way to get my JVC tv into antenna mode? - Canadian TV, Computing and Home Theatre Forums
Old 2009-08-19, 10:03 PM   #1
hamid14
Default way to get my JVC tv into antenna mode?
epicdistortion, It is almost done, but I am still looking for a way to get my tv into antenna mode. Any links would be appreciated. It is a JVC 20 inch flat screen. Tried searching JVC.com, but they did not help. >:[
60 Inch 1080P LG LCD TV w/ Bell HD Satellite & Sony Playstation 3 :D
hamid14 is offline   Quick reply to this message
Old 2009-08-19, 10:59 PM   #2
epicDistortion
I'm glad to hear the build is going well, let us know how it turns out!
Without the Model number I haven't come up with anything. fixya.com seems to have some manuals online, so if you can find a similar model it should get you the instructions you need.
epicDistortion is offline   Quick reply to this message
Old 2009-08-20, 12:04 AM   #3
300ohm
The model number should be listed on the back of the set.
300ohm is offline   Quick reply to this message
Old 2009-08-20, 11:07 PM   #4
hamid14
Found out my tv model, it is a JVC I'Art, model no. av20f702! Thanks to anyone who can find a way to get my tv into antenna mode!
Old 2009-08-21, 12:13 AM   #5
300ohm
Hmm, JVC doesnt seem to have that model listed, but they do have the av20f703 and av20f704. They should be similar. You can download the manuals from here : http://books.jvcservice.com/booklist.asp?Model=av20f
Old 2009-08-21, 06:56 AM   #6
peano
From the manual:
"This TV is equipped with a channel memory feature which
allows channels to skip up or down to the next channel set
into memory, skipping over unwanted channels.
Before selecting channels, they must be programmed into
the TV's memory. In addition to normal VHF and UHF
channels, this TV can receive up to 113 Cable TV channels.
To use this TV with an antenna, set the TV/CATV menu
option to the TV setting. When shipped from the factory, this
menu option is in the CATV setting.
TV/CATV SELECTION
Press the MENU button.
Press the CH + (s) or – (t) button
until the indicator next to "CH SETUP"
begins to flash, then press the
ENTER button.
until the indicator next to "TV/CATV"
begins to flash.
Press the VOL + ( ) or – ( ) button
to select the TV or CATV mode. The
arrow indicates the selected mode.
Press the EXIT button."
peano is offline   Quick reply to this message
Old 2009-08-21, 07:13 PM   #7
hamid14
Thanks for the help peano, but the enter button does nothing when I press it, in the menu. I dont have a manual for the philips universal remote.
Old 2009-08-21, 07:56 PM   #8
300ohm
You can probably find your Phillips remote manual here : http://www.remotecentral.com/cgi-bin...her&db=devices
Old 2009-08-21, 08:26 PM   #9
hamid14
That is helpful, but I dont know what model my philips remote is.
Old 2009-08-21, 08:35 PM   #10
300ohm
Hmm, my Phillips Universal Remote doesnt have the model listed on it outside anywhere either. How many control/function buttons ? My 3 function control, TV, VCR, SAT is model number SRU3003WM/17
Old 2009-08-21, 08:38 PM   #11
stampeder
Any model number shown in the battery compartment?
stampeder is offline   Quick reply to this message
Old 2009-08-21, 09:03 PM   #12
hamid14
300ohm, I HAVE THE EXACT SAME REMOTE! Praise the Lord!
Old 2009-08-21, 10:06 PM   #13
300ohm
The manual for it is here: http://www.p4c.philips.com/files/s/s...27_dfu_aen.pdf
The codes for it are here : http://www.urc.philips.com/default.asp?categoryId=333
Select US URC Models, Remote starts with SRU, SRU 3003.
Click "Find Device Codes for your remote".
Its also the only remote Ive found that works with the Zenith DTT-901 CECB (using code 0267 on the SAT button).
JVC TV codes are (including LCD, Plasma and Panel):
0607, 0204, 0321, 0508, 0617, 0326, 0993, 0802, 0108, 0308, 0715.
Old 2009-08-22, 02:28 PM   #14
hamid14
Tried all that, but it's like the Enter button was not made for this JVC television. I've tried all the codes for JVC television starting from 0607. None of them work.
Old 2009-08-22, 04:21 PM   #15
300ohm
Try the OK button for the Enter button (or even a different button). The buttons on universal remotes dont always have a 1 : 1 matchup to the original remote.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
