#1126 |
Since I saw the dimensions of the AC turnstile clone, model FMSS, 53" long and 8" high, I made a model of it.
Interesting to note that the turnstiles, while having a 100 degree plus beamwidth front and back, still have nulls. Code:
CM Antenna Craft FMSS Turnstile Clone CM AGT = 1.0 (0 db) at 98 mhz, Autoseg = 21 CE GW 1 9 0 1.09 -1 0 26.5 -1 0.1875 GW 2 9 0 -1.09 -1 0 -26.5 -1 0.1875 GW 3 1 0 -26.5 -1 0 -26.5 -4 0.1875 GW 4 1 0 26.5 -1 0 26.5 -4 0.1875 GW 5 19 0 26.5 -4 0 -26.5 -4 0.1875 GW 6 9 -1.09 0 1 -26.5 0 1 0.1875 GW 7 9 1.09 0 1 26.5 0 1 0.1875 GW 8 1 26.5 0 1 26.5 0 4 0.1875 GW 9 1 -26.5 0 1 -26.5 0 4 0.1875 GW 10 19 -26.5 0 4 26.5 0 4 0.1875 GW 11 1 -1.09 0 1 1.09 0 1 0.1875 GW 12 1 0 -1.09 -1 0 1.09 -1 0.14 GS 0 0 0.0254 ' All in in. GE 0 EK TL 11 1 12 1 450 0 LD 5 0 0 0 2.49e7 0 EX 0 12 1 0 1 0 GN -1 FR 0 1 0 0 98 0
#1127 |
FM "Omni" Antennas:
Certainly NOT an Omni-directional antenna pattern.... Looks like a typical bi-directional pattern, except rotated with deep nulls at 45-deg. Note that pattern is same whether Horizontal, Vertical or Total Gain. Antennacraft Spec Sheet for FMSS doesn't say very much: http://www.antennacraft.com/pdfs/FMSS.pdf However, the FMSS Manual shows a "9-in Intercoupler" (Twinlead) that is wrapped around the mount (so element to element distance is a bit less than 9-in): http://www.antennacraft.com/Manuals/FMSS_Manual.pdf Adding this phasing harness to the model may improve the antenna pattern, even though it isn't even close to a 1/4-wavelength (30-in, 90-degrees): http://electriciantraining.tpub.com/.../14182_211.htm http://www.cebik.com/content/a10/wire/turns.html [Cebik's website requires FREE Registration] BTW: Most on-line info re Turnstile Antennas pertains to their use for Satcom, with a ground plane, exploiting the overhead (presumably circularly polarized) coverage. |
#1128 |
FM "Omni" Antennas continued:
FYI: Winegard HD-6010 is a similar FM Turnstile...except NOT Folded...NOT Omni... and they don't want to talk about SWR: http://www.winegard.com/kbase/upload/HD-6010.pdf http://www.winegard.com/kbase/upload/1450463.pdf Hmmm....spec sheet says 10-in Height...so Element spacing might be about 9-in and interconnecting feedline might be 11-13-in??? Antiference (U.K.), Triax (U.K.) & others below make FM Omni Antennas where a single Folded Dipole is bent into nearly a complete circle...or HOOP: http://www.antiference.co.uk/sitefil...0%20Aerial.jpg http://www.antiference.co.uk/sitefil...%20Radio_0.pdf http://www.triax.co.uk/Products/Aeri...20Aerials.aspx [Somewhat better picture in their catalog.] FWIW: Bruce Carter cites a 1978 Audio Magazine series of articles by Michael J. Salvatti: http://www.mindspring.com/~brucec/fmant.htm Note that a single Folded Dipole bent into an "S" shape MIGHT have an Omni pattern. Dipole (Poland) still makes this type of FM antenna...but fortuitously mounts it VERTICALLY (for Vertical as well as Horizontal polarization coverage): http://www.dipolnet.com/estore-antennas-fm,4346.htm Click on image for full specs. Also note HOOP (Horiz only) and HOOP+WHIP (H+V) Omnis. Fracarro is the only one who actually publishes an Azimuthal Gain chart for the "S"...but NOT Hoop: http://www.fracarro.co.uk/index.php?...87&&Itemid=262 [Yup, it's OMNI.] And Televes appears to be the only one who publishes Azimuthal Gain chart for the HOOP: http://www.televes.com/en/content/dra-1201gif [Yup, it's OMNI.] http://www.televes.com/en/node/2314 Have fun and don't forget to check Horizontal, Vertical and Total antenna patterns.... |
#1129 | ||
#1130 |
FM Double-Hoop Omni Antenna:
First cut at a 4nec2 model for the Double-Hoop Omni Antenna, which may be a few tenths of an inch larger diameter than SOME manu' specs and I'm guessing at the size of the "Open Space" opposite the Feedpoint. It's DEFINITELY AN OMNI (-1.6 to +1.3 dBi) with high SWR (7-15) and only responds to Horizontally polarized signals. [Rescaling slightly LARGER would be a better "fit"...and/or maybe a larger "Open Space"...still tweaking]: Code:
CM FM Omni Double Hoop, Open Space=5segs~2.5-in, 4nec2 by holl_ands, 14Dec2011 CM Diameter=20-in, Separation=2-in, 125 segments per full Hoop, Feedpoint Gap=2segs~1-in. CM 3/8-in Diameter Aluminum Elements. CE SY Rsrc=0.22 ' SOURCE Wire Radius, Adjust for AGT=1.0: Rsrc=0.22 at 98 MHz. ' GW 1 1 -10 0 -1 -9.9873697 -0.5024433 -1 0.1875 ' GAP GW 2 1 -9.9873697 -0.5024433 -1 -9.9495102 -1.0036173 -1 0.1875 GW 3 1 -9.9495102 -1.0036173 -1 -9.8865173 -1.5022559 -1 0.1875 GW 4 1 -9.8865173 -1.5022559 -1 -9.7985504 -1.9971 -1 0.1875 GW 5 1 -9.7985504 -1.9971 -1 -9.6858315 -2.4868988 -1 0.1875 GW 6 1 -9.6858315 -2.4868988 -1 -9.5486453 -2.9704157 -1 0.1875 GW 7 1 -9.5486453 -2.9704157 -1 -9.3873386 -3.4464291 -1 0.1875 GW 8 1 -9.3873386 -3.4464291 -1 -9.2023185 -3.9137366 -1 0.1875 GW 9 1 -9.2023185 -3.9137366 -1 -8.9940524 -4.3711575 -1 0.1875 GW 10 1 -8.9940524 -4.3711575 -1 -8.7630669 -4.8175366 -1 0.1875 GW 11 1 -8.7630669 -4.8175366 -1 -8.5099449 -5.2517465 -1 0.1875 GW 12 1 -8.5099449 -5.2517465 -1 -8.235326 -5.6726894 -1 0.1875 GW 13 1 -8.235326 -5.6726894 -1 -7.9399039 -6.0793031 -1 0.1875 GW 14 1 -7.9399039 -6.0793031 -1 -7.6244252 -6.4705594 -1 0.1875 GW 15 1 -7.6244252 -6.4705594 -1 -7.2896862 -6.8454709 -1 0.1875 GW 16 1 -7.2896862 -6.8454709 -1 -6.9365331 -7.2030902 -1 0.1875 GW 17 1 -6.9365331 -7.2030902 -1 -6.5658575 -7.5425138 -1 0.1875 GW 18 1 -6.5658575 -7.5425138 -1 -6.1785961 -7.8628843 -1 0.1875 GW 19 1 -6.1785961 -7.8628843 -1 -5.7757272 -8.1633925 -1 0.1875 GW 20 1 -5.7757272 -8.1633925 -1 -5.3582681 -8.4432791 -1 0.1875 GW 21 1 -5.3582681 -8.4432791 -1 -4.9272732 -8.7018374 -1 0.1875 GW 22 1 -4.9272732 -8.7018374 -1 -4.4838323 -8.9384142 -1 0.1875 GW 23 1 -4.4838323 -8.9384142 -1 -4.0290642 -9.1524118 -1 0.1875 GW 24 1 -4.0290642 -9.1524118 -1 -3.5641189 -9.3432894 -1 0.1875 GW 25 1 -3.5641189 -9.3432894 -1 -3.0901701 -9.5105654 -1 0.1875 GW 26 1 -3.0901701 -9.5105654 -1 -2.608415 -9.6538165 -1 0.1875 GW 27 1 -2.608415 -9.6538165 -1 -2.1200713 -9.7726811 -1 0.1875 GW 28 1 -2.1200713 -9.7726811 -1 -1.6263717 -9.8668594 -1 0.1875 GW 29 1 -1.6263717 -9.8668594 -1 -1.1285638 -9.936113 -1 0.1875 GW 30 1 -1.1285638 -9.936113 -1 -0.6279051 -9.9802673 -1 0.1875 GW 31 1 -0.6279051 -9.9802673 -1 -0.1256602 -9.9992106 -1 0.1875 GW 32 1 -0.1256602 -9.9992106 -1 0.37690197 -9.9928949 -1 0.1875 GW 33 1 0.37690197 -9.9928949 -1 0.87851181 -9.9613362 -1 0.1875 GW 34 1 0.87851181 -9.9613362 -1 1.37790276 -9.9046142 -1 0.1875 GW 35 1 1.37790276 -9.9046142 -1 1.87381299 -9.8228724 -1 0.1875 GW 36 1 1.87381299 -9.8228724 -1 2.36499016 -9.7163173 -1 0.1875 GW 37 1 2.36499016 -9.7163173 -1 2.85019252 -9.5852177 -1 0.1875 GW 38 1 2.85019252 -9.5852177 -1 3.32819528 -9.4299055 -1 0.1875 GW 39 1 3.32819528 -9.4299055 -1 3.79779094 -9.250772 -1 0.1875 GW 40 1 3.79779094 -9.250772 -1 4.25779291 -9.0482705 -1 0.1875 GW 41 1 4.25779291 -9.0482705 -1 4.70703937 -8.8229122 -1 0.1875 GW 42 1 4.70703937 -8.8229122 -1 5.14439528 -8.5752665 -1 0.1875 GW 43 1 5.14439528 -8.5752665 -1 5.5687563 -8.3059591 -1 0.1875 GW 44 1 5.5687563 -8.3059591 -1 5.97905 -8.0156697 -1 0.1875 GW 45 1 5.97905 -8.0156697 -1 6.37423976 -7.7051323 -1 0.1875 GW 46 1 6.37423976 -7.7051323 -1 6.75332795 -7.3751311 -1 0.1875 GW 47 1 6.75332795 -7.3751311 -1 7.11535669 -7.0264996 -1 0.1875 GW 48 1 7.11535669 -7.0264996 -1 7.45941142 -6.6601185 -1 0.1875 GW 49 1 7.45941142 -6.6601185 -1 7.78462283 -6.2769138 -1 0.1875 GW 50 1 7.78462283 -6.2769138 -1 8.09017008 -5.8778524 -1 0.1875 GW 51 1 8.09017008 -5.8778524 -1 8.37528031 -5.4639433 -1 0.1875 GW 52 1 8.37528031 -5.4639433 -1 8.63923425 -5.0362319 -1 0.1875 GW 53 1 8.63923425 -5.0362319 -1 8.88136457 -4.5957984 -1 0.1875 GW 54 1 8.88136457 -4.5957984 -1 9.10105984 -4.1437559 -1 0.1875 GW 55 1 9.10105984 -4.1437559 -1 9.29776496 -3.6812457 -1 0.1875 GW 56 1 9.29776496 -3.6812457 -1 9.47098307 -3.2094362 -1 0.1875 GW 57 1 9.47098307 -3.2094362 -1 9.62027677 -2.7295193 -1 0.1875 GW 58 1 9.62027677 -2.7295193 -1 9.7452689 -2.2427075 -1 0.1875 GW 59 1 9.7452689 -2.2427075 -1 9.84564331 -1.7502307 -1 0.1875 GW 60 1 9.84564331 -1.7502307 -1 9.92114685 -1.2533323 -1 0.1875 ' GW 61 1 9.92114685 -1.2533323 -1 9.97158898 -0.7532681 -1 0.1875 ' OPEN ' GW 62 1 9.97158898 -0.7532681 -1 9.99684173 -0.2513008 -1 0.1875 ' OPEN ' GW 63 1 9.99684173 -0.2513008 -1 9.99684173 0.25130079 -1 0.1875 ' OPEN ' GW 64 1 9.99684173 0.25130079 -1 9.97158898 0.75326811 -1 0.1875 ' OPEN ' GW 65 1 9.97158898 0.75326811 -1 9.92114685 1.25333228 -1 0.1875 ' OPEN GW 66 1 9.92114685 1.25333228 -1 9.84564331 1.75023071 -1 0.1875 GW 67 1 9.84564331 1.75023071 -1 9.7452689 2.24270748 -1 0.1875 GW 68 1 9.7452689 2.24270748 -1 9.62027677 2.72951929 -1 0.1875 GW 69 1 9.62027677 2.72951929 -1 9.47098307 3.20943622 -1 0.1875 GW 70 1 9.47098307 3.20943622 -1 9.29776496 3.68124567 -1 0.1875 GW 71 1 9.29776496 3.68124567 -1 9.10105984 4.14375591 -1 0.1875 GW 72 1 9.10105984 4.14375591 -1 8.88136457 4.59579843 -1 0.1875 GW 73 1 8.88136457 4.59579843 -1 8.63923425 5.03623189 -1 0.1875 GW 74 1 8.63923425 5.03623189 -1 8.37528031 5.46394331 -1 0.1875 GW 75 1 8.37528031 5.46394331 -1 8.09017008 5.87785236 -1 0.1875 GW 76 1 8.09017008 5.87785236 -1 7.78462283 6.27691378 -1 0.1875 GW 77 1 7.78462283 6.27691378 -1 7.45941142 6.6601185 -1 0.1875 GW 78 1 7.45941142 6.6601185 -1 7.11535669 7.02649961 -1 0.1875 GW 79 1 7.11535669 7.02649961 -1 6.75332795 7.3751311 -1 0.1875 GW 80 1 6.75332795 7.3751311 -1 6.37423976 7.70513228 -1 0.1875 GW 81 1 6.37423976 7.70513228 -1 5.97905 8.01566969 -1 0.1875 GW 82 1 5.97905 8.01566969 -1 5.5687563 8.30595906 -1 0.1875 GW 83 1 5.5687563 8.30595906 -1 5.14439528 8.57526654 -1 0.1875 GW 84 1 5.14439528 8.57526654 -1 4.70703937 8.8229122 -1 0.1875 GW 85 1 4.70703937 8.8229122 -1 4.25779291 9.04827047 -1 0.1875 GW 86 1 4.25779291 9.04827047 -1 3.79779094 9.25077205 -1 0.1875 GW 87 1 3.79779094 9.25077205 -1 3.32819528 9.42990551 -1 0.1875 GW 88 1 3.32819528 9.42990551 -1 2.85019252 9.58521772 -1 0.1875 GW 89 1 2.85019252 9.58521772 -1 2.36499016 9.71631732 -1 0.1875 GW 90 1 2.36499016 9.71631732 -1 1.87381299 9.82287244 -1 0.1875 GW 91 1 1.87381299 9.82287244 -1 1.37790276 9.90461417 -1 0.1875 GW 92 1 1.37790276 9.90461417 -1 0.87851181 9.96133622 -1 0.1875 GW 93 1 0.87851181 9.96133622 -1 0.37690197 9.99289488 -1 0.1875 GW 94 1 0.37690197 9.99289488 -1 -0.1256602 9.99921063 -1 0.1875 GW 95 1 -0.1256602 9.99921063 -1 -0.6279051 9.98026732 -1 0.1875 GW 96 1 -0.6279051 9.98026732 -1 -1.1285638 9.93611299 -1 0.1875 GW 97 1 -1.1285638 9.93611299 -1 -1.6263717 9.86685945 -1 0.1875 GW 98 1 -1.6263717 9.86685945 -1 -2.1200713 9.7726811 -1 0.1875 GW 99 1 -2.1200713 9.7726811 -1 -2.608415 9.65381654 -1 0.1875 GW 100 1 -2.608415 9.65381654 -1 -3.0901701 9.51056535 -1 0.1875 GW 101 1 -3.0901701 9.51056535 -1 -3.5641189 9.34328937 -1 0.1875 GW 102 1 -3.5641189 9.34328937 -1 -4.0290642 9.15241181 -1 0.1875 GW 103 1 -4.0290642 9.15241181 -1 -4.4838323 8.93841417 -1 0.1875 GW 104 1 -4.4838323 8.93841417 -1 -4.9272732 8.7018374 -1 0.1875 GW 105 1 -4.9272732 8.7018374 -1 -5.3582681 8.44327913 -1 0.1875 GW 106 1 -5.3582681 8.44327913 -1 -5.7757272 8.16339252 -1 0.1875 GW 107 1 -5.7757272 8.16339252 -1 -6.1785961 7.86288425 -1 0.1875 GW 108 1 -6.1785961 7.86288425 -1 -6.5658575 7.54251378 -1 0.1875 GW 109 1 -6.5658575 7.54251378 -1 -6.9365331 7.20309016 -1 0.1875 GW 110 1 -6.9365331 7.20309016 -1 -7.2896862 6.84547087 -1 0.1875 GW 111 1 -7.2896862 6.84547087 -1 -7.6244252 6.47055945 -1 0.1875 GW 112 1 -7.6244252 6.47055945 -1 -7.9399039 6.07930315 -1 0.1875 GW 113 1 -7.9399039 6.07930315 -1 -8.235326 5.67268937 -1 0.1875 GW 114 1 -8.235326 5.67268937 -1 -8.5099449 5.25174646 -1 0.1875 GW 115 1 -8.5099449 5.25174646 -1 -8.7630669 4.81753661 -1 0.1875 GW 116 1 -8.7630669 4.81753661 -1 -8.9940524 4.37115748 -1 0.1875 GW 117 1 -8.9940524 4.37115748 -1 -9.2023185 3.91373661 -1 0.1875 GW 118 1 -9.2023185 3.91373661 -1 -9.3873386 3.44642913 -1 0.1875 GW 119 1 -9.3873386 3.44642913 -1 -9.5486453 2.97041575 -1 0.1875 GW 120 1 -9.5486453 2.97041575 -1 -9.6858315 2.48689882 -1 0.1875 GW 121 1 -9.6858315 2.48689882 -1 -9.7985504 1.9971 -1 0.1875 GW 122 1 -9.7985504 1.9971 -1 -9.8865173 1.50225591 -1 0.1875 GW 123 1 -9.8865173 1.50225591 -1 -9.9495102 1.00361732 -1 0.1875 GW 124 1 -9.9495102 1.00361732 -1 -9.9873697 0.50244331 -1 0.1875 ' GW 125 1 -9.9873697 0.50244331 -1 -10 0 -1 0.1875 ' GAP GW 126 1 -10 0 1 -9.9873697 0.50244331 1 0.1875 GW 127 1 -9.9873697 -0.5024433 1 -9.9495102 -1.0036173 1 0.1875 GW 128 1 -9.9495102 -1.0036173 1 -9.8865173 -1.5022559 1 0.1875 GW 129 1 -9.8865173 -1.5022559 1 -9.7985504 -1.9971 1 0.1875 GW 130 1 -9.7985504 -1.9971 1 -9.6858315 -2.4868988 1 0.1875 GW 131 1 -9.6858315 -2.4868988 1 -9.5486453 -2.9704157 1 0.1875 GW 132 1 -9.5486453 -2.9704157 1 -9.3873386 -3.4464291 1 0.1875 GW 133 1 -9.3873386 -3.4464291 1 -9.2023185 -3.9137366 1 0.1875 GW 134 1 -9.2023185 -3.9137366 1 -8.9940524 -4.3711575 1 0.1875 GW 135 1 -8.9940524 -4.3711575 1 -8.7630669 -4.8175366 1 0.1875 GW 136 1 -8.7630669 -4.8175366 1 -8.5099449 -5.2517465 1 0.1875 GW 137 1 -8.5099449 -5.2517465 1 -8.235326 -5.6726894 1 0.1875 GW 138 1 -8.235326 -5.6726894 1 -7.9399039 -6.0793031 1 0.1875 GW 139 1 -7.9399039 -6.0793031 1 -7.6244252 -6.4705594 1 0.1875 GW 140 1 -7.6244252 -6.4705594 1 -7.2896862 -6.8454709 1 0.1875 GW 141 1 -7.2896862 -6.8454709 1 -6.9365331 -7.2030902 1 0.1875 GW 142 1 -6.9365331 -7.2030902 1 -6.5658575 -7.5425138 1 0.1875 GW 143 1 -6.5658575 -7.5425138 1 -6.1785961 -7.8628843 1 0.1875 GW 144 1 -6.1785961 -7.8628843 1 -5.7757272 -8.1633925 1 0.1875 GW 145 1 -5.7757272 -8.1633925 1 -5.3582681 -8.4432791 1 0.1875 GW 146 1 -5.3582681 -8.4432791 1 -4.9272732 -8.7018374 1 0.1875 GW 147 1 -4.9272732 -8.7018374 1 -4.4838323 -8.9384142 1 0.1875 GW 148 1 -4.4838323 -8.9384142 1 -4.0290642 -9.1524118 1 0.1875 GW 149 1 -4.0290642 -9.1524118 1 -3.5641189 -9.3432894 1 0.1875 GW 150 1 -3.5641189 -9.3432894 1 -3.0901701 -9.5105654 1 0.1875 GW 151 1 -3.0901701 -9.5105654 1 -2.608415 -9.6538165 1 0.1875 GW 152 1 -2.608415 -9.6538165 1 -2.1200713 -9.7726811 1 0.1875 GW 153 1 -2.1200713 -9.7726811 1 -1.6263717 -9.8668594 1 0.1875 GW 154 1 -1.6263717 -9.8668594 1 -1.1285638 -9.936113 1 0.1875 GW 155 1 -1.1285638 -9.936113 1 -0.6279051 -9.9802673 1 0.1875 GW 156 1 -0.6279051 -9.9802673 1 -0.1256602 -9.9992106 1 0.1875 GW 157 1 -0.1256602 -9.9992106 1 0.37690197 -9.9928949 1 0.1875 GW 158 1 0.37690197 -9.9928949 1 0.87851181 -9.9613362 1 0.1875 GW 159 1 0.87851181 -9.9613362 1 1.37790276 -9.9046142 1 0.1875 GW 160 1 1.37790276 -9.9046142 1 1.87381299 -9.8228724 1 0.1875 GW 161 1 1.87381299 -9.8228724 1 2.36499016 -9.7163173 1 0.1875 GW 162 1 2.36499016 -9.7163173 1 2.85019252 -9.5852177 1 0.1875 GW 163 1 2.85019252 -9.5852177 1 3.32819528 -9.4299055 1 0.1875 GW 164 1 3.32819528 -9.4299055 1 3.79779094 -9.250772 1 0.1875 GW 165 1 3.79779094 -9.250772 1 4.25779291 -9.0482705 1 0.1875 GW 166 1 4.25779291 -9.0482705 1 4.70703937 -8.8229122 1 0.1875 GW 167 1 4.70703937 -8.8229122 1 5.14439528 -8.5752665 1 0.1875 GW 168 1 5.14439528 -8.5752665 1 5.5687563 -8.3059591 1 0.1875 GW 169 1 5.5687563 -8.3059591 1 5.97905 -8.0156697 1 0.1875 GW 170 1 5.97905 -8.0156697 1 6.37423976 -7.7051323 1 0.1875 GW 171 1 6.37423976 -7.7051323 1 6.75332795 -7.3751311 1 0.1875 GW 172 1 6.75332795 -7.3751311 1 7.11535669 -7.0264996 1 0.1875 GW 173 1 7.11535669 -7.0264996 1 7.45941142 -6.6601185 1 0.1875 GW 174 1 7.45941142 -6.6601185 1 7.78462283 -6.2769138 1 0.1875 GW 175 1 7.78462283 -6.2769138 1 8.09017008 -5.8778524 1 0.1875 GW 176 1 8.09017008 -5.8778524 1 8.37528031 -5.4639433 1 0.1875 GW 177 1 8.37528031 -5.4639433 1 8.63923425 -5.0362319 1 0.1875 GW 178 1 8.63923425 -5.0362319 1 8.88136457 -4.5957984 1 0.1875 GW 179 1 8.88136457 -4.5957984 1 9.10105984 -4.1437559 1 0.1875 GW 180 1 9.10105984 -4.1437559 1 9.29776496 -3.6812457 1 0.1875 GW 181 1 9.29776496 -3.6812457 1 9.47098307 -3.2094362 1 0.1875 GW 182 1 9.47098307 -3.2094362 1 9.62027677 -2.7295193 1 0.1875 GW 183 1 9.62027677 -2.7295193 1 9.7452689 -2.2427075 1 0.1875 GW 184 1 9.7452689 -2.2427075 1 9.84564331 -1.7502307 1 0.1875 GW 185 1 9.84564331 -1.7502307 1 9.92114685 -1.2533323 1 0.1875 ' GW 186 1 9.92114685 -1.2533323 1 9.97158898 -0.7532681 1 0.1875 ' OPEN ' GW 187 1 9.97158898 -0.7532681 1 9.99684173 -0.2513008 1 0.1875 ' OPEN ' GW 188 1 9.99684173 -0.2513008 1 9.99684173 0.25130079 1 0.1875 ' OPEN ' GW 189 1 9.99684173 0.25130079 1 9.97158898 0.75326811 1 0.1875 ' OPEN ' GW 190 1 9.97158898 0.75326811 1 9.92114685 1.25333228 1 0.1875 ' OPEN GW 191 1 9.92114685 1.25333228 1 9.84564331 1.75023071 1 0.1875 GW 192 1 9.84564331 1.75023071 1 9.7452689 2.24270748 1 0.1875 GW 193 1 9.7452689 2.24270748 1 9.62027677 2.72951929 1 0.1875 GW 194 1 9.62027677 2.72951929 1 9.47098307 3.20943622 1 0.1875 GW 195 1 9.47098307 3.20943622 1 9.29776496 3.68124567 1 0.1875 GW 196 1 9.29776496 3.68124567 1 9.10105984 4.14375591 1 0.1875 GW 197 1 9.10105984 4.14375591 1 8.88136457 4.59579843 1 0.1875 GW 198 1 8.88136457 4.59579843 1 8.63923425 5.03623189 1 0.1875 GW 199 1 8.63923425 5.03623189 1 8.37528031 5.46394331 1 0.1875 GW 200 1 8.37528031 5.46394331 1 8.09017008 5.87785236 1 0.1875 GW 201 1 8.09017008 5.87785236 1 7.78462283 6.27691378 1 0.1875 GW 202 1 7.78462283 6.27691378 1 7.45941142 6.6601185 1 0.1875 GW 203 1 7.45941142 6.6601185 1 7.11535669 7.02649961 1 0.1875 GW 204 1 7.11535669 7.02649961 1 6.75332795 7.3751311 1 0.1875 GW 205 1 6.75332795 7.3751311 1 6.37423976 7.70513228 1 0.1875 GW 206 1 6.37423976 7.70513228 1 5.97905 8.01566969 1 0.1875 GW 207 1 5.97905 8.01566969 1 5.5687563 8.30595906 1 0.1875 GW 208 1 5.5687563 8.30595906 1 5.14439528 8.57526654 1 0.1875 GW 209 1 5.14439528 8.57526654 1 4.70703937 8.8229122 1 0.1875 GW 210 1 4.70703937 8.8229122 1 4.25779291 9.04827047 1 0.1875 GW 211 1 4.25779291 9.04827047 1 3.79779094 9.25077205 1 0.1875 GW 212 1 3.79779094 9.25077205 1 3.32819528 9.42990551 1 0.1875 GW 213 1 3.32819528 9.42990551 1 2.85019252 9.58521772 1 0.1875 GW 214 1 2.85019252 9.58521772 1 2.36499016 9.71631732 1 0.1875 GW 215 1 2.36499016 9.71631732 1 1.87381299 9.82287244 1 0.1875 GW 216 1 1.87381299 9.82287244 1 1.37790276 9.90461417 1 0.1875 GW 217 1 1.37790276 9.90461417 1 0.87851181 9.96133622 1 0.1875 GW 218 1 0.87851181 9.96133622 1 0.37690197 9.99289488 1 0.1875 GW 219 1 0.37690197 9.99289488 1 -0.1256602 9.99921063 1 0.1875 GW 220 1 -0.1256602 9.99921063 1 -0.6279051 9.98026732 1 0.1875 GW 221 1 -0.6279051 9.98026732 1 -1.1285638 9.93611299 1 0.1875 GW 222 1 -1.1285638 9.93611299 1 -1.6263717 9.86685945 1 0.1875 GW 223 1 -1.6263717 9.86685945 1 -2.1200713 9.7726811 1 0.1875 GW 224 1 -2.1200713 9.7726811 1 -2.608415 9.65381654 1 0.1875 GW 225 1 -2.608415 9.65381654 1 -3.0901701 9.51056535 1 0.1875 GW 226 1 -3.0901701 9.51056535 1 -3.5641189 9.34328937 1 0.1875 GW 227 1 -3.5641189 9.34328937 1 -4.0290642 9.15241181 1 0.1875 GW 228 1 -4.0290642 9.15241181 1 -4.4838323 8.93841417 1 0.1875 GW 229 1 -4.4838323 8.93841417 1 -4.9272732 8.7018374 1 0.1875 GW 230 1 -4.9272732 8.7018374 1 -5.3582681 8.44327913 1 0.1875 GW 231 1 -5.3582681 8.44327913 1 -5.7757272 8.16339252 1 0.1875 GW 232 1 -5.7757272 8.16339252 1 -6.1785961 7.86288425 1 0.1875 GW 233 1 -6.1785961 7.86288425 1 -6.5658575 7.54251378 1 0.1875 GW 234 1 -6.5658575 7.54251378 1 -6.9365331 7.20309016 1 0.1875 GW 235 1 -6.9365331 7.20309016 1 -7.2896862 6.84547087 1 0.1875 GW 236 1 -7.2896862 6.84547087 1 -7.6244252 6.47055945 1 0.1875 GW 237 1 -7.6244252 6.47055945 1 -7.9399039 6.07930315 1 0.1875 GW 238 1 -7.9399039 6.07930315 1 -8.235326 5.67268937 1 0.1875 GW 239 1 -8.235326 5.67268937 1 -8.5099449 5.25174646 1 0.1875 GW 240 1 -8.5099449 5.25174646 1 -8.7630669 4.81753661 1 0.1875 GW 241 1 -8.7630669 4.81753661 1 -8.9940524 4.37115748 1 0.1875 GW 242 1 -8.9940524 4.37115748 1 -9.2023185 3.91373661 1 0.1875 GW 243 1 -9.2023185 3.91373661 1 -9.3873386 3.44642913 1 0.1875 GW 244 1 -9.3873386 3.44642913 1 -9.5486453 2.97041575 1 0.1875 GW 245 1 -9.5486453 2.97041575 1 -9.6858315 2.48689882 1 0.1875 GW 246 1 -9.6858315 2.48689882 1 -9.7985504 1.9971 1 0.1875 GW 247 1 -9.7985504 1.9971 1 -9.8865173 1.50225591 1 0.1875 GW 248 1 -9.8865173 1.50225591 1 -9.9495102 1.00361732 1 0.1875 GW 249 1 -9.9495102 1.00361732 1 -9.9873697 0.50244331 1 0.1875 GW 250 1 -9.9873697 -0.5024433 1 -10 0 1 0.1875 GW 251 5 9.92114685 -1.2533323 -1 9.92114685 -1.2533323 1 0.1875 ' Connect GW 252 5 9.92114685 1.25333228 -1 9.92114685 1.25333228 1 0.1875 ' Connect GW 253 1 -9.9873697 -0.5024433 -1 -9.9873697 0.50244331 -1 Rsrc ' SOURCE GS 0 0 0.0254 ' All in inches. |
#1131 |
The rest of the above 4nec2 file:
Code:
GE 0 EK LD 5 0 0 0 3.77e7 0 ' Aluminum EX 0 253 1 0 1 0 ' Simulated SOURCE on GW253 GN -1 ' FR Freq Sweep choices in order of increasing calculation time (fm holl_ands): ' FR 0 0 0 0 198 0 ' Fixed Freq ' FR 0 0 0 0 590 0 ' Fixed Freq ' FR 0 29 0 0 470 12 ' Freq Sweep 470-806 every 12 MHz - OLD UHF BAND ' FR 0 34 0 0 410 12 ' Freq Sweep 410-806 every 12 MHz - Even Wider Sweep ' FR 0 39 0 0 470 6 ' Freq Sweep 470-698 every 6 MHz - PREFERRED FOR UHF ' FR 0 77 0 0 470 3 ' Freq Sweep 470-698 every 3 MHz ' FR 0 153 0 0 470 1.5 ' Freq Sweep 470-698 every 1.5 MHz ' FR 0 71 0 0 300 10 ' Freq Sweep 300-1000 every 10 MHz - WIDEBAND SWEEP ' FR Hi-VHF choices: ' FR 0 15 0 0 174 3 ' Freq Sweep 174-216 every 3 MHz ' FR 0 29 0 0 174 1.5 ' Freq Sweep 174-216 every 1.5 MHz - PREFERRED ' FR 0 43 0 0 174 1 ' Freq Sweep 174-216 every 1 MHz - Hi-Rez ' FR 0 26 0 0 150 6 ' Freq Sweep 150-300 every 6 MHz - WIDEBAND SWEEP ' FR Lo-VHF choices: FR 0 22 0 9 87 1 ' Frequency Sweep every 1 MHz for 87-108 MHz - FM Band ' FR 0 19 0 0 54 3 ' Frequency Sweep every 3 MHz for Ch2-6 + FM ' FR 0 28 0 0 54 6 ' Wide Freq Sweep every 6 MHz for Ch2-13 ' FR 0 35 0 0 54 1 ' Frequency Sweep every 1 MHz for Ch2-6 ' FR 0 36 0 0 75 1 ' Frequency Sweep every 1 MHz for Ch5 + Ch6 + FM ' FR 0 41 0 0 75 2 ' Frequency Sweep every 2 MHz for 75-115 MHz ' FR 0 64 0 0 54 12 ' Super Wide Freq Sweep 54-810 every 12 MHz ' RP choices in order of increasing calculation time: ' RP 0 1 1 1510 90 90 1 1 0 0 ' 1D Gain toward 0-deg Azimuth - SIDE GAIN ' RP 0 1 1 1510 90 0 1 1 0 0 ' 1D Gain toward 90-deg Azimuth - FORWARD GAIN ' RP 0 1 1 1510 90 180 1 1 0 0 ' 1D Gain toward 270-deg Azimuth - REVERSE GAIN ' RP 0 1 37 1510 90 0 1 5 0 0 ' 2D (Left only) Azimuthal Gain Slice RP 0 1 73 1510 90 0 1 5 0 0 ' 2D Azimuthal Gain Slice - PREFERRED ' RP 0 73 1 1510 90 0 5 1 0 0 ' 2D Elevation Gain Slice ' RP 0 73 73 1510 90 0 5 5 0 0 ' 3D Lower Hemisphere reveals antenna (Fixed Freq) ' RP 0 285 73 1510 90 0 5 5 0 0 ' 3D Full Coverage obscures antenna (Fixed Freq) EN |
#1132 |
Thats interesting. The single 3D pattern is a double facing eyeball, heh. I like that its only 20" in diameter. It doesnt seem to be a 300ohm antenna as expected as the SWR is high at 300.
I stacked it at 8 inches apart same as the FMSS, rotated the bottom element 180 degrees and the gain increased, and the vertical pattern is on a diagonal while the horizontal pattern remains round, which is nice. NEC file: http://www.wuala.com/300ohm/Document...0_stacked.nec/
#1133 |
IN SEARCH OF THE "BEST" OMNI FOR FM BAND: [May rescale to other Bands.]
Fol. Table compares nine different OMNI (many are Quasi-OMNI) Antennas. Full analysis with charts and graphs and descriptions can be found here: http://imageevent.com/holl_ands/omni Code:
FM WORST/BEST Gain (dBi, all angles & freqs): HORIZONTAL VERTICAL TOTAL SWR a) FM Monopole Whip (Vert. Pol.): 0 +1.5 to +1.6 +1.5 to +1.6 3-4.5 (75-ohms) b) FM Vertical Folded Dipoles (Vert. Pol.): 0 -1.7 to +2.6 -1.7 to +2.6 1-2.0 (300-ohms) c) FM Turnstile (Horiz. Pol.): -13 to +1.4 0 -13 to +1.4 3.5-1.5 (300-ohms) d) FM Double-Hoop (Horiz. Pol.): -2.1 to +1.3 0 -2.1 to +1.3 6-11 (300-ohms) e) FM Double-Hoop with Vertical Whip: -3.7 to +1.2 -53 to -4.6 -3.2 to +1.9 5.1-7.1 (300-ohms) f) FM Double-Hoop + Vertical-Dipole Outside: -12 to +1.0 -13 to +1.9 -1.9 to +2.1 1-5 (75-ohms) g) FM Double-Hoop + Vertical-FD Outside: -3.9 to +1.2 -22 to -1.4 -2.3 to +1.8 6.4-6.8 (300-ohms) h) FM Double-Hoop + Vertical-Dipole In Center: -5.9 to +0.9 -9.4 to +1.5 -1.2 to +2.4 2.6-6 (300-ohms) i) FM Double-Hoop + Vertical-FD In Center: -5.2 to +0.8 -10 to +1.2 -1.8 to +2.3 2.2-7.2 (300-ohms) SETUP to Landscape and then PRINT. Vertically Polarized (ONLY) signals: Vertical Folded Dipole (VFD) had slightly higher Gain FORWARD and much better SWR than the Vertical Monopole Whip. VFD Gain was within +/- 2.2 dB across all angles and frequencies with excellent SWR between 1 and 2. VFD is a truly Superior OMNI Antenna (for Vert. Pol. ONLY). Horizontally Polarized (ONLY) signals: Double-Hoop (DH) Gain was within +/- 1.5 dB across all angles and frequencies, but SWR of 6-11 was quite high. However, it was clearly superior to the Turnstile (Crossed Folded Dipoles), which had very deep Gain holes away from the Bi-Directional lobes....both of which changed angles as the frequency changed. Perhaps there is something that can be done to reduce the DH's SWR???? As the Double-Hoop (DH) Opening (opposite the Feedpoint) gets smaller, Gain increases slightly, but at the expense of higher SWR. I picked an Opening of 3.5-in as being the "best" compromise, rather than 2.5-in in post#1130 above. Vertically & Polarized signals: Double-Hoop + Vertical-Dipole-In-Center barely edged out the Double-Hoop + Vertical-Folded Dipole-In-Center. Horizontal Gain for the "worst case" angle and frequency was -5.2 and -5.9 dBi, with "worst case" Vertical Gain being -9.4 and -10 dBi respectively. Clearly we haven't yet found the ideal Dual Polarization OMNI.... The other three candidates had higher or much higher "worst case" Vertical Gain and one even had a "worst case" Horizontal Gain of -12 dBi (with 75-ohm impedance). There are a few more candidates for which I have not yet run 4nec2 analyses..... |
#1134 | |
![]() It has a 8ft mini coax run from the whip to the receiver end with a 300 to 75 ohm balun at the receiver end. I always thought whips were balanced to ground, so wouldnt a 75 ohm whip used in this way technically need two baluns, one 1:1 at the antenna end to go from balanced to unbalanced, and one 4:1 at the receiver end for 300 ohm input ?
#1135 | |
If your FM Receiver (esp. antiques) only has 300-ohm twinlead input, use Balun. |
#1136 | |
But my in general question is, shouldnt a whip antenna require a 1:1 balun before connecting to the 75 ohm mini coax ?
#1137 | |
But then there is the question - should one "inject" the dc power for the preamp into the receiver.... |
#1138 | ||
When I asked Arie Voors about how to model a whip antenna connected at the base, he said the other end of the EX wire had to go to a ground plane. Makes sense, I think. Quote:
#1139 | |
Power Insertion Module going towards your HDTV. ==================================================== In post#1133 above I provided a link to various OMNI antenna simulations. At the bottom is the 14-in Whip antenna (with a 2-in base) that came with my Stick Tuner. Note that the SWR is Excessive on most frequencies, except near the (high) resonant frequency. Modeling on a larger Ground Plane helped a bit, but it's far from being a "good" SWR. At the top, you'll also find results for an FM Monopole Whip OMNI, which includes two, slightly different 4nec2 models. The first is same as for the 14-in Whip, where the bottom segment of the Whip is declared to be the SOURCE. The second specifically defines the a 1-in Wire at the bottom of the Whip to be the SOURCE. Since results were within a couple tenths, I did not post results charts for the second. I don't know what is inside the Jensen FM25, but it COULD easily include a 1:1 Balun. But I would guess that the internal Preamp is PROBABLY direct connected between a very small ground plane in the base and the bottom of the active (FAT) whip element. Due to the very short connection (much less than a wavelength), common mode current problems are negligible, so an internal Balun is quite unnecessary: http://www.eznec.com/Amateur/Articles/Baluns.pdf PS: I wouldn't rule out some of these TOO TALL "whips" actually being Vertical Dipoles, which is either 75-ohms or 300-ohms (Folded), fed in the middle.... Interesting....I'm getting hits from someone in Reims, France......on vacation perhaps???? |
#1140 |
I added 4nec2 Analysis for two FM Quasi-Omni "ESS-Curve" type antennas, similar to Italian Fracarro ANT1200A and Polish Dipol A0222 & A0223: http://www.fracarro.es/download/prod.../FM_SERIES.pdf http://photos.imageevent.com/holl_an...%20Antenna.jpg Although Vertical Polarization pattern was close to Omni-Directional, the Horizontal pattern was Bi-Directional with deep nulls to the Sides (like a Horizontal Folded Dipole): http://imageevent.com/holl_ands/omni http://imageevent.com/holl_ands/omni...sfracarrodipol Here's an update to the comparison table: Code:
IN SEARCH OF THE "BEST" OMNI FOR FM BAND: FM WORST/BEST Gain (dBi, all angles & freqs): HORIZONTAL VERTICAL TOTAL SWR (Impedance) a) FM Monopole Whip (Vert. Pol.): 0 +1.5 to +1.6 +1.5 to +1.6 3-4.5 (75-ohms) b) FM Vertical Folded Dipoles (Vert. Pol.): 0 -1.7 to +2.6 -1.7 to +2.6 1-2.0 (300-ohms) c) FM Turnstile (Horiz. Pol.): -13 to +1.4 0 -13 to +1.4 3.5-1.5 (300-ohms) d) FM Double-Hoop (Horiz. Pol.): -2.1 to +1.3 0 -2.1 to +1.3 6-11 (300-ohms) e) FM Double-Hoop with Vertical Whip: -3.7 to +1.2 -53 to -4.6 -3.2 to +1.9 5.1-7.1 (300-ohms) f) FM Double-Hoop + Vertical-Dipole Outside: -12 to +1.0 -13 to +1.9 -1.9 to +2.1 1-5 (75-ohms) g) FM Double-Hoop + Vertical-FD Outside: -3.9 to +1.2 -22 to -1.4 -2.3 to +1.8 6.4-6.8 (300-ohms) h) FM Double-Hoop + Vertical-Dipole In Center: -5.9 to +0.9 -9.4 to +1.5 -1.2 to +2.4 2.6-6 (300-ohms) i) FM Double-Hoop + Vertical-FD In Center: -5.2 to +0.8 -10 to +1.2 -1.8 to +2.3 2.2-7.2 (300-ohms) j) FM ESS-Curve (similar to Fracarro ANT1200A): -4.4 to -1.4 -34 to +0.1 -4.4 to +2.5 1.3-2.7 (300-ohms) k) FM ESS-Curve (similar to Dipol A0222+A0223): -5.1 to -1.9 -36 to +0.4 -5.1 to +2.4 1.3-2.5 (300-ohms) |
