Wireless router buying suggestion needed - Canadian TV, Computing and Home Theatre Forums
Old 2009-01-20, 07:20 PM   #1
Fishbone
Default Wireless Router Choice?
I am currently using an Apple Airport Express to transmit music files from my PC to my Squeezebox 3s, however, the Squeezebox in my upstairs bedroom is now constantly "rebuffering", likely due to too many wireless networks in my area. I am considering trying to use a stronger wireless router to improve the signal and see if that works. Any suggestions on a router? I understand that some automatically change channels to optimize the signal strength.
Any thoughts would be appreciated.
Lawrence
Fishbone is offline
Old 2009-01-20, 08:13 PM   #2
hugh
Dlink DIR 655 is a good one. serveral threads discussing it and a few others around here.
hugh is offline
Old 2009-02-06, 09:55 PM   #3
bdoyledimou
I just upgraded to the dlink DIR 855 and love it.. i can split my data and multimedia broadcasts across two separate wireless networks, all from one router..
bdoyledimou is offline
Old 2009-02-06, 10:38 PM   #4
cigar7
Default Dlink
I have been using the DIR 655 for a year, and I have no complaints. Does a great job, wired and wireless.
cigar7 is offline
Old 2009-02-08, 03:27 PM   #5
jcol
Default Wireless N ?
I've had a D-Link Dir-655 router for some time now. It works fine, however until now I've only ever had G devices on my network. Today I purchased a wireless card for my sons desktop computer. The card supports B, G and N. I installed the card and changed my router setting from G only to G and N. Computer sees the router and can now access the internet and the other computers on our home network, however I see that it has connected as a G device. The wireless config program that came with the N card even reconizes the network as a G and N but it does seem to want to connect as an N device. I'm running a WEP for security. Is there are rule about mixed devices or am I missing something else. Any help would be appreciated. Thanks.
jcol is offline
Old 2009-02-08, 04:01 PM   #6
cambo
Default Wireless N
For true Wireless N, you must use WPA, as WEP is being phased out.
cambo is offline
Old 2009-02-08, 04:27 PM   #7
Alan Toronto
Location: Toronto, Rogers, SA8300HD + 640GB external drive. Samsung LCD LN40A750 1080p 120Hz. Blu-Ray BD-P1500
For good reason: WEP is very insecure.
Alan Toronto is offline
Old 2009-02-09, 08:25 AM   #8
sharpnfuzzy
Your network "speed" will always drop to that of the lowest connected device. So N will drop to G if you have even 1 G device connected and B if you have even 1 B device connected.
To get an N network you need ALL N devices connected.
sharpnfuzzy is offline
Old 2009-02-09, 08:29 AM   #9
hugh
jcol,
I have the Dlink-655 and I use an External N adapter in the basement and I use WEP. I get N speeds.
I don't know the answer to your problem but I can assure you that you should get N speeds regardless of other wireless devices and encryption methods.
I would investigate your router, network card setup options and ensure the firmware on your devices is current.
hugh is offline
Old 2009-02-10, 03:09 PM   #10
Jeff Flowerday
DIR 655 is your best option.
Band:
Scotch on Sunday
Jeff Flowerday is offline
Old 2009-02-10, 03:42 PM   #11
Tezster
I've been looking at the same exact router to replace my el-cheapo TrendNet for both Wireless N + wired gigabit capability.
Tezster is offline
Old 2009-02-11, 07:02 PM   #12
jcol
Thanks for the replies. I went ahead and changed from WEP to WAP2, it was relatively painless. I didn't play around to much with my original WEP setup but I'm sure the computer with the N card was not connection as an N device before. After changing to WAP2 and rebooting the router the router now shows that the computer is connected as an N device. It also lists a much higher data rate and better signal strength. Seems pretty fast. So I'm not sure whether it was the change from WEP to WAP2, or perhaps it was simply the reboot but I can state that I am getting N speeds from my router to this computer even though I have G devices on the network as well.
jcol is offline
Old 2009-02-11, 08:02 PM   #13
e268
That is right, it does not go to the lower speed device in the network. Each is on its own. My G router is configured to run G & B, I get 54 mbps on my G desktop, and my N laptop, but only 11 mbps on my b laptop.
Yammy RXV2400 & CDC815, Celestion DL8 fr Mission 73Ci ctr Sansui rear Velodyne CHT8, Vaio TT180, i7-920@3.8Ghz
e268 is online now
Old 2009-02-12, 02:06 AM   #14
dennism3
Some documentation suggest mixing slows down the network but not to the lowest common denominator. Right on.
dennism3 is offline
Old 2009-02-12, 09:43 AM   #15
sharpnfuzzy
The point is that you will not get N level throughput on a network with any lower devices. A/B/G have no clue what N is, (A has no clue about B, and B about G, etc.) yet they all need to be able to talk to the router and listen for when the channel is free to transmit.
Therefore your router will always be switching between all the different speeds slowing down your overall throughput to some mean value of all the devices that are connected and can only guarantee the throughput of the slowest connected device.
Of course this is all assuming you're not using dual band etc.
