82-km limit to protected contours of DTV stations in Canada - Canadian TV, Computing and Home Theatre Forums
Old 2009-09-07, 02:27 PM   #1
downbeat
Default 82-km limit to protected contours of DTV stations in Canada
What is the purpose of capping the protected contours of DTV stations in Canada to 82 kilometres? Is it a purely technical limitation or some kind of bureaucratic thing?
downbeat is offline
Old 2009-09-07, 02:49 PM   #2
mr weather
That's about 50 miles. Sounds like a political thing to me.
mr weather is offline
Old 2009-09-07, 03:36 PM   #3
stampeder
Default Some thoughts on DTV contours
To briefly answer downbeat's question, it is political, but philosophical (from an engineering standpoint) too. Okay, that was the brief part.
For those of you not familiar with TV station contours (as seen on maps) it is very important to note that they are not "coverage areas", which usually exceed the actual contour in some or all directions. When a new TV station is being planned, its contour calculations start well before the application for a license. The owner contracts a broadcast engineering firm to do the technical work, and the process usually begins with a simple "ideal" coverage area based on marketing and/or consumer research drawn on a map and handed to the engineer. That is not the contour, it is a "want to have" coverage map.
From there the contour is calculated based on actual distances but also on a variety of other factors, chiefly the surrounding topography, the HAAT (Height Above Average Terrain) of the transmitting antenna, the directionality of the antenna, beam tilt, etc. to arrive at an ERP (Effective Radiated Power) level and its expected field strength in dBu. The broadcast engineer must follow the regulations of Industry Canada and if in a border area the FCC too.
Unlike the older analogue NTSC stations in the U.S. where Class A stations could belt out whopping amounts of ERP to cover huge areas, Canada stayed away from that philosophy with only a few exceptions (CN Tower, major prairie cities). The engineering philosophy was not much different from the concept of firing an old howitzer and hoping for a direct hit.
Now that we're in the DTV age there has been an effort on both sides of the border to force the contour thresholds lower and with greater precision for the sake of energy and reception efficiency. DTV allows that kind of formulation, and the engineering philosophy is now towards "right sizing" contours to their desired audience coverage area.
So, while all the technical stuff is being hashed out, the political side comes in. The CRTC approves/disapproves applications and can send them back to the drawing board during the process. In Canada, there are several good examples of cities for which the contours of neighbouring stations are tightly regulated so as to allow realistic advertising revenues for each: Victoria/Vancouver, Hamilton/Toronto/Kitchener-Waterloo, even Ottawa/Montreal to some extent. Not only is the field strength capped, but the shape of the contours is also highly regulated. The Canadian authorities have often objected to U.S. stations' contours having overlap into Canada, and have intervened successfully to have many such contours reshaped to avoid that.
So you see, setting such limits on the contours of stations is one of the simplest ways to enforce such political considerations and policies from the very start of a station's application process.
My own knock on the capping and shaping of contours is that we've been seeing more and more evidence that DTV-era field strength calculations are proving to be too conservative for satisfactory OTA reception.
stampeder is offline
Old 2009-09-07, 05:28 PM   #4
CamDAB
Location: Far East End of Hamilton, ON (Lake & Barton, 10th floor facing East)
And it's technically possible to blanket a city with low power "relays" without a primary "blowtorch" and thus very tightly control the coverage.
ATSC is quite robust in this area, like DAB is in radio. Just no one here in Canada has really made use of this concept to it's full potential.
Cameron
DAB listener December 2003-November 2011 (DAB Off-Air)
HD radio Listener since June 2010
CamDAB is offline
OTA Forum Sponsor
