New Pace/Shaw equipment launching Sept 30th - Page 3 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Shaw Communications > Shaw Cable HD tuner and HD PVR Discussion
Old 2009-09-30, 05:26 PM   #31
lorissimo23
Has anyone been able to confirm the availability of the Pace Summit in Calgary?
lorissimo23 is offline
Old 2009-09-30, 11:19 PM   #32
ksolomon
We just made an appointment this afternoon with Shaw to get our HD service installed on November 1st (so as not to have a double bill between Shaw and MTS)...any guesses on which PVR we'll be getting?
ksolomon is offline
Old 2009-10-01, 12:48 AM   #33
RigPig
Shaw Guru, thankyou for providing this information. Regarding the Shaw PVR expander (which i guess is a rebranded Western Digital MyDVR esata drive) ....has there been any discussion on whether or not 3rd party esata enclosures will work with the Motorola PVR? Just wondering if there will be some sort of equipment 'pairing', that will preclude the use of 3rd party esata gear. Thx & rgds.
Integra Research RDC-7.1, Bryston 9B-SST, NHT vt2, vs2 & sw2, Sony 65XBR10w, Moto 6416iii, PS3-250, Sony BDP-s550
RigPig is offline
Old 2009-10-01, 12:56 AM   #34
http://www.digitalhome.ca/forum/showthread.php?t=112018
57 is offline
Old 2009-10-01, 01:36 PM   #35
RigPig
.....actually i was asking ShawGuru if there had been any discussion 'Internal to Shaw' on that subject, i could have worded it different maybe.
He had mentioned internal discussions about the new hardwares, so i was just asking if that was touched on at all. Thx.
RigPig is offline
Old 2009-10-01, 06:08 PM   #36
tj80
FYI the Pace 758Ds are in stock at BestBuy Surrey BC. Thanks for the advance info! I might have made a mistake and ordered the 3416 instead.. Unless this unit sucks, the 1TB for $500 is clearly better than 160GB for $500. I'm no math genius, but this seems like a no-brainer.
tj80 is offline
Old 2009-10-01, 07:46 PM   #37
JesseJ
Location: Calgary, Shaw Digital HD Plus, 3416 & Expander
plugged in and works fine. It says 0%, and even though there are recordings, I think it uses the larger space first, then the smaller internal HDD, if I am correct (I think someone on here mentioned that). I can go on vacation now, and my pvr wont fill up!!!
SHAW 2012 HD Count: +8 (51 Total not counting SC or SNETWorld)
JesseJ is offline
Old 2009-10-01, 08:59 PM   #38
753951
Speaking of ... What happens during power outage? Instructions (and bit of common sense) say that expander should be powered first, then after 5-10 seconds PVR. Reason is that disk in expander has time to spin up and PVR can then recoginze there is external disk and can properly initialize it.
When power comes back, both expander and PVR start initialization at the same time. If PVR makes check for external disk before disk is ready to respond what will happen?
  • Nothing. Disk will always start faster and PVR will recognize it.
  • PVR is faster and it will not detect external disk. It will record to internal disk for as long as there is space on it. Existing recordings on external disk will be available next time PVR boots up and external disk is recognized.
  • PVR is faster and it will not detect external disk. It will record to internal disk for as long as there is space on it. Existing recordings on external disk will be lost forever.
  • PVR is faster and it will not detect external disk. Because disk configuration changed it will automatically reformat internal disk and previous recordings on internal disk will be lost. New scheduled recordings will continue to record as normal.
  • PVR is faster and it will not detect external disk. Because disk configuration changed it will ask user (thus wait for you to come back from vacation) if it's OK to reformat. From that point on all scheduled recordings will be missed.
  • PVR is faster and it will not detect external disk. System will crash and wait for special boot sequence to perform factory reset
  • Something in between
753951 is online now
Old 2009-10-01, 10:08 PM   #39
Jetranger
Premium Supporter
The answer is to buy a UPS. I have one on each of the three STBs in my house.
If you want more then ask for it rather than going hungry. If you want more than I have then you should ask. They're going to park their car over there.
Jetranger is offline
Old 2009-10-02, 10:24 AM   #40
753951
I'm well aware of ways to avoid it but when UPS battery gets exhausted UPS will shut down and we are back to the original question. Which of many suggested scenarios is going to happen? When my expander gets delivered I'll flip the breaker and test it myself, but I thought someone may have encounter this and knows the answer.
Old 2009-10-02, 05:00 PM   #41
jumpy27
I just talked to Shaw and was informed that a power outage should cause no problems after the drive is formatted. But only time will tell!
jumpy27 is offline
Old 2009-10-02, 05:16 PM   #42
JohnnyCanuck
Power outages do not cause any problems with eSATA drives connected to Pace Aspen PVR's so I'd be hard pressed to imaging that they would with Whistlers.
JohnnyCanuck is offline
Old 2009-10-03, 01:59 PM   #43
753951
Thanks guys, that's what I wanted to hear.
Old 2009-10-05, 01:15 PM   #44
bciochetti
I can confirm that the new Pace HD Tuner DCT758D is available at the North Edmonton Best Buy. However, I went to get the box activated, and after about 20 minutes of working with the guy from Shaw (He told me that I didn't give him a valid serial number because it didn't start with PAZ) he informed me that Shaw wasn't putting up the firmware download until today, so my box is sitting at home right now hopefully downloading the firmware so I can use it when I get home.
bciochetti is offline
Old 2009-10-09, 06:01 PM   #45
fuzzybunny
From the Pace Website:
The box comes standard with dual video tuners that allow subscribers to record two channels simultaneously while watching previously recorded content.
The DC758D can support a range of hard drive models and capacities including the popular 1 Terabyte drives now on the market.
fuzzybunny is offline
Tags
pace, pvr, pvr expander, summit, whistler
Forum Sponsor
