Distance between VHF & UHF antennas? - Canadian TV, Computing and Home Theatre Forums
Old 2009-09-07, 09:20 AM   #1
DarkNovaNick
Question Distance between VHF & UHF antennas?
I have a quick question -- how far apart should my UHF antenna be from my VHF on the mast so they don't cause problems with each other? Thanks!
DarkNovaNick is offline
Old 2009-09-07, 02:38 PM   #2
Jaygeetee
DHC Supporter
Not sure of exact distance requirement but I have VHF mounted 2' below UHF on same mast without any problems. Also tried various spacings between 6" and 3' without any noticable interference. Both antennas aimed in same direction on rotor mast.
Jaygeetee is offline
Old 2009-09-07, 02:51 PM   #3
stampeder
Also see Post #16 in the OTA FAQ for some calculations:
stampeder is offline
Old 2009-09-08, 05:55 PM   #4
DarkNovaNick
Thanks.
OTA Forum Sponsor
