ATSC High Definition Tuner Boxes (Non-Recording) - Canadian TV, Computing and Home Theatre Forums
Old 2008-07-27, 02:01 PM   #1
videobruce
Lightbulb ATSC High Definition Tuner Boxes (Non-Recording)
I stumbled across this HD tuner that might be of interest up north.
It is distrubuted through Centronics and sold through Solid Signal (probably others) for only $50 US which is close to the price for one of our CEBC's with the coupon. The orginal list was $230 and now it's $150.
Features;
1. 8VSB tuner (no QAM even though the chip has it built in),
2. HDMI, VGA & component outs; switchable between 480p, 720p & 1080i,
3. Composite out (see below), but no S video,
4. EPG (see below),
5. Optical audio out (see below),
6. Multiple aspect ratio choices (but buried layers deep in the menu).
Pros;
1. Price (1/3 the cost of the compition),
2. Multiple outputs (two can be used at the same time ?),
3. Decent PQ with HDMI & component outs (not quite as good and my other external tuner and internal tuner in my 57" Mits),
Cons;
1. Lack of proper documentation,
2. Flaky EPG and incorrect GMT offset (+ hours instead of - hours),
3. Older 2nd generation tuner. Main board is dated 12/06 (but doesn't appear to be a problem),
4. Useless composite out (high chroma level and rolled off video response), no S-video,
5. Uses as much power in standby as when on. IOW's a power hog (considering what it is),
6. Flaky, hard to figure out, undocumented 'Channel Manager',
7. Possible audio sync issues w/ optical out (first unconfirmed report).
Details on what you don't see and isn't in print;
Circuit board: PATSC40040G Rev.02 Build date 12/06
Front End: Thomson DTF8800A 21475080 6325000487
8VSB/QAM 2nd gen. receiver chip: Broadcom BCM3510KPFG (QAM disabled);
http://www.broadcom.com/collateral/pb/3510-PB05-R.pdf
Memory (2): Samsung K4H561616338F-UCCC
NOR flash memory: Samsung K8D6316UBM PI07;
Unfortunately, the main processor is under a glued on heat sink that I didn't want to try to remove.
There are two 'headers' on the board;
J9- 3 pin
J19- 20 pin
There is also a reset: SW1
I did many tests with this and considering it's only a 2nd generation receiver chip, it has surprising good reception results. I'm in the unfortunate location to be bombed with no less than seven stations less than 7 miles away in the same direction as Toronto. That creates a very interesting (and expensive ) challenge for me to even think about trying for Toronto. With the aid of seven, single channel filters and a amp, I found a combimation that works (for the most part).
Anyway, this box isn't any worst than my four other HD tuners (three TV's and one DVR). I do have a CECB box (Channel Master) and I have to say, there is a noticeable improvement over all these others with the CM. Nothing huge, but noticeable. Anyone that only has a HD ready TV, this might be an answer.
videobruce is offline
Old 2008-09-22, 11:27 AM   #2
RHGuy
Default Choice Select vs Winegard?
I'm considering either a Choice Select CH04006 or a Winegard RC-1010.
My ultimate goal is to feed in a signal from a CM4228 and have this box power a 1080i projector for my home theatre setup but would also like to be able to move it around to a older HDTV without ATSC tuner or analog TV up at the cottage.
Any thoughts or suggestions about these two tuners would be appreciated.
Thank you.
RHGuy is offline
Old 2008-09-23, 01:54 PM   #3
avgjoe
Default Samsung SIR-T151 tuner
I was able to get a great deal on a used Samsung SIR-T151 tuner, the only problem is it came without a remote. Does anyone have that system and if so, would you be able to tell me part number for the remote? or maybe anyone knows a universal remote that will work with this tuner?
Thanks in advance.
avgjoe is offline
Old 2008-09-23, 01:57 PM   #4
stampeder
A Harmony remote will operate your Samsung SIR-T151 just fine. Now the not so good news... the reason you got such a good deal on it is probably due to the fact that it has a very old generation of ATSC chipset, which means you won't be getting the performance we've come to expect over the last 2 to 3 years from ATSC tuners. Sorry, but its always best to hear the truth.
stampeder is offline
Old 2008-09-23, 04:02 PM   #5
roger1818
I haven't even heard of either of these tuners. What is drawing you to them?
roger1818 is offline
Old 2008-09-24, 03:30 PM   #6
avgjoe
Thanks for the reply stampeder, though that Harmony remote seems to be worth more than I paid for the box ($25) - anything cheaper you're aware of, like a generic universal remote?
As for the tuner - we'll see how it goes, hopefully it'll be stable enough for the Toronto stations, don't really care for analog stuff (I see that it doesn't have a ntsc tuner)
avgjoe is offline
Old 2008-09-24, 05:52 PM   #7
teenie
I hear you.... they are not cheap... but they really do eliminate your other remotes for almost all day to day activities around TV watching or any of your audio/video equipment.
Most of us that have gone the harmony way... did so to make controlling two or more devices in an activity limited to one remote. My wife use to give me grief abou the 5-7 remotes... she would say I want one remote one button... the harmony is the closest I have gotten.
teenie is offline
Old 2008-09-24, 09:11 PM   #8
roger1818
My preference is a JP1 remote. They are much cheaper, but you need to be a bit more tech savvy to program it.
Old 2008-10-19, 08:19 PM   #9
leemoreau
Default Can you buy a ATSC HD receiver standalone?
Quick question, I have 3 LCD tvs. I have a 52" Toshiba, 32" LG and a 32" Westinghouse. Right now my OTA is split to all 3 and I get HD on the first two fine, but the westinghouse is older and has no ATSC antenna so it's just analog. Can you just buy a standalone receiver box that would connect using component or HDMI to the TV? I know for media centre PCs I could get a ATSC pci capture card, I just prefer keeping my media centre PC out of the bedroom, just curious the cheapest option as I can't seem to find anything. Thanks!
Last edited by stampeder; 2008-10-19 at 09:44 PM. Reason: Merged into existing thread about standalone ATSC HD Tuners
leemoreau is offline
Old 2008-10-19, 08:25 PM   #10
recneps77
You can, but they're extremely rare in Canada, and if you find one, it's far too expensive for what it does.
After Feb., you should be able to find them easier, as the US will be ATSC-only (for the majority), making a need for the products (in the US).
As for up here, the electronics giants would prefer you to buy cable/sat subscriptions through them, so they will hold off as long as possible before stocking these kind of items.
recneps77 is offline
Old 2008-10-19, 10:17 PM   #11
Friko
Thanks for the help guys
Friko is offline
Old 2008-10-20, 08:15 AM   #12
Smog
it's expensive but some satellite receivers have the ATSC tuner built in with HDMI out,
one example is the nfusion and it also have a USB port for PVR and playback.
and there's also the Coolsat 8100 HD
most HD receivers retails for around 400$ but can do SAT HD
CM4228a+CM7777=digital tv 185 km away.
http://www.tvfool.com/?option=com_wr...134931fec40ad0
Smog is offline
Old 2008-10-20, 10:14 AM   #13
roger1818
Yes, though they are hard to find in Canada. If you don't mind driving to the US, you can get the highly rated Samsung DTB-H260F for about $170.
Old 2008-10-23, 11:28 AM   #14
roger1818
Originally Posted by Smog
so far the DTT-901 and the CM7000 are the boxes of choice for analog tvs and both are good performing transition boxes.
I agree. I have heard very few complaints with either of these boxes and they seem very reliable. They each have their own pros and cons, but so does the DTB-H260F.
From what I have read, here is how the three boxes compare:
Samsung DTB-H260F:
  • Great for HDTVs or analog TVs with Component inputs,
  • Unusable with TVs that only have S-VIDEO or Composite inputs,
  • Has older 5th Generation decoder chip.
Channel Master CM7000:
  • S-VIDEO output gives superior picture quality to TVs that support it,
  • Small text in menus is difficult to read on smaller TVs,
  • Does not have analog passthrough for viewing analog broadcasts,
  • Excellent sensitivity for weak signals,
  • Has 6th Generation decoder chip for improved handling of interference.
Zenith DTT-901:
  • Good picture quality despite only having composite (or RF) outputs,
  • Has analog passthrough,
  • Has highly rated LG 6th Generation decoder chip for excellent handling of interference.
So which one to choose? I would say:
  • If you have an HDTV, go with the DTB-H260F,
  • If you have a large analog TV with an S-VIDEO input and don't care about analog channels or don't mind adding a splitter (resulting in an extra 3.5 to 4 dB signal loss), go with the CM7000,
  • Otherwise, the DTT-901 is your best option.
This is my personal opinion and other people may have other opinions.
Old 2008-10-23, 12:14 PM   #15
El Gran Chico
Location: Toronto/Etobicoke - Bloor/Royal York/Queensway/Islington
Thumbs up
Roger, I agree with you 100%. Just one more point to clarify - both the CM and Zenith STBs only output 480i so there are pointless for HDTVs.
Another point about the Samsung box - it is less capable than the Zenith at displaying cropped 16:9 on a 4:3 screen (don't know about the CM box since I don't have one) so not really a good fit for an analog set.
Orig 4221, A-D C5, CM 7778, Aquos LC37D62U, TiVo Premiere, DTVpal DVR
El Gran Chico is offline
Tags
atsc, ota
OTA Forum Sponsor
