Hoho, Zoombox / Torpedo? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > Home Theatre Corner > Home Theatre Construction
Old 2009-07-19, 01:41 AM   #1
HarilsonP
Default Hoho, Zoombox / Torpedo?
One of those cheap less then $150 projectors ,been hearing good/bad reviews - Anyone here care to give an honest one?
HarilsonP is offline
Old 2009-07-27, 08:19 PM   #2
David Susilo
It's beyond garbage. The resolution is only 557x234 with the brightness of only 8 ANSI lumens.
THX, ISF, Control4 Certified Professional; CEDIA Trainer
David Susilo is offline
