530 with an External Hard-drive - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Shaw Direct (formerly Star Choice)
Old 2009-08-22, 05:16 PM   #1
greatger
Default 530 with an External Hard-drive
Does anyone know if a hard-drive can be used with the 530 via a USB port ?
greatger is offline
Old 2009-08-22, 06:18 PM   #2
QCK
The answer is no, and odds are it never will have this ability. Maybe the next generation receivers will have this.
QCK is offline
Old 2009-08-22, 10:59 PM   #3
Moose57
Red face Not so fast...
This thread has evolved and shows several cases of using an external hard drive.
There are several good reasons for doing so.
One is trying to find SEAGATE drive with IDE interfaces is getting tough and capacity , while many times greater than the factory 160GB has not kept up with the latest sizes in SATA drives.
So using a LARGE any brand SATA drive in a USB enclosure makes a lot of sense.
It also transfer the heat load outside of the unit for potentially more reliable operation.
Reports suggest the overall performance is BETTER.
This may be due to the faster 7200+ RPM over the OEM 5400 and larger buffer sizes.
While it IS true the USB port is NOT enabled and likely never will be, it does have power.
Most have just dangled a USB cable out the back and connected to the internal headers.
You COULD detach the USB rear connections from the main board with some carefully cutting and de-soldering and jumper them over the the main board header.
This would be the tidiest installation.
http://www.digitalhome.ca/forum/showthread.php?t=73790
Kudos to the thread author for exposing this exciting modification that makes the unit a contender and the others that also pioneered the USB and external experiments.
Maybe with all the beta testing the members here did when Moto/SD wouldn't will not have them scared to add this feature to the next generation unit. After all, then it will be almost as good as a 5 year old Echostar Technologies PVR
Moose57 is offline
Old 2009-08-23, 06:08 AM   #4
QCK
Yea, I should have added that it can be done if you don't mind modifying your receiver and voiding the warranty. It is so much cleaner just to put a larger hard drive inside if you need more capacity IMO. It is cool that this can be done though.
QCK is offline
