Hello all, I have a question. How can I connect outdoor antenna to tv? My TV does not have coaxial cable connection. What do I need?
Is it possible to set it up through satellite receiver? |
what connections does your tv have ?
and you don't have a vcr you can put it through ? |
If it has the old 2 screws for 300 ohm twinlead, just connect a BALUN to the end of your coax wire, and then hook the two leads from the BALUN to the VHF portion of the TV.
I am assuming the coax will be coming from either a satellite box or DTV tuner box that is set for either channel 3 or 4 on the VHF band. Once it is all hooked up, tune your TV to either channel 3 or 4 (which ever one the box is set on) and you should be good to go. HTH. Mike |
It might be a new monitor-type tunerless TV too, so I'm hoping he'll post the make and model number here.
If a regular TV doesn't have a coax input, it must be an antique, as coax has been standard for decades. If this is the case, you'll have to get a balun to convert from coax to the twisted pair input. If it's not an ancient TV, please describe what connections it does have.
#6 | |
No idea where the OP went, so I've moved some posts about vintage TVs to this great thread:
Retro Video Equipment (TVs, Antennas, Consoles, Etc.) Last edited by stampeder; 2009-09-01 at 01:36 PM. |
