzy. GolfHD1080i_MP4.m2ts -- recorded from Shaw HDDVR box thru' Hauppauge HDPVR box. Standard 1920x1080i. Should be deinterlaced to 60 fields per second. Again, text should scroll smoothly and not fuzzy. GolfHD720p60_MP4.m2ts -- same recording as above but in 1280x720p60. No deinterlace required. Any player able to play 60fps video should be able to get this one right. This is for comparison with the above video. The scrolling text should be just as smooth and clear as the above 2 videos. If this one is smoother, then the box can't do double-rate deinterlace properly. Please set output of the box to 1080p if such option exists. Thanks for testing. |
#36 |
The videos are a little short I have to fiddle to get to the repeat button LOL
Anyways, my LIVE passed with flying colors and everything is butter smooth. Then I proceed to set the WD to output @ 1080i @ 60Hz and my Samsung B530 does a good job de-interlacing as well. OTOH, my bedroom rig with Radeon 4350 stuttered a little at the beginning but the scrolling text was very clear. I may look at Canada am one morning to see how a longer clip will fair. I never doubt the video capability the LIVE and this little thingie is indeed a marvel. Networking is still flaky!!
#37 |
Just got this unit and am also impressed. No HD content but can report no problems auto connecting to either drive in my DNS-323 and Win7 PC. (did do the firmware update on install start up)
Question for everyone... how do you get thumbnails of your movie files to appear? As I understand you just put a jpg with the same name in the same folder? I have all my movies as ISO files in one folder on my NAS.. will this still work? Also, any way to automatically get the thumbnail and movie info automatically? I have XBMC on a few Xboxes and have been spoiled by the seamless automatic IMDB lookup.
Epson EX71, Tosh HD-A2, Denon AVR590, Athena P4100, Infinity P362,C250,P162. RCA L42WD22, Pio VSX1016, Athena LS50 |
#38 | |
http://rapidshare.com/files/31416868...lKreviazuk.mpg (180MB) http://rapidshare.com/files/314174024/GolfHD1080i.m2ts (41MB) |
#39 |
dosborne on 17 November 2009:
Firmware v1.01 is now available for download I am hoping to get one of these soon, but I would like to know if WD has made any effort to improve the Windows/Samba networking problems noted earlier in this thread. Has anybody noticed any improvement with networking with the latest WD firmware? - Jeff Schallenberg Mont Saint Hilaire, Québec |
#40 |
I updated as soon as it was available.
It did work well for about a week and then same old dropping off occasionaly while playing something. There are newer problems that the LIVE is not connecting to a SHARE in the first place and sometimes NO MEDIA FOUND. I am glad I don't have to depend on it in any way; that's also probably why I am lazy and have not installed 3rd party firmware yet. Seriously, if you're on the fence, do NOT buy (yet) unless you're prepared to troubleshoot or be prepared to install 3rd party which seems to have fixed various problems.
#41 |
I am getting this unit later today.
It will save me time, I save shows for my wife to view later and have put them to dvd in doing that loosing some quality too. They are OTA programs. I will hard wire it and if problems arise then go usb drive until they are worked out. |
#42 |
I'm thinking of buying a media center for my home entertainment system.....does anyone know if these systems can upconvert div x media to 720p and 1080p? I know they do dvd's which are 420, but I am really only interested in these media players if they can upconvert divx formats.
#43 |
Your television is going to upconvert everything to its native resolution anyway (1080p if it's a 1080p television).
-Mike
Pioneer PRO-110FD | Pioneer VSX-92TXH | BELL 9242 | Panasonic DMP-BD35 | XBOX 360 |WD TV Live Hub |
#44 |
I got the WDTV HD Live today took 10 mins to setup inc the new firm ware and a little work setting up shares on the computer and boom wife's happily watching NCIS looks great! I am pleased with the ease of setup and the size is nice to tuck away beside Onkyo I hooked up dvi to it and all is great.
#45 | |
You don't set the resolution to 1280x720 to play 720p material and let the HDTV upconvert. Big no-no for LCDs.
