Problem with display (going by FBI Warning background)? - Canadian TV, Computing and Home Theatre Forums
Old 2009-08-28, 10:19 PM   #1
das75
Default Problem with display (going by FBI Warning background)?
Why I'm wondering is seem to notice every time the the FBI warning comes up, the background is not uniform.
Most often it's a corner (usually upper right) is a lot more brighter (paler blue) than the rest of the frame.
Tried to capture below, (this time the bottom is darker than the top).
TV is a Samsung plasma PN58S650 about 10 months old. Source is a Sony BDP-S350.
das75 is offline
Old 2009-08-29, 10:38 AM   #2
das75
or is it normal that the background is uneven?
das75 is offline
Old 2009-08-29, 10:48 AM   #3
jayoldschool
I seem to remember that is the way it is supposed to look...
jayoldschool is offline
Old 2009-08-30, 07:55 PM   #4
das75
thanks, been bothering me for while and with the warranty coming to an end...
das75 is offline
Old 2009-08-30, 08:53 PM   #5
jayoldschool
das, I just checked for you (while trying out my new home theater projector)... it's normal.
Old 2009-09-07, 11:43 AM   #6
kev604
Location: Burnaby,BC--Sharp LC-37D43U,Pioneer 1018AH,PS3,Toshiba HD-A2,Celestion AVP-301,Jamo SW-1008,DCT3416
I've noticed the same thing on my plasma and lcd display and I have the same bluray player bdps350.
Panasonic TH-50PX60U,Pioneer VSX-1018AH,Sony BDP-S350,Toshiba HD-A3,Energy RC Mini Speakers,Klipsch Sub-10,H880,DCT3416
kev604 is offline
