Controlling a 9242 with two UHF remotes? - Canadian TV, Computing and Home Theatre Forums
Old 2009-06-22, 07:24 PM   #1
BellCraig
Default Controlling a 9242 with two UHF remotes?
Hello - I am having custom cabinet built-ins installed and, as a result, my components will be hidden in the cabinets. For my HD box (Bell 9242 HD PVR+), can I replace the tv1 IR remote with a UHF remote? (I am running the tv2 UHF remote that came with the box in another room).
Finally, I'm assuming this will solve my hidden component problem: will it? and....any other suggestions? (ie. UHF kits? can't seem to find them anywhere?)
BellCraig is offline
Old 2009-06-22, 07:52 PM   #2
Pinza
Did you try looking in the stickies in this Forum.?
Using 2 UHF remotes on dual tuner receivers in dual mode
http://www.digitalhome.ca/forum/showthread.php?t=70967
Pinza is online now
Old 2009-06-23, 03:43 PM   #3
Sleeping Wolf
I use 2 UHF remotes for my 9242 - as it feeds several TV's in single mode. All showing same thing. If that's the setup you plan on using check eBay out for remotes. I bought a seccond UHF remote for $10. Otherwise stores can sell you remotes for considerably more.
Primary System: Sharp Aquos 42 inch LC-42D65U,Sony BDP-350, JVC RX-8000VBK, BEV 9242, Harmony 670
Sleeping Wolf is offline
Old 2009-06-23, 05:10 PM   #4
BellCraig
Thanks guys - I read the thread and it gave me the answers I need. I am running 2 UHF (Bell 6.3) remotes with the system in Dual mode. Perfect! Thanks guys!
Tags
9242, uhf
